15" rims, all terrain tires, offsets, back spacing...Lord
MConstable
MConstable is offline
PostPosted: Fri Mar 09, 2018 3:42 pm    Post subject: 15" rims, all terrain tires, offsets, back spacing...Lord Reply with quote
Ok...I've read a ton of the wheel/tire threads, will it fit, etc.
Here's my dilemma, it only really applies to the fronts.
I am running all terrain tires with aftermarket Baja style wheels, 205/75/15 tires on the front, which are the skinniest all terrain tires I could find.
With the offset/backspacing on my wheels (and all aftermarket wheels I have researched) the tires stick out just enough to rock chip the crap out of the side of my Thing.
I don't like the looks of wider front fenders, but is that my only option?
I appreciate any thoughts
1974 Thing
[email protected]
waugamans@aol.com is offline
PostPosted: Sat Mar 10, 2018 8:12 pm    Post subject: Re: 15" rims, all terrain tires, offsets, back spacing...Lord Reply with quote
How about adding some mud flaps?
MConstable
PostPosted: Sun Mar 11, 2018 7:09 am    Post subject: Re: 15" rims, all terrain tires, offsets, back spacing...Lord Reply with quote
i e got ‘em on
1974 Thing
doublecanister
doublecanister is offline
PostPosted: Mon Mar 12, 2018 10:35 am    Post subject: Re: 15" rims, all terrain tires, offsets, back spacing...Lord Reply with quote
I don't have them on mine, but I've heard the running boards also double as rock guards.
I too get rock chips on mine, but on the front of the rear fenders, I need to look at some mud flaps myself. (or running boards).
Also, are the current mud flaps wide enough?
I bought some big truck mudflaps from my work and made a towing guard flap for tow-barring my thing.
Idea Wonder if the same type material could make you some extra wide flaps? That thick rubber is hard to cut but it may could work...
Just thinkin'
T
73'- Thing
66' -Mustang GT- Fastback
51'- Ford F1 pickup Flathead V8
Captain Spalding
Captain Spalding is offline
PostPosted: Mon Mar 12, 2018 12:54 pm    Post subject: Re: 15" rims, all terrain tires, offsets, back spacing...Lord Reply with quote
Out of curiosity, what is the backspace on your wheels? How about the width? Do the tires protrude beyond the edge of the fenders?
When you say Baja style wheels do you mean these?
By the way, when we discuss wheel width relating to old vee-dubs, we're talking about the width between the bead seats - "nominal width" on the drawing below.
MConstable
PostPosted: Wed Mar 14, 2018 3:27 am    Post subject: Re: 15" rims, all terrain tires, offsets, back spacing...Lord Reply with quote
Those are my rims, fronts are 6" wide with 3 1/4" backspace which puts my 205/75/15 front tires just at the edge of the fender.
The wheels I want to run have the same backspacing.
That being said, I found out 5.5" BRM five spokes have 4" plus backspacing on their rims so I might go that route.
Thanks for the help guys
1974 Thing
