Balmoral1958 Samba Member
Posted: Thu Mar 08, 2018 4:24 pm Post subject: 1977 engine bay wiring question |
Have a '77 Bay Window. Was originally FI but PO removed it.
Now has dual Webers.
Wanted to confirm that if I use the B side of the double relay it should work.
Yes - will clean up the wires.
I will then install the fuel safety relay.
_________________ 2x 1974 Karmann Ghia Coup
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa |
busdaddy Samba Member
Posted: Thu Mar 08, 2018 4:49 pm Post subject: Re: 1977 engine bay wiring question |
Balmoral1958 wrote: |
.......Wanted to confirm that if I use the B side of the double relay it should work. |
Work for what exactly? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Mar 08, 2018 5:21 pm Post subject: Re: 1977 engine bay wiring question |
for the engine starting system _________________ 2x 1974 Karmann Ghia Coup
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa |
Posted: Thu Mar 08, 2018 5:34 pm Post subject: Re: 1977 engine bay wiring question |
What's it going to do that your ignition switch won't? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Mar 09, 2018 3:34 am Post subject: Re: 1977 engine bay wiring question |
running a low pressure pump to carbs -should be real simple.
That double relay will depend on a signal from the air box of the FI.-- If you hook that up it will need a source of power after cranking.---In that case, you might as well just put in a straight connection to the pump, or a generic relay to lower the load on the ignition switch. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Fri Mar 09, 2018 7:10 am Post subject: Re: 1977 engine bay wiring question |
I do not have the EFI connected. I just wanted to confirm the wiring to connect the double relay to the starter etc. so I can get it running. Then fit the fuel pump cut-off relay - or does the double relay cut-off fuel to the fuel pump if the engine stalls but the ignition is not cut off? _________________ 2x 1974 Karmann Ghia Coup
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa |
Posted: Fri Mar 09, 2018 8:01 am Post subject: Re: 1977 engine bay wiring question |
The double relay doesn't effect the starter or ignition circuit in any way, it gets signals from each of those to control functions of the FI but for carbs no part of it is needed. To run an electric fuel pump for carbs you will need something like this: http://vwparts.aircooled.net/Electric-Fuel-Pump-Relay-321-906-059C-p/321-906-059c.htm , carbs can't provide the signal your existing relay is looking for to turn on the pump. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Mar 09, 2018 9:30 am Post subject: Re: 1977 engine bay wiring question |
Thanks... _________________ 2x 1974 Karmann Ghia Coup
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Fri Mar 09, 2018 10:22 am Post subject: Re: 1977 engine bay wiring question |
The double relay can be used as a regular relay. I'd limit any connected load to maybe 5 amps.
Pinout:
_________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Fri Mar 09, 2018 11:12 am Post subject: Re: 1977 engine bay wiring question |
telford dorr wrote: |
Pinout:
now THIS is a schematic! This is nice for the beginner to see what things are actually hooked to, vs a key referencing a number to a part. |
Posted: Fri Mar 09, 2018 11:18 am Post subject: Re: 1977 engine bay wiring question |
Thanks - this great... so if I use the non-FI connections this will be the right connections to the starter , battery, fuel pump (I'm using the electric low pressure type) etc. _________________ 2x 1974 Karmann Ghia Coup
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa |
tommu Samba Member
Posted: Fri Mar 09, 2018 11:44 am Post subject: Re: 1977 engine bay wiring question |
alman72 wrote: |
Pinout:
Here's the source for credit, thread posterity and some more fun schematics.
http://itinerant-air-cooled.com/viewtopic.php?t=54...highlight= _________________ |
Posted: Fri Mar 09, 2018 1:46 pm Post subject: Re: 1977 engine bay wiring question |
You can use the double relay socket to power the fuel pump and other stuff in the engine bay if you want.
The relay that BD mentions uses a signal from the #1 ignition circuit to know if the engine is running or not. |
Posted: Fri Mar 09, 2018 4:07 pm Post subject: Re: 1977 engine bay wiring question |
Thanks - this great... so if I use the non-FI connections this will be the right connections to the starter , battery, fuel pump (I'm using the electric low pressure type) etc. |
Sure, but the fuel pump will only run when cranking the starter, the component that tells the double relay the engine is running is missing since you don't have an air flow meter anymore. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
airschooled Air-Schooled
Posted: Fri Mar 09, 2018 4:49 pm Post subject: Re: 1977 engine bay wiring question |
busdaddy wrote: |
Sure, but the fuel pump will only run when cranking the starter, the component that tells the double relay the engine is running is missing since you don't have an air flow meter anymore. |
The alternator idiot light circuit should be used instead of the starter #50 to trigger the relay- carbs don’t need a fuel pump during cranking but they sure do when running. (This way will require a jumper wire to prime the carbs if they sit for a few months like during winter storage.)
www.airschooled.com |
Posted: Fri Mar 09, 2018 5:03 pm Post subject: Re: 1977 engine bay wiring question |
asiab3 wrote: |
busdaddy wrote: |
Robbie |
I agree, but I get the impression Balmoral figures if he just connects his pump to the DR it's going to magically work after cranking even with the AFM out of the picture.
Thinking about it he could connect the blue charge light wire to 86b and get a similar result, the only potential issue may be a backfeed when you turn off the key that keeps it running, a diode would solve that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Mar 09, 2018 6:47 pm Post subject: Re: 1977 engine bay wiring question |
Update
It starts and runs using the “engine” side of the dual relay.
I have ordered the relay kit from Germansupply that has the fuel pump shutoff.
Thanks for the help! _________________ 2x 1974 Karmann Ghia Coup
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa |
Posted: Mon Mar 12, 2018 2:08 pm Post subject: Re: 1977 engine bay wiring question |
OK - so trying to install the fuel safety relay below.
Where does the red/white stripe wire from the start motor attach ?
per the Bentley its 88d - do I need it ? _________________ 2x 1974 Karmann Ghia Coup
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa |
Posted: Mon Mar 12, 2018 2:40 pm Post subject: Re: 1977 engine bay wiring question |
per the Bentley its 88d - do I need it ? |
Is there any reason you would need input from the starter motor? By the time the engine has turned a half revolution the relay should get the signal to close. |
Posted: Mon Mar 12, 2018 3:30 pm Post subject: Re: 1977 engine bay wiring question |
Thanks - it appears that I don't need that for my carburetor setup = its only need for the FI circuit. _________________ 2x 1974 Karmann Ghia Coup
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa |
