Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1554 Location: Nevada
Posted: Wed Mar 07, 2018 11:12 am Post subject: Spare Tire Rack 215/70R/16 Stock Location |
I finally got around to making the rack for my 215/70R-16 spare. Was very much in doubt it would fit but with a tiny bit of frame grinding, - well there you go.
Pretty simple really. One 4' X 3/8 rod from Home Depot (7 bucks), A piece of 10 GA sheet with a slot for the spring-clip and a tab welded to it for the bolt.
I only had to shave small radius's in the lower frame flanges - maybe 1/4 " at the deepest part. I cut the ends off the original squiggly rods and welded them to the tips of the new 3/8 rods (the 4' piece gets cut in half).
Here are the photos. . .
[img]https://s25.postimg.cc/u8zf8573j/DSC02227.jpg/img]
Feels a lot better than relying on a can of fix-a-flat and 12 volt compressor. I'm also confident I'll gain 10 MPG, corner like a Ferrari, and have all the ladies hanging around the van constantly _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale).
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Wed Mar 07, 2018 11:21 am Post subject: Re: Spare Rack 215/70R/16 Stock Location |
Well done! I'll be doing this once I find another CLK rim! _________________ Brandon
Instagram @joannthevan |
Posted: Wed Mar 07, 2018 3:05 pm Post subject: Re: Spare Rack 215/70R/16 Stock Location |
shagginwagon83 wrote: |
Well done! I'll be doing this once I find another CLK rim! |
Thanks - it was amazingly simple. I wish I had take a few photos where I ground the lower flanges of the frame. It was really a tiny amount to remove and because it's just the thin edge, goes rather quickly. For the rim, I used the 16" steel rim from Go-Westy when I bought the aluminum set several years ago - yes, that's how long I've been without a spare.
Do your rims have some special offset or bolt pattern? Don't know why it (the spare) would need to look the same as the rest otherwise. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Wed Mar 07, 2018 8:34 pm Post subject: Re: Spare Rack 215/70R/16 Stock Location |
You are my hero for the rest of the work week. Not calendar week mind you. Outstandingly simple! Bravo.
By contrast the insanity I was toying with building is a cross between Homer’s perfect car cup holder and an Escher drawing.
I think your design would also work well with the blue plastic drum Tupperware-like storage thing people have done.
Nice work. _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Wed Mar 07, 2018 9:15 pm Post subject: Re: Spare Rack 215/70R/16 Stock Location |
Thanks, I tend to go complicated as well and kept giving up at the thought of attempting it. Sometimes it's good to just dive in and get it done.
I should mention that the tire actually sits on the frame cross-member in the back. There's a bit of a flange sticking up which I bent away from the space using a 12" crescent (poor mans press-brake). I didn't have to bend it much and only the center 4". _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Wed Mar 07, 2018 10:10 pm Post subject: Re: Spare Rack 215/70R/16 Stock Location |
Will the tire install over the tall front plate when the van is sitting on its tires?
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
jimf909 Samba Member
Posted: Wed Mar 07, 2018 10:34 pm Post subject: Re: Spare Rack 215/70R/16 Stock Location |
vanis13 wrote: |
Ahh, you’re wondering if the van has to be driven onto ramps in order to get the tire out! Good question.
OP, this looks nice. I’ve settled into carrying a 14” oem spare as kind of a doughnut. If I get a flat in the front then I need to put a good 16” from the back into the front to fit over the big brakes and then I’ll put the doughnut on the back. This works for 2WDs and folks who haven’t seen your sweet solution. Well done! _________________ - Jim
Abscate wrote: |
E1 Samba Member
Joined: January 21, 2013 Posts: 6585 Location: Westfalia, Earth
Posted: Thu Mar 08, 2018 1:52 am Post subject: Re: Spare Rack 215/70R/16 Stock Location |
Well done, Sell me one! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Thu Mar 08, 2018 6:02 am Post subject: Re: Spare Rack 215/70R/16 Stock Location |
Ill take one too. Since Im prepping to install my new wheels this weekend Ive had spare concerns. Not gonna be poss to use my current spare so a mod like this is quite timely. I applaud your ingenuity. Bravo my man.
Now get them into production before I find myself on the side of the road and SOL. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Thu Mar 08, 2018 7:37 am Post subject: Re: Spare Rack 215/70R/16 Stock Location |
Thanks all - just wanted to share a fix that was so simple, hadn't thought of making 'em. I'll work on a design that can be shipped easily and put the concept up for feedback. Would anyone be opposed to threaded ends with a nut on either side of the sheet metal?
Yes, the tire can me removed and installed without the ramps - I've done it. Having the spring clip catch is essential for sure.
The driveway down to my shop is quite steep and the ramps just level the van out and makes things easier. Besides, I was also going to pull the fuel tank and see what I need to do to get it to stop leaking when I fill it all the way up. I still need to do that.
You do have to take it out sideways due to the sheet metal but it's doable. Might be a good idea to carry a set of painters coveralls stuffed somewhere - you will be getting familiar with the dirt getting this out. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Posted: Thu Mar 08, 2018 7:46 am Post subject: Re: Spare Rack 215/70R/16 Stock Location |
IMO, sell me the plate and I'll weld my rods on. _________________ Brandon
Posted: Thu Mar 08, 2018 7:47 am Post subject: Re: Spare Rack 215/70R/16 Stock Location |
Gizmoman wrote: |
You do have to take it out sideways due to the sheet metal but it's doable. Might be a good idea to carry a set of painters coveralls stuffed somewhere - you will be getting familiar with the dirt getting this out. |
EDIT - I may wokr on a concept where the sheet metal bit folds down to make removing it easier - like I said earlier, I tend to complicate things but this may be a worthwhile mod. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
jmillsj Samba Member
Joined: November 23, 2017 Posts: 110 Location: Denver, CO
Posted: Thu Mar 08, 2018 10:03 am Post subject: Re: Spare Rack 215/70R/16 Stock Location |
I would love one of these if you decide to make a few for sale. I am ready to buy a rear mounted tire carrier, but this would be preferable. _________________ 1985 Vanagon Westfalia EJ25
Vanagon owner since 1995 |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Mar 08, 2018 10:35 am Post subject: Re: Spare Rack 215/70R/16 Stock Location |
A simple, elegant solution - congrats!
Is it as quiet as when the clamshell was under there? I ran without a spare for a bit while my spare was repaired and found it a lot noisier than with the tire in place. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Thu Mar 08, 2018 10:36 am Post subject: Re: Spare Rack 215/70R/16 Stock Location |
jmillsj wrote: |
I would love one of these if you decide to make a few for sale. I am ready to buy a rear mounted tire carrier, but this would be preferable. |
I'm going to work on it today with the following concepts in mind:
1. Allow the sheet metal to pivot forward but not backward.
2. Make the rods so they can attach to the plate after shipping
3. Powder coat all the bits
4. Try to design inside the confines of a "standard" shipping carton and gather shipping rates
I will post the concept before proceeding to get some feedback.
This could take a few weeks to get into fab so you can either wait, or forge ahead with a rear mount - your call. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Jon_slider Samba Member
Posted: Thu Mar 08, 2018 3:38 pm Post subject: Re: Spare Rack 215/70R/16 Stock Location |
Gee, and I was almost done. . .
Well there you go fellas! Also, probably less expensive than what I had going.
The height from the top surface of the bolt tab to the rails is around 5". It would be easier to remove the tire if the plate folded down, but it would also need to resist folding up past the "ideal" angle, so the catch works properly - which really complicates things.
My Westy has 1" lift springs and 215/70R-16's and I can get the tire out when the van is on the ground by rolling it around the side of the plate. It's close though.
The Van Cafe unit is hard to beat.
Thanks Jon. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Posted: Thu Mar 08, 2018 4:53 pm Post subject: Re: Spare Rack 215/70R/16 Stock Location |
Van Cafe told me that their system would not work with the GW 16” rims with 215/60 R16 tires. I believe the barrier was the width of the alloy rim (7” IIRC). _________________ - Jim
Abscate wrote: |
Posted: Thu Mar 08, 2018 5:01 pm Post subject: Re: Spare Rack 215/70R/16 Stock Location |
Gizmoman wrote: |
215/70R-16 spare. Was very much in doubt it would fit but with a tiny bit of frame grinding, - well there you go. |
well done!
Van-Cafe cant hold a candle to that
jimf909 wrote: |
Van Cafe told me that their system would not work with the GW 16” rims with 215/60 R16 tires. |
aha! good catch
enter Gizmoman!
with the GW 16" Alloy carrier
new and improved, after thousands of requests, it is finally here! _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Posted: Thu Mar 08, 2018 5:36 pm Post subject: Re: Spare Rack 215/70R/16 Stock Location |
jimf909 wrote: |
Van Cafe told me that their system would not work with the GW 16” rims with 215/60 R16 tires. I believe the barrier was the width of the alloy rim (7” IIRC). |
A 215/60 R16 is almost 1-1/2" smaller in diameter than the 70 - the width is the same. Obviously you wouldn't need to trim the frame for this tire.
I think a guy could put a few kinks in the VC unit and get it to work. You might need to bend the front plate out a tad to make up for the kinks. I know I can't build them for 89 bucks. As you can see in my previous screenshot - the rods need to bend down away from the hinges about an inch and then back up
Mine is a 215/70 R-16 on a Go Westy 16" steel rim. I did put a few down-up bends in the rods but it fits like a glove. I'ts also a good idea to make sure the rad hoses are not crossing over each other right where the tire lands when it's in place.
Here are a few more shots of it going in (without ramps). Again, I have 1" lift springs on all four corners as well. As you will see, it doesn't have to go in sideways.
Getting it started
Onto the rack a bit more by rocking it while pushing a bit
Ready to lift and latch
