56 manx Samba Member
Joined: August 22, 2008 Posts: 224 Location: central Il.
Posted: Fri Mar 09, 2018 7:32 pm Post subject: Steering Wheel Kits [splines] |
I have an average 11in. 3 bolt 3 spoke steering wheel on my buggy the brand name as far as I can tell is [the 500] and the piece that fits on the back of the wheel has damaged splines and it looks like I need to replace pretty much everything but the wheel.
I've been told that there are replacement kits that will fit most of these [black 3 spoke] wheels that also have the center caps and the horn mechanisms as well.
But I'm not finding them at any stores.
Does anyone out there know what I'm looking for?
If so, where can I find them.
I like my steering wheel and I'd hate to have to replace it. |
slalombuggy Samba Member
Dale M. Samba Member
Posted: Fri Mar 09, 2018 9:57 pm Post subject: Re: Steering Wheel Kits [splines] |
Look up GRANT wheels, When I did my restoration I found Grand adapter and wheels at FLAPS, but alas they no longer have them, look online and get out of tunnel vision mode that it has to be from a VW parts store.... Try Summit, JEGS, Grant products...
http://www.grantproducts.com/products/browse/installation-kits/
Posted: Fri Mar 09, 2018 10:07 pm Post subject: Re: Steering Wheel Kits [splines] |
slalombuggy,
Thanks for the rapid reply and links. CIP1.ca is one of the stores I didn't look at and I didn't know that what I was looking for was considered an adapter.
I don't know much about steering wheels [still learning] and I never thought about the steering column year being an issue, I thought they were pretty much all the same. I should have known there was different ones.
Anyway the second one of the links looks to be the one that will do the job. My donor is a '56. I'll have the local VW mechanic look and make sure what I have.
Thanks |
Posted: Fri Mar 09, 2018 10:19 pm Post subject: Re: Steering Wheel Kits [splines] |
Dale M.
Thanks for the reply.
Summit was the first place I looked. I didn't see what I was looking for but I kept seeing those Grant wheels. The pics didn't show if everythjing I needed came with the wheels or not though.
My steering wheel isn't a grant so I hope their adapter kit will work with my 'the 500'.
If worst came to worst I was going to try and find out more about the 11 1/2'' Grant from Summit.
Thanks again, this isn't the first time you've given me info throughout the years. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Mar 10, 2018 9:28 am Post subject: Re: Steering Wheel Kits [splines] |
I think the 500 wheel might have been made by Superior Industries. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Sat Mar 10, 2018 12:32 pm Post subject: Re: Steering Wheel Kits [splines] |
Oval window steering column splines look like this.
58-67 steering column splines look like this
Over9K Samba Member
Joined: February 22, 2018 Posts: 14 Location: The Dragon
Posted: Sat Mar 10, 2018 1:43 pm Post subject: Re: Steering Wheel Kits [splines] |
This is weird... this thread reminded me of this exchange I read, while shopping for the steering wheel adapter for my buggy...
Note that the seller claims the Grant Adapter won't work with the Superior steering wheel.
This exchange can be found on the Amazon entry for the Grant Adapter for 58-67 columns, which I purchased to install a nice wood-rimmed Grant.
https://www.amazon.com/gp/product/B000CMH3J2/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1 |
jsturtlebuggy Samba Member
Posted: Sat Mar 10, 2018 6:57 pm Post subject: Re: Steering Wheel Kits [splines] |
Most all steering wheels whether they are Grant, Superior 500, Mooneyes, Speedway Motors, and other use the same 3 bolt pattern to bolt to a steering wheel adapter.
I used, installed the above mention brands and other off brands steering wheels and found all had the same 3 bolt pattern.
Any parts place that carries Empi parts should have or be able to get you a adapter as they show all 3 steering shaft spline sizes in their catalog. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
ev88f Samba Member
Joined: April 07, 2008 Posts: 139 Location: North Port FL
Posted: Fri Apr 27, 2018 11:35 am Post subject: Re: Steering Wheel Kits [splines] |
Same 3 bolt pattern. They fit. |
