SGKent Samba Member
thearkofnoahofwest Samba Member
Posted: Fri Mar 16, 2018 5:42 am Post subject: Re: 77 bus wont start. |
I bit the bullet and stopped by autozone and got a Delphi pump. It'll be in around 1 today. Ill slap that bad boy on and see if the bus finally starts. And hopefully don't find any other major issues. |
SGKent Samba Member
Posted: Fri Mar 16, 2018 6:58 am Post subject: Re: 77 bus wont start. |
thearkofnoahofwest wrote: |
I did not know Delphi made an external pump for our buses. What is the part number? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Mar 16, 2018 8:11 am Post subject: Re: 77 bus wont start. |
Yeah, autozone carries that Bosch pump too. I got the Delphi because its for the "campmobiles". probably not any different, I just really dont want to take the chance. And the part number is CFE0023. Autozone price matched Rockauto at 109.99. And ill have it today. |
Posted: Fri Mar 16, 2018 2:49 pm Post subject: Re: 77 bus wont start. |
IT WORKED! I got it running up and down the driveway. Forbthe being my first air cooled vwbus, is it supposed to be this slow? Like, so slow I could outrun it on foot. also, it won't stay running unless I keep the flap open on the intake with a Dow rod. Fuel pump worked though! |
Randy in Maine Samba Member
SGKent Samba Member
Posted: Fri Mar 16, 2018 4:19 pm Post subject: Re: 77 bus wont start. |
they show it for all FI buses vanagons etc, BMW, Alfa, VW, Fiat.
I suspect there are other issues that still have to be dealt with. First thing I would do now is a smoke test to find all the vacuum leaks and why it won't stay running at idle. Looks like there isn't enough suction to hold the AFM flap open so I am guessing massive vacuum leak. Once those are resolved I'd do s cylinder balance test at idle to make sure all 4 are firing. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Fri Mar 16, 2018 4:56 pm Post subject: Re: 77 bus wont start. |
What kind of plastic was the Dow rod? or was it silicone? Copolymer?
Great work getting this far. Now the county has to walk real fast to catch the bus to tow it. but really, does this buy you time? It runs. |
Posted: Fri Mar 16, 2018 9:18 pm Post subject: Re: 77 bus wont start. |
I found the vaccum leak. Tear all the way around the intake hose. Ill fix that and figure out the misfire. As for the dow rod it was just a wooden one I found laying around. And for the county, they can't say s#!t if it has a clean inspection sticker.
Here is my grinch bus.
And thank you all for the help. |
SGKent Samba Member
Posted: Fri Mar 16, 2018 11:37 pm Post subject: Re: 77 bus wont start. |
show me a picture of the intake hose - is it the S-Boot? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Mar 17, 2018 7:34 am Post subject: Re: 77 bus wont start. |
This is where the intake is broken. Safe to say there is no vaccum at all.
I can probably cut it about 1/2 way up and add a 90° coupling
I also have a feeling the points need some adjusting. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sat Mar 17, 2018 8:12 am Post subject: Re: 77 bus wont start. |
Yup, I'd say you fond the major source of the leak. Probably going to find more when this one is fixed.
If you want an S-boot that will last many more years, GeeBee makes one out of silicone with a nomex covering...
https://www.thesamba.com/vw/classifieds/detail.php?id=1321070
I bought one, and it's pretty indestructible. But it's a PITA to install. The silicone is slippery, so everything attached to it must be clamped on.
Alternately, there are several OG boots listed in The Samba classified. Much cheaper too.
But it's great to hear your grinch bus will be on the roads soon! Happy bussin'! _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Posted: Sat Mar 17, 2018 8:17 am Post subject: Re: 77 bus wont start. |
Nope. Get a good S boot and replace that loser. Check the classifieds here as there are usually some in there.
The new ones that GEEBEE makes are excellent.
While you are waiting for a good used one to show up find a decent dwell meter for about $25. I have a little Actron 7605 that does dwell,tach, and voltage. Handy if you have points. |
SGKent Samba Member
Posted: Mon Mar 19, 2018 5:41 am Post subject: Re: 77 bus wont start. |
Yeah, ill get that from you soon. As for now im having an issue with cylinder 3 not firing. Its getting spark. It is most definatly getting spark. Strong spark. My arm agrees. Im not completely convinced that its getting fuel. Im going to pull the injector and make sure its cleaned and working one more time. Other than that im probably going to adjust the valves in the next few days.
Also, if I give it any throttle now, its just wants to shut off completely. Im wondering if Ive mixed up my fuel injector wires.
And for some reason, my brand spankin new fuel pump is making Terrible whining noise. |
Posted: Mon Mar 19, 2018 6:43 am Post subject: Re: 77 bus wont start. |
The whining is also known as "cavitation" and is usually caused by tank rust building up in the fuel filter and limiting flow to the fuel pump. Keep in mind that the fuel also cools the pump. |
SGKent Samba Member
Posted: Mon Mar 19, 2018 7:03 pm Post subject: Re: 77 bus wont start. |
what Randy just said. Are you feeding it from the extra tank as suggested or did you go back to the probably dirty one that is in the car?
All 4 injectors fire at the same time. Fuel puddles until the valve opens. Use the noid light to check the connector. If it works then just see if the injector sprays into a jar. Don't do it long because of the fire danger. Also, if you haven't replaced the injector seals you need to. They get dry and leak lots of air. That can also be why #3 isn't firing and why it is gutless. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22568 Location: NYC/Upstate/ROW
Posted: Tue Mar 20, 2018 4:06 am Post subject: Re: 77 bus wont start. |
Yeah, all the vacuum leaked out of that one. Make sure it didn’t pool at he bottom of the engine.
I and leave the DOW rod in your will, too.
Get new parts seals hoses on this beast and it will run much better _________________ .ssS! |
Posted: Tue Mar 20, 2018 3:20 pm Post subject: Re: 77 bus wont start. |
I moved the line back to the bus tank. I ordered new injector seals and will install them tomorrow. I also hauled it to my new shop and put gas in it while hauling it. And fuel leaked out. Not while I was filling it, afterward. While hauling it. |
