pyrOman Fire Master
Joined: July 21, 2003 Posts: 12406 Location: Over 2002 posts deleted!
Posted: Mon Nov 28, 2005 10:55 am Post subject: Plump Truck & the Gutless Wonder |
No, I'm not lost or just stumbled into the fatchick forum by mistake.
I got a '68 truck now and if you didn't do the shindig at Andy's house the day before the Yuma show, then you missed the "ceremony" of my induction into fatchickdom.
Anyway, this fatchick needs a lot of work. I've got it almost road worthy except for the turn signals. It is totally missing the perenial emergency flasher unit, the one where all the wires go from the turn signal switch. I've called a couple of places and they don't even list it!?!
I used the "search" button and got 635 hits including some "relay" race of some sort. So, do I HAVE TO get the correct relay or can I modify some contraption, or replace the turn signal switch with a later than '68 one which doesn't require such a relay box???
I really need to get this truck running "legal" as far as the lights is concerned. _________________ Some people are so busy being clever they don't have time enough to be wise. |
pyrOman Fire Master
Posted: Mon Nov 28, 2005 11:01 am Post subject: |
Ooops! Forgot to post a pix:
Here's what I had to begin with!
djdh68dlux Samba Member
Joined: February 24, 2005 Posts: 770 Location: I.E., SoCal
Posted: Mon Nov 28, 2005 11:20 am Post subject: |
If you need the infamous "black box" flasher, nobody makes an exact replacement anymore. Wolfsburg West makes this one, which is the closest replacement for it. I put one in my own 68 and its worked great so far (about 1 year). As for the turn signatl switch, you'd have to find a used one for the 68. Not sure if you can convert it to a later setup or not. Someone else have any experience with that?
Anyways, here's the link for the flasher:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211953227BWW _________________ 1968 Deluxe "Clipper L" Type 2
Looking for a VW club in Southern California? Check out Inland Valley Volkswagens: www.ivvw.org |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4520 Location: Oklahoma City, OK
Posted: Mon Nov 28, 2005 12:42 pm Post subject: |
Convert the rear light assembly to a European(?) two bulb system giving you a separate turn signal light. Pick up a 69 or 70 turn signal switch, convert the flasher relay to a two prong standard flasher. If you want Emergency flashers (I did away with mine) you will need a separate switch (a SP/ST toggle switch will work) tied across a two pole relay.
Yep, it isn't original, but it works and does away with a complicated expensive system. |
pyrOman Fire Master
Posted: Mon Nov 28, 2005 1:02 pm Post subject: |
dj, thanks for the link, will keep it handy.
busman, that's more like what I wanted to hear. For one, I already have euro tailights on my '65 Dormy and was thinking on doing the same for the truck. Also, it IS a truck and intended to be used as such. Hell, even my Dormy as nice as I keep it, was never intended to be an award winner of any kind. So if I have to get a pep boys generic signal lever and relay combo then that's what' it'll get. I was just hoping to find a quick and somewhat easy solution here. Thanks for the suggestion.
As far a "correct" this that or the other, I already jammed a '78 steering box into it, including the very nice rubberized steering wheel! _________________ Some people are so busy being clever they don't have time enough to be wise. |
steponmebbbboom Samba Member
Posted: Mon Nov 28, 2005 4:57 pm Post subject: |
I replaced my turn signal flasher with one right off the shelf at the nearest VW shop for fifteen bucks. Those three prong flashers are easy to get. It's a hell of a lot less expensive and time consuming than tracking down euro taillight housings and hacking the wiring for an HD12 flasher.
Quote: |
No, I'm not lost or just stumbled into the fatchick forum by mistake. |
Dont worry pal, I wont try to hang with you, we all know youre too cool for us.
Good luck. |
pyrOman Fire Master
Posted: Mon Nov 28, 2005 6:24 pm Post subject: |
steponmebbbboom wrote: |
Good luck. |
Thanks for the tip. Already got the highbeam switch to work as well as the brake lights. Soon as I hook up the turn signals it'll be good to go!
Dont worry pal, I wont try to hang with you, we all know youre too cool for us. |
I know but hey, don't rub it in! _________________ Some people are so busy being clever they don't have time enough to be wise. |
shakor44 Banned
Posted: Mon Nov 28, 2005 8:46 pm Post subject: Re: '68 Truck |
pyrOman wrote: |
I really need to get this truck running "legal" as far as the lights is concerned. |
Those trucks are a silly joke. Good luck trying to make it legal. |
TristanM Samba Member
Posted: Mon Nov 28, 2005 8:55 pm Post subject: Re: '68 Truck |
shakor44 wrote: |
pyrOman wrote: |
So let's see a pic of your ride if we are going to be judgemental. _________________ Don't Believe The Hype. |
pyrOman Fire Master
Posted: Tue Nov 29, 2005 7:36 am Post subject: Re: '68 Truck |
splitty wrote: |
shakor44 wrote: |
So let's see a pic of your ride if we are going to be judgemental. |
So'right! It drove sweet this morning to work. As I'm getting it together and just this close from "fixing" the signals, we'll see just who IS the joke! _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Tue Nov 29, 2005 8:22 am Post subject: |
Good, now maybe we can all learn to appreciate the "fatness" a little more now, huh? _________________ Don't Believe The Hype. |
pyrOman Fire Master
Posted: Thu Dec 01, 2005 7:27 am Post subject: |
I'm still "working on" getting the signals fixed. However, also need the latching mechanisms for both treasure chest doors. Bungees are just tacky looking. Can anyone out there spare a set? _________________ Some people are so busy being clever they don't have time enough to be wise. |
wileysc71 Samba Member
Joined: March 13, 2005 Posts: 660 Location: Madison, AL
Posted: Thu Dec 01, 2005 8:11 am Post subject: |
pyrOman wrote: |
Can anyone out there spare a set |
For a long while I thought there weren't any left on the planet. And "no", a split one and later bay ones won't fit without serious mods. I ended up getting one from Gabriel at Gab's locks or something. He posts in the classifieds and has a website too. He had 2 and I was too broke to buy them both. Maybe he still has 1. _________________ ~ Sean
'71 Super |
pyrOman Fire Master
Posted: Thu Dec 01, 2005 9:18 am Post subject: |
wileysc71 wrote: |
pyrOman wrote: |
For a long while I thought there weren't any left on the planet. And "no", a split one and later bay ones won't fit without serious mods. I ended up getting one from Gabriel at Gab's locks or something. He posts in the classifieds and has a website too. He had 2 and I was too broke to buy them both. Maybe he still has 1. |
For the life of me I can't even begin to figure out WHY would any frokin previous owner would just remove these mechanisms from the truck and install tacky bungees. I must assume they were purposely removed because all the bolts that holds them are in place but the items are gone! _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Thu Dec 01, 2005 10:48 am Post subject: |
pyrOman wrote: |
For the life of me I can't even begin to figure out WHY would any frokin previous owner would just remove these |
Ditto. My lock was still there, although broken internally. But the lock cylinder was gone. These locks were LONG gone on all the trucks I found being parted. I think someone has a garage full of them. I heard of a guy in Europe asking $250 for one. _________________ ~ Sean
'71 Super |
flabay Samba Member
Joined: February 28, 2004 Posts: 638 Location: Clearwater,FL
Posted: Thu Dec 01, 2005 7:16 pm Post subject: Re: '68 Truck |
shakor44 wrote: |
pyrOman wrote: |
Every post from you SUCKS!!! PLEASE GO AWAY- YOU ARE NOT WELCOME HERE WITH ALL OF YOUR NEGATIVE COMMENTS!!!!
Nice SC Pyroman, I have always wanted a DC. Maybe someday! |
pyrOman Fire Master
Posted: Fri Dec 02, 2005 6:59 am Post subject: |
flabay wrote: |
The funny thing is that, 1) I really don't care much at all for fatchicks but wanted a truck and the cab space on these just can't be beat, and 2) I wanted a TRUCK not a "passenger" vehicle. That's pretty much why I did not want a DC, kool though they are.
For passenger/camping I already have the '65 Dormy. For a truck I think double cabs compromise on cargo space. But again, to each his own, whatever floats your boat or blows your skirt up, etc.
Another point that sold me on the fatchick SC is the fact that you just don't see that many of them around yet the DCs seem to be a dime a dozen.
My trucks serial number is also a pretty much "early" one.
Which makes me wonder just what are the production numbers. _________________ Some people are so busy being clever they don't have time enough to be wise. |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Fri Dec 02, 2005 7:39 am Post subject: Re: '68 Truck |
shakor44 wrote: |
WTF? Try your cheerios WITHOUT the urine. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
pyrOman Fire Master
Posted: Mon Dec 05, 2005 9:25 am Post subject: |
So I'm getting the turn signal lights nearly figured out, but...
I got a funky in-dash lawnmower type starter switch and want to install a correct one on the column. Found one at the scrapyard but for the life of me I just could not remove it!
I could have hammered the damn thing out but since I need it, I didn't want to ruin it in the process. So just HOW is it you remove the starter switch WITHOUT having a key!!!! _________________ Some people are so busy being clever they don't have time enough to be wise. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Mon Dec 05, 2005 3:59 pm Post subject: Re: '68 Truck |
pyrOman wrote: |
I got a '68 truck now |
Is that rear sidemarker just a reflector or does it have a bulb inside? _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
