can't edit posts?
Forum Index -> Site Share: Facebook Twitter
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Mar 07, 2018 1:27 pm    Post subject: can't edit posts? Reply with quote
in the wake of the photobucket mess, I thought that we were able to edit posts to fix the broken links?
just tried and got this:
You are not allowed to edit a post after it has been posted for 2102400 minutes. If you need to update a thread title or edit something critical, please contact the admin.
is it on my end somehow?
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
djkeev
djkeev is offline
PostPosted: Wed Mar 07, 2018 3:51 pm    Post subject: Re: can't edit posts? Reply with quote
I think Everett made it a limited time opportunity.
Dave
Ghia
Vanagon
Beetle
PostPosted: Wed Mar 07, 2018 4:02 pm    Post subject: Re: can't edit posts? Reply with quote
I left it wide open for a while but since then I have been changing the max edit time as needed for people to fix older posts as needed.
PM me with the post you want to edit so I can see how old it is and I'll temporarily alter the max edit time, then set it back to normal once you are done.
I'm assuming you've already uploaded all the replacement pics here so if you haven't done that, please do that first to save time.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Mar 07, 2018 8:11 pm    Post subject: Re: can't edit posts? Reply with quote
truth be told, I haven't. but, if you add ~original to the extension all the photos work. I did it in this thread here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=695496
if you'd rather not do it that way, I understand
Jake Raby wrote:
Brian wrote:
PostPosted: Wed Mar 07, 2018 10:40 pm    Post subject: Re: can't edit posts? Reply with quote
I'd rather not as they might break that later
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Mar 08, 2018 6:30 am    Post subject: Re: can't edit posts? Reply with quote
fair enough. I just wanted to see what order the photos were in rather than try and match up the code.
Jake Raby wrote:
Brian wrote:
PostPosted: Fri Mar 09, 2018 9:58 pm    Post subject: Re: can't edit posts? Reply with quote
Do you mean you wanted to edit it to see the text you used in the original post?
Tip: You can hit "quote" on it and see the original text.
This gives you a screen to post a new message to the thread so obviously don't "Submit" that screen unless you want to add another post.
You can use "Preview" on the quoted post if you want to test out changes without submitting it.
Reply to topic    Forum Index -> Site All times are Mountain Standard Time/Pacific Daylight Savings Time
