crewcab1964 Samba Member
Posted: Thu Mar 08, 2018 11:23 pm Post subject: Cold start valve, what is the difference between the revisions? |
I have a 1970 Squareback and has a 311906171A, can a 311906171B be used instead? |
KTPhil Samba Member
Posted: Fri Mar 09, 2018 12:34 pm Post subject: Re: Cold start valve, what is the difference between the revisions? |
Where do you live? I ask because unless you are often starting near zero degrees, the cold start valve is not in operation regardless of the part number, so it may not matter anyway. |
Bobnotch Samba Member
Posted: Fri Mar 09, 2018 1:55 pm Post subject: Re: Cold start valve, what is the difference between the revisions? |
KTPhil wrote: |
Yeah, I think the CSV comes into play between 36 and 40 degrees. Above 40, it doesn't work by design. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KTPhil Samba Member
Posted: Fri Mar 09, 2018 1:58 pm Post subject: Re: Cold start valve, what is the difference between the revisions? |
I think I read somewhere here that the change was in operating temperature. One was near 32F, the other was much lower, maybe 10-12F.
Also, it only works during cranking, not during running.
So you can appreciate that there are rare instances where it ever worked at all! |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Fri Mar 09, 2018 9:11 pm Post subject: Re: Cold start valve, what is the difference between the revisions? |
KTPhil wrote: |
Operating temperature change would be controlled by the thermo time switch.
I've never had any issues subbing a B for an A. IIRC the difference may have had to do with emissions. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat Mar 10, 2018 10:03 am Post subject: Re: Cold start valve, what is the difference between the revisions? |
Thank you for all the response. I have only had issues with starting the vehicle near freezing temperatures and will run into a few instances where the vehicle would flood. I was reading through a troubleshooting guide and it mentioned flooding can be caused by a leaking cold start valve. |
Posted: Sat Mar 10, 2018 11:20 am Post subject: Re: Cold start valve, what is the difference between the revisions? |
crewcab1964 wrote: |
One of the reasons I disable it. My old 71 Notch would start up in 20 degree weather with the CSV being disabled. No problem. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KTPhil Samba Member
Posted: Sat Mar 10, 2018 11:35 am Post subject: Re: Cold start valve, what is the difference between the revisions? |
Actually, I took his question to be about the thermo-time switch, not the jet, but I see it wasn't, sorry!
The reports of flooding came from two causes... a leaky injector that either bled down after shutoff, or dripped when it should be closed. Or it could be forced on by putting the wire on the solenoid on the wrong contact.
Your '70 has the middle-vintage TVS that added the ten "access pump" firings as you press the throttle. So you can use this like a cold start valve when it's really cold by pumping the throttle during cranking, or even turning the key on, flooring it, letting up, then moving the key to start. This will give extra gas during the first rotations.
So I really think you can do without the CSV setup, unless you are stationed in Point Barrow or similar. |
Posted: Sat Mar 10, 2018 3:08 pm Post subject: Re: Cold start valve, what is the difference between the revisions? |
Actually, the whole cold start system thing has way more to do with 1960s/ early 70s battery and lubricant technology than actual temperature. Remember, the original A/B systems had cold start as an option
When the temperature gets really cold, the old paraffin based motor oils got the consistency of molasses, and batteries of that era would lose 50% plus of their cold cranking capacity. Lots of people ran single weight oils in those days too.
When you were at 0 degrees with sludgy oil and a diminished capacity battery, your FI car wouldn't start because there wasn't enough juice for the FI system, so VW developed the cold start system as a band- aid. A shot of gas got the engine- and generator- spinning so that the FI would kick in.
With today's modern motor oils and better batteries you really shouldn't need the CSV system at all as actual enrichment is done via the temp sensors and the AAR compensates for the cold enrichment. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Mon Mar 12, 2018 2:21 pm Post subject: Re: Cold start valve, what is the difference between the revisions? |
Yep. Mine is disconnected, but it starts in single digit temperatures. _________________ 71 Elm Green FI A/T Squareback |
Posted: Wed Mar 14, 2018 10:15 am Post subject: Re: Cold start valve, what is the difference between the revisions? |
Good to know that the cold start valve is not that critical. I have a new one coming. in the future, disconnecting the valve could be an option. |
KTPhil Samba Member
Posted: Wed Mar 14, 2018 8:44 pm Post subject: Re: Cold start valve, what is the difference between the revisions? |
Found a reference for the operating temps:
This is for the sensor, not the jet.
It remains to determine if the difference in the jet part number matters. I haven't found any cross references or tables to distinguish them. |
