KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Wed Mar 14, 2018 9:03 pm Post subject: Re: 77 bus wont start. |
Yikes! Either way, you won't get them in time.
Here are alternative ways you can clean them yourself:
https://www.thesamba.com/vw/forum/search.php?searc...=titleonly
Where in VA do you live? There must be a fellow Sambanista nearby that can help. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
thearkofnoahofwest Samba Member
Posted: Thu Mar 15, 2018 6:40 am Post subject: Re: 77 bus wont start. |
I just pulled the injectors and ran a can of cleaner into them with 12v. They open and spray. This leads me to believe I may be low on fuel pressure. Ill be putting that new FPR with the gauge on it sometime today. Hopefully I didn't just get a crap fuel pump.
And I live about 20mins away from harrisonburg VA. i havent had a chance to talk to anyone local that deals with VWs |
SGKent Samba Member
Posted: Thu Mar 15, 2018 6:50 am Post subject: Re: 77 bus wont start. |
you are almost done. With ignition on, and the distributor disconnected to avoid burning the points, open the afm flap with a wooden dowel or long screw driver. Do you hear a click from the double relay? If yes then check for 12V at the fuel pump. Also check for a ground and feel if the pump is running. There is also a possibility that the nipple at the gas tank is plugged with debris unless you cleaned the tank out. Avoid using 12V on the injectors or you may burn them up. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Randy in Maine Samba Member
Posted: Thu Mar 15, 2018 7:46 am Post subject: Re: 77 bus wont start. |
If you have to, call up a tow truck or a buddy and have them move the bus to a nice safe secure location as you figure this out.
I send my injectors to Rich at www.cruzinperformace.com and they come back in about a week with new short hoses for about $100 or so. Send the cold start valve also. |
Posted: Thu Mar 15, 2018 11:28 am Post subject: Re: 77 bus wont start. |
Okay. I am getting voltage to the pump and the pump is pumping fuel. Im not sure if its enough fuel or fuel pressure. Im going to test the pressure today. It is possible to have some debris in the tank. I have not cleaned it. And got it. No more 12v to the injectors.
Last edited by thearkofnoahofwest on Thu Mar 15, 2018 11:36 am; edited 1 time in total |
Posted: Thu Mar 15, 2018 11:34 am Post subject: Re: 77 bus wont start. |
I have a trailer to move the bus if I have to. I just really want to be able to tell the county to frigg off. And im borrowing a vehicle until I can get the bus running. It'll be ready to inspect once I get it running. |
Posted: Thu Mar 15, 2018 11:42 am Post subject: Re: 77 bus wont start. |
thearkofnoahofwest wrote: |
Okay. I am getting voltage to the pump and the pump is pumping fuel. Im not sure if its enough fuel or fuel pressure. Im going to test the pressure today. It is possible to have some debris in the tank. I have not cleaned it. And got it. No more 12v to the injectors. |
Have you carefully checked the function of your double relay? It needs to click when you turn the key on, if you aren't seeing consistent power to the injectors this could be your problem.
One half of the double relay is your FI relay and the other is your fuel pump relay. |
SGKent Samba Member
Posted: Thu Mar 15, 2018 12:01 pm Post subject: Re: 77 bus wont start. |
Mike he had flashing on a noid light. It tried to start on a tablespoon of fuel in the boot. The injectors were clogged so he ran some cleaner thru them when voltage was applied. The pump is running so it sounds like either there is no pressure (plugged rails, clogged nipple etc.) or bad FPR.
One could put a fresh gallon of gas in a lawn mower container and run a hose from it to the back of the pump and see if it starts. If it does then the tank outlet is suspect. If it doesn't one can pinch the back of the hose leaving the FPR to make sure the tank doesn't drain, also hook a hose up to the FPR and point it into another container then see if fuel flows when in the engine is on. That will eliminate the rails being plugged. If the bus starts then the FPR may be good - in fact the bus may even start if the FPR is poor. If it does then the solution to getting it moving off the property is to rig a temporary tank under it with a pickup and return, then move it gently like that. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Mar 15, 2018 2:03 pm Post subject: Re: 77 bus wont start. |
SGKent wrote: |
Mike he had flashing on a noid light. It tried to start on a tablespoon of fuel in the boot. The injectors were clogged so he ran some cleaner thru them when voltage was applied. |
Except for he added this to his 10:28 post :
Quote: |
No more 12v to the injectors |
SGKent Samba Member
Posted: Thu Mar 15, 2018 2:18 pm Post subject: Re: 77 bus wont start. |
Wildthings wrote: |
SGKent wrote: |
I see what you mean Mike. I suggested he not use direct 12V on the injectors anymore so I read that as, "I promise I won't jump the battery directly to the injectors anymore to clean them." _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Mar 15, 2018 2:43 pm Post subject: Re: 77 bus wont start. |
Yes, I promise, No more 12v to the injectors directly via batteries. So I ran a line directly to the new pump out of a gas can. The pump is getting 12v. However, it is only slowly sucking fuel from the gas can. I feel like it was just a junk fuel pump I ordered. |
SGKent Samba Member
Posted: Thu Mar 15, 2018 2:52 pm Post subject: Re: 77 bus wont start. |
so if you pull the line off the back side of the FPR, and crimp it to keep the tank from leaking, then attach a known good hose does the volume go way up? The fuel pump should deliver 1/2 quart in 30 seconds
page 20
https://www.thesamba.com/vw/archives/manuals/afc_f...Manual.pdf _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Mar 15, 2018 3:28 pm Post subject: Re: 77 bus wont start. |
It does not. I barley had but a few drops on the end. I did the same before the fpr and it kind of pumped a bit more intermittently. I also did it before the cold stary valve and it pumped a lot constantly. |
Posted: Thu Mar 15, 2018 4:14 pm Post subject: Re: 77 bus wont start. |
The pump likely has a screen in its intake end. If you tank is full of crap then the crap may have clogged the screen. |
Posted: Thu Mar 15, 2018 5:13 pm Post subject: Re: 77 bus wont start. |
Its getting plenty of fluid in the lines before the cold start. Before the FPR it has less fuel and after the FPR there is little to no fuel. I think the fuel pump might be underpowered. |
WESTYJACK Samba Member
Joined: February 21, 2017 Posts: 266 Location: LAVAL,QC CANADA
Posted: Thu Mar 15, 2018 6:06 pm Post subject: Re: 77 bus wont start. |
did you buy the good one for fuel injection? _________________ VW bus type 2 1978 transplant engine 1975 1800cc fuel injection |
Posted: Thu Mar 15, 2018 6:43 pm Post subject: Re: 77 bus wont start. |
Check that you have the wires on the correct terminals on the pump. These pumps don't suck all that well either, so maybe try raising your fuel container up to a level higher than the pump. |
Posted: Fri Mar 16, 2018 4:05 am Post subject: Re: 77 bus wont start. |
Ill try lifting the gas can up. How does 2.5 psi sound? I have a feeling even for this old 65hp monster, that's not enough |
Posted: Fri Mar 16, 2018 4:17 am Post subject: Re: 77 bus wont start. |
not enough for sur
suppose to be around 25-35
I think you buy a pump for carburator 2-4 psi _________________ VW bus type 2 1978 transplant engine 1975 1800cc fuel injection |
