72 Bay dash help
Karzapart55
Karzapart55 is offline
PostPosted: Sat Mar 10, 2018 12:38 am    Post subject: 72 Bay dash help Reply with quote
anyone have a pic of rear of dash cluster with bulb diagram designations? thanks
Central Jersey Volkswagen Socity
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Mar 10, 2018 6:59 am    Post subject: Re: 72 Bay dash help Reply with quote
it's pretty easy to figure out. have you looked at the tech section here and followed the wiring diagrams?
hold the cluster to a light and you'll see what lives where or use a flashlight behind the cluster.
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Karzapart55
PostPosted: Sat Mar 10, 2018 7:17 am    Post subject: Re: 72 Bay dash help Reply with quote
Have the cluster out. Currently rewriting entire Bu using a generic harness with blade fuses. My blinkers never worked before. It look like both indicators flash at the same time regardless of lever position. Is that right?
alman72
alman72 is offline
PostPosted: Sat Mar 10, 2018 7:23 am    Post subject: Re: 72 Bay dash help Reply with quote
correct
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Mar 10, 2018 7:55 am    Post subject: Re: 72 Bay dash help Reply with quote
barf....
yes, they flash at the same time. I have worked on 1 bus with a harness like you speak of and it was a PITA to map everything out.
can I ask why a generic harness? a reworked OE harness works fine. in cases like this sometimes new doesn't mean better and can introduce a whole lot of headache
Jake Raby wrote:
Brian wrote:
Karzapart55
PostPosted: Sat Mar 10, 2018 11:53 pm    Post subject: Re: 72 Bay dash help Reply with quote
Wiring was an abortion. VW harness was too expensive (retired) I reworked everything-every switch. Harness came with 14 circuits and blade type fuses. Cost 89$. Plus about 15$ in term. And heat shrink. Should be done tomorrow and no more gremlins!
