mas00 Samba Member
Joined: February 08, 2016 Posts: 183 Location: Los Angeles/Texas
Posted: Thu Mar 08, 2018 10:32 am Post subject: braided cloth vs rubber fuel line? |
I've search the forums here and just wanted some additional weight in from experience as I'm about to replace the fuel lines in my 1600 61 bug. Which fuel line is best to replace - rubber or braided cloth? I know that the lines need to be rated for the 10% ethanol and it's about 5ft give or take to do the whole car, but which is better for Texas weather which is dry humidity in the summer coming up and good rain fall.
Also correct me if I'm wrong but the size is a 5mm? I just called auto zone and they gave me 3/16, 1/4 and 5/16 sizing.
Thanks
Mas |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Thu Mar 08, 2018 1:23 pm Post subject: Re: braided cloth vs rubber fuel line? |
Not 100% sure on size, but the fuel tubing on my 65 beetle looks about 5mm. I ordered some 'braided German' fuel hose online and it was junk within a year (of daily driving). All fuel line is braided.. the smooth stuff just looks newer because the braid is covered with rubber. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Thu Mar 08, 2018 1:30 pm Post subject: Re: braided cloth vs rubber fuel line? |
Stock cloth has been fine with somewhere over 400,000 miles of driving ACVWs between us.
Did three years in the USAF in Texas and plenty of ethanol fuel over the years here in the PNW way before it became standard issue at the pumps.
Just got to replace flex fuel lines every two to three years depending on how much you drive it. _________________ In Stereo, Where Available! |
Bob Loblaw Samba Member
Joined: August 17, 2008 Posts: 865 Location: Vancouver Island, Canada
Posted: Thu Mar 08, 2018 1:34 pm Post subject: Re: braided cloth vs rubber fuel line? |
mas00 wrote: |
Mas |
You're not wrong. It is 5mm. Auto Zone just has shitty listings. _________________ sent from a phone using poor grammar and spelling |
mas00 Samba Member
Posted: Thu Mar 08, 2018 3:38 pm Post subject: Re: braided cloth vs rubber fuel line? |
thanks for the replies. |
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 679 Location: SE Oklahoma
Posted: Thu Mar 08, 2018 8:06 pm Post subject: Re: braided cloth vs rubber fuel line? |
I used to only buy the German braided hose. It has the “Chinese finger trap” feature that helps it to grab onto the metal fittings on the carb and fuel pump, etc.. Unfortunately that hose never evolved to cope with modern, ethanol-laced fuels. So I’ve had to look elsewhere. I found these two high quality fuel hoses:
https://www.belmetric.com/multifuel-hoseethanol-ap...0ik8qnftp7
http://www.volksbolts.com/FuelHose/index.htm
The belmetric hose is more pliable but the volksbolt hose has a better fit being 5.6 mm
Hope this helps _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Thu Mar 08, 2018 9:45 pm Post subject: Re: braided cloth vs rubber fuel line? |
Get rubber fuel Line rated for fuel injection use. |
Volktales Samba Member
Joined: June 21, 2013 Posts: 545 Location: Nanaimo, B.C. CANADA
Posted: Thu Mar 08, 2018 10:39 pm Post subject: Re: braided cloth vs rubber fuel line? |
I have used some "German" braided fuel line that has lasted for a very long time. I also used some on a project recently that failed after one season of use. This was Continental branded made in Germany hose as well. It just seems quality is extremely variable these days. My last project used Gates Barricade, and I really hope it is going to last. I would rather use the braided hose for its original appearance, but it seems you just cannot trust it anymore... _________________ 1974 "Restfalia" Camper 2000 cc EFI 2001-
1970 Beetle first car, rotten, yard art 1985-
1966 Sunroof Beetle, restored 1998-
1964 Ghia, ongoing project 2007-
1962 Beetle Beryl,original paint survivor 2012-
1970 Savannah Beige Beetle 2012-
1992 16v GTI, 100% stock 2006-
1991 "Terseo", wife's old daily 1995-
1969 Chevrolet CST/10 (family owned since new)
1965 Gold Corvair Monza 2021-
1966 and 1965 Monza 2022- |
glutamodo The Android
Joined: July 13, 2004 Posts: 26309 Location: Douglas, WY
Posted: Fri Mar 09, 2018 5:12 am Post subject: Re: braided cloth vs rubber fuel line? |
I started to lose my love for stock braided cloth hose many years ago when I examined some used hose that was cracking for the outside-in!
_________________ Andy T.
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Fri Mar 09, 2018 9:22 am Post subject: Re: braided cloth vs rubber fuel line? |
I never have a problem with braided hose.
I also never put ethanol fuel in my VWs unless it's on a road trip. _________________
EverettB wrote: |
FU#5 |
Jody '71 Samba Member
Joined: July 16, 2005 Posts: 2842 Location: Manassas VA
Posted: Fri Mar 09, 2018 9:39 am Post subject: Re: braided cloth vs rubber fuel line? |
I have plenty of Bellmetric 5mm ID fuel line but it's way too tight. Go with 5.5mm ID diameter and use the proper clamps. _________________ '66 Beetle
2011 Hyundai Elantra Touring |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11055 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Mar 09, 2018 11:58 am Post subject: Re: braided cloth vs rubber fuel line? |
I will NOT use the cloth covered fire hose..
Much better fuel line has been developed since 1938.... and is easily available at most FLAPS..
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
bluebus86 Banned
Posted: Sun Mar 11, 2018 9:35 am Post subject: Re: braided cloth vs rubber fuel line? |
SAE rated hose, 30R9 specification is lined to resist todays fuel. liner inside is a teflon like material. the mandated oxygenated fuels will not harm it.
1/4 inch is a bit big, but will work fine with proper hose clamps. used the solid band type, not the serrated type. serrated type will allow the rubber hose to extrude thru the holes, loosening the clamp.
Also see safety wire information on link below this post.
Good Luck, Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
vwgirl1961a Samba Member
Posted: Mon Nov 12, 2018 8:01 am Post subject: Re: braided cloth vs rubber fuel line? |
What happens if the hose is too tight? I know the one I have on mine is hard to take off every time I change the fuel filter. I don't know the size of the hose but it is the cloth braided one
Jody '71 wrote: |
I have plenty of Bellmetric 5mm ID fuel line but it's way too tight. Go with 5.5mm ID diameter and use the proper clamps. |
_________________ "Age doesn't really matter unless you are a cheese". |
bluebus86 Banned
Posted: Mon Nov 12, 2018 8:12 am Post subject: Re: braided cloth vs rubber fuel line? |
vwgirl1961a wrote: |
Jody '71 wrote: |
if too tight, removal can loosen the fittings the hose is attached to. see link below on engine fires and safety wire, then you will know the end result of loosened fittings.
Posted: Mon Nov 12, 2018 8:21 am Post subject: Re: braided cloth vs rubber fuel line? |
Maybe this is why the end the attaches to the carb is wet with fuel? My carb is an aftermarket one and someone said the float in it may be stuck which is causing the problem. I am taking my car to my mechanic hopefully this morning. Thanks
bluebus86 wrote: |
Jody '71 wrote: |
Bug On! |
Posted: Mon Nov 12, 2018 8:52 am Post subject: Re: braided cloth vs rubber fuel line? |
What happens if the hose is too tight? I know the one I have on mine is hard to take off every time I change the fuel filter. I don't know the size of the hose but it is the cloth braided one. |
You want it tight, or it is just going to fall off. The German fuel line is designed to tighten when pulled just like Chinese Finger Cuffs. So just like CFCs one pushes the ends of of the fuel line to get it to loosen and slide off. A flat tip screwdriver works well for this. Otherwise slice the end open and cut off a chunk of fuel line each time or just replace the length.
You do want hose clamps on the line between the fuel pump and carb. VW issued a tech bulletin about this to avoid having the line come loose from the pressure between those two points. _________________ In Stereo, Where Available!
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Mon Nov 12, 2018 9:37 am Post subject: Re: braided cloth vs rubber fuel line? |
Eric&Barb wrote: |
You want it tight, or it is just going to fall off. The German fuel line is designed to tighten when pulled just like Chinese Finger Cuffs. So just like CFCs one pushes the ends of of the fuel line to get it to loosen and slide off. A flat tip screwdriver works well for this. Otherwise slice the end open and cut fuel line each time.
You do want hose clamps on the line between the fuel pump and carb. VW issued a tech bulletin about this to avoid having the line come loose from the pressure between those two points. |
THANK YOU! Nice to know someone else knows about this bulletin besides me. |
Posted: Mon Nov 12, 2018 11:08 am Post subject: Re: braided cloth vs rubber fuel line? |
Helfen wrote: |
You are welcome! Tried to find it this morn, but have so much packed away due to our years on going house rebuild. It is actually a Workshop Bulletin, not Technical. _________________ In Stereo, Where Available! |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Tue Nov 13, 2018 5:00 am Post subject: Re: braided cloth vs rubber fuel line? |
When I change the hose I make it longer by a few inches. Then, when I need to change a filter or whatever I can just cut it off. I make a lengthwise cut with a razor knife at the end of the hose near the filter ,then cut that portion of hose off. I use wire cutters , which make a clean cut. When reinstalling I dip the end of the hose in boiling water for about 30 seconds or so before pushing it on. It expands the rubber so you won't have to struggle getting it back on. Still using the braided stuff. |
