Below Windshield Rust Repair
Stevenb83
Stevenb83 is offline
PostPosted: Fri Mar 09, 2018 1:06 pm    Post subject: Below Windshield Rust Repair Reply with quote
I just picked up a bay window with some awesome patina to it. The only rust that will effect anything is the usual rust below the front windshield. Thereís some decent holes, is there any creative ways to cover and seal this up without cutting out and welding back in a new piece? I want to keep the patina for a while and donít want to start doing a lot of metal work just yet.
Spike0180
Spike0180 is offline
PostPosted: Fri Mar 09, 2018 1:31 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
If you're going to take out the window (which you'll have to do to replace the seal that needs replaced of this will only get worse), then you mine as well weld in a new piece now. Because besides cutting an welding your options are: rivet in a cover piece, fiber glass, or leave it. maybe you could like tuck some plastic under the seal and then put the window back in and tape it down? overall, they are all poor choices. Just order the part from KF and weld in that new piece but don't paint it yet. you'll keep the "I'm saving patina" look.
Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic"
OB Bus
OB Bus is offline
PostPosted: Fri Mar 09, 2018 1:56 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
I did some creative patching in the same area with fiberglass tape and POR-15. (I don't weld.) However I only had about 2% of your visible rust holes. You have to deal with this now or face much worse damage really soon.
Larry in OB
The Great Deal Maker cannot make a deal and he pays off porn stars. But you love him.
69 Westfalia and 2002 Eurovan Camper. Yes, the dark side. 67 Single Cab is off to Arizona.
Stevenb83
PostPosted: Fri Mar 09, 2018 3:58 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
I might end up just having to go ahead and patch it and and get creative with some paint to try and keep the patina look. Was just hoping someone had come up with a way to avoid all the extra work, since this is a common bay problem.
KentPS Premium Member
KentPS is online now
PostPosted: Fri Mar 09, 2018 7:04 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
I'm with you on that wishful thought for a simple windshield fix. I deliberately leave mine in the garage during rainy days to help delay the inevitable. But it appears the only fix is to weld in a new piece. Fiberglass sounds like it would be a great interim step, but it fails over time.
If you find an easy alternative, you will be a hero to hundreds of Bay Window owners!
-Kent-
1976 Riviera, my 1.8l FI chrome yellow VAN - "Chloe"
My top favorite Samba quote:
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's.... like driving a celebration!"
-WildIdea
Yarkle Premium Member
Yarkle is offline
PostPosted: Fri Mar 09, 2018 7:41 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
EIS is selling a similar repair panel to klassicfab..anyone have any experience with it?
https://www.eisparts.com/winshield-lower-repair-section-bus-1968-1979new.html
1973 VW Bus [o____o] "the Thing" thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=8272498#8272498 1.7 914? engine with weber progressive clone (soon to be 72 dual carb setup)
1969 VW Bus deluxe 221 -belongs to the boy
"Weld Busler" Bus rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=630499 1600SP
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Mar 09, 2018 7:47 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
Yarkle is offline
PostPosted: Fri Mar 09, 2018 8:06 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
duct tape got me out of here! i dont get pictograms very well, but i think you are saying that the EIS piece is basically duct tape?
but, due to that experience , i dotn get pictograms very well:
so you are saying the EIS one is a waste of money? [/url]
Mr. 010
Glenn is offline
PostPosted: Fri Mar 09, 2018 8:16 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
No I meant to use duct tape to cover the rust and keep the rain out.
Glenn
Yarkle is offline
PostPosted: Fri Mar 09, 2018 8:18 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
Ah..Ok, got it. several vendors are selling the grey EIS one now, so i figured someone here may have bought one.
Mr. 010
Glenn is offline
PostPosted: Fri Mar 09, 2018 8:34 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
When there's holes, it's no longer patina... it's RUST/ROT.
Glenn
Mr. 010
Glenn is offline
PostPosted: Fri Mar 09, 2018 8:35 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
Then what is this in your signature?
[o____o]
Glenn
williamM
williamM is offline
PostPosted: Sat Mar 10, 2018 6:34 am    Post subject: Re: Below Windshield Rust Repair Reply with quote
[img]
The green panels need a LOT of custom fitting. The corners were the worst. [/img]
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Abscate Premium Member
Abscate is offline
PostPosted: Sat Mar 10, 2018 11:08 am    Post subject: Re: Below Windshield Rust Repair Reply with quote
Itís awesome rust/rot.
Stop trying to make Ďpatinaí happen Karin, itís going to die, like Ďfetchí
.ssS!
dirtkeeper
dirtkeeper is offline
PostPosted: Sat Mar 10, 2018 11:25 am    Post subject: Re: Below Windshield Rust Repair Reply with quote
as mentioned you have some substantial rot there. That said i have made temporary repairs (last a few years) in those areas of a bug, i used high quality metal tape as used in the heating and air conditioning business. sticks well, thin, can be built up stronger with a few layers, can be painted and massaged flat and smooth. I had a picture of this but cant find it now. Must clean the surface very well first. can even be slipped under the rubber, I have made permanent repairs to smaller rotted areas using fiberglass bondo. Has lots of fibers in it to grab and stick around the damage dries hard and sandable. For a permanent fix you would need to make sure all rust is removed, or treated and sealed, difficult unless you can get in and observe the inner side of the panel..
Yarkle is offline
PostPosted: Sat Mar 10, 2018 2:12 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
[o____o]
Its my bus!
Pictograms i doodle make perfect sense to me, its just ones from other people that i have trouble deciphering.
I wonder why there are so many mixed reviews on the green panels, could it be that buses over the years have just deformed a bit? Im leery of EIS in general, especially when the price is well over a hundred bucks cheaper.
Miklo
°Chale!
Miklo is offline
PostPosted: Sat Mar 10, 2018 3:30 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
Iíve been wondering the same question...
My project 70 lower windshield looks very similar. Rusted/rotted out.
Iíll mention as well, windshield leaks run all over the fusebox killing the relays... ask me how I know.
What I found... Check out the relays in the bottom picture.
Antelope Valley Air-Coolers
'55 Type1 "Ozma"
'70 Type2 "Hannah"
'66 Type1 "Charlotte" RIP
OG over Aftermarket!
Dr OnHolliday wrote:
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche...
Stevenb83
PostPosted: Sat Mar 10, 2018 3:40 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
Dang! Mine doesnít have any of the fuse block or relays, Iíve got to buy new, probably got pulled out because they were like yours
Alan Brase
Alan Brase is offline
PostPosted: Sat Mar 10, 2018 10:35 pm    Post subject: Re: Below Windshield Rust Repair Reply with quote
Generally, if you bought KF panels directly and had trouble fitting them, he would take some action, make it better just to improve the product.
I recently bought the UK made part from Bus Depot, and it is so bad one almost wonders if it was for a different window! But this vehicle is not too badly rusted, so, I'm just gonna make this into patches. Plus, I bought a shrinker/ stretcher, gotta set it up and learn!
Auto Craft may be better yet. Never tried them. I was so pleased when Gerson came on to the scene, I'll tolerate a little, I guess!
Al
Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home
Yarkle is offline
PostPosted: Sun Mar 11, 2018 5:59 am    Post subject: Re: Below Windshield Rust Repair Reply with quote
was the busdepot one the little metal strip one or the one similar to the EIs one i linked (kinda looks like the klassicfab, but grey?)
