Empi center caps
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
losinground
losinground is offline
PostPosted: Wed Mar 07, 2018 7:22 pm    Post subject: Empi center caps Reply with quote
Has anyone used these Empi center caps on stock wheels? They are a tad larger than the stock wheel cutout, how did you get them to fit, cut, dent?
hitest
hitest is offline
PostPosted: Thu Apr 26, 2018 6:25 pm    Post subject: Re: Empi center caps Reply with quote
You'll have to carefully punch in indentations around each lug nut- a crescent-shaped kink X 20 to clear each lug flange. I've seen this done with what was likely heat; a mallet and temper and a buzz.
Or you can notch out and remove the amount of metal needed to clear the lug bolt flanges- again a notch times twenty unfortunately.
'62 L390 151, '62 L469 117, '63 L380 113, '65 L512 265, '65 L31 SO-42, '66 L360 251, '71 L12 113, '74 L65K Love Bug SE, '74 ORG 181
FU#5
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
