Buggo Samba Member
Posted: Mon Mar 12, 2018 2:55 pm Post subject: Backup Lights Wiring |
Hi there,
My beetle is a 1967 that is mostly untouched especially when it comes to the electrical. Im installing reverse lights and am noticing that there is NOT an inline fuse in the lead heading to the coil. If this car was 100% stock, there would be an inline fuse right? Im just a little surprised that the fuse isnt there. Everything looks stock. So just install a fuse before i set up the lights? Is that the general consensus here?
Ricky |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Mon Mar 12, 2018 3:47 pm Post subject: Re: Backup Lights Wiring |
Yep - Just install an 8A fuse....and we ARE talking about a 50 year old car....Sometimes things get misplaced... _________________ D-Dubya Manx clone - 63 Short pan,1914.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Mon Mar 12, 2018 5:32 pm Post subject: Re: Backup Lights Wiring |
andk5591 wrote: |
Yep - Just install an 8A fuse....and we ARE talking about a 50 year old car....Sometimes things get misplaced... |
x2. It's likely that when the PO removed the backup lights from your 67 they discarded the fuse holder.
Have a look at the pic below. You can see the fuse holder just above the right fresh air outlet from the fan housing.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
mukluk Samba Member
Posted: Mon Mar 12, 2018 7:05 pm Post subject: Re: Backup Lights Wiring |
Just for clarification's sake, there should be an inline fuse in the wire from the coil to the reverse light switch, but not an inline fuse in the wire going to the coil from the fuse block/ignition switch. You are more than welcome to install a fuse going to the coil if you wish, being something that I feel the factory was remiss in not doing, but be aware that there was not one originally. _________________ 1960 Ragtop w/Semaphores "Inga" |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Tue Mar 13, 2018 6:43 am Post subject: Re: Backup Lights Wiring |
Just for additional information.. the 67 reverse lamp fuse is NOT indicated in the wiring schematic ... but it is originally right.. here..
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Buggo Samba Member
Posted: Tue Mar 13, 2018 12:14 pm Post subject: Re: Backup Lights Wiring |
Here is that exact location on my bug. Why would anyone remove the inline fuse? Seems like a pain in the ass to rewire...because i dont see a break on the wire that would indicate the fuse had been just snipped out. Infact i even tested the lights and they defiantly work. so someone snipped out the fuse and rewired it. Is that the conclusion we are all coming to? any idea why anyone would do that?
Ricky
https://www.thesamba.com/vw/forum/album_page.php?pic_id=1756500 |
Posted: Tue Mar 13, 2018 12:35 pm Post subject: Re: Backup Lights Wiring |
I am not questioning Volkswagnut's comment about the correct fuse location....Lord knows that I have yet to work on an unmolested car, BUT every car that I have worked on has had the fuse close to the coil and not on the passenger side of the shroud. _________________ D-Dubya Manx clone - 63 Short pan,1914.
mukluk Samba Member
Posted: Tue Mar 13, 2018 2:08 pm Post subject: Re: Backup Lights Wiring |
Something I've wondered is if the '67 backup lights weren't provided with an inline fuse until sometime after initial production started, possibly a mid-production change that was made due to problems popping up with the lights or wiring. Two things that support that theory would be the October '66 dated wiring diagram noted already that doesn't show a fuse, as well as the August '66 owner's manual that doesn't show or make mention of a fuse for the backup lights anywhere (the fuse and holder is specifically mentioned starting in the '68 owner's manual). _________________ 1960 Ragtop w/Semaphores "Inga" |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Tue Mar 13, 2018 2:16 pm Post subject: Re: Backup Lights Wiring |
My brother's all-original '67 Euro 1500 from about 1974 had it in the upper right:
(yeah, I know the fuel filter was not original!)
Also, in about 1976, my '67 USA 1500 had it in the same position.
My late Type 3 cars had them on the left side near the coil, however. |
Buggo Samba Member
Posted: Tue Mar 13, 2018 3:10 pm Post subject: Re: Backup Lights Wiring |
That seems right to me because this bug I have is almost 100% original and i really doubt someone would have taken the fuse out and rewired the car. This wire looks 100% factory to me. and like i said before i dont see anywhere where the wire was spliced back together. so it must have been replace completely or never had an inline fuse in the first place. |
KTPhil Samba Member
Posted: Tue Mar 13, 2018 4:46 pm Post subject: Re: Backup Lights Wiring |
Someone got the "changes" document handy? |
Buggo Samba Member
Posted: Tue Mar 13, 2018 7:52 pm Post subject: Re: Backup Lights Wiring |
Ok so do I need a special fuse holder or can I just get any old one at a normal shucks auto or something? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
mukluk Samba Member
Meiang Samba Member
Joined: September 27, 2016 Posts: 656 Location: Perth, Western Australia
Posted: Wed Mar 14, 2018 12:36 am Post subject: Re: Backup Lights Wiring |
I have a VW original retro fit kit to install reverse lamps on cars which were not fitted with them. The part number is 135 998 135.
The kit includes:
1) the entire wiring loom (including fuse holder)
2) gearbox switch
3) bulb holders to put in the rear lamp units
You might find this kit if you keep an eye out on Ebay.de or Ebay.co.uk |
Buggo Samba Member
Posted: Thu Mar 29, 2018 11:56 am Post subject: Re: Backup Lights Wiring |
Ok got an inline fuse holder from JBugs: http://www.jbugs.com/product/111-848.html
What i got did not look like whats in the picture, infact, what i got was nicer then whats pictured. Anyways installed it and the lights work perfectly. Thanks for the help eveyone.
Posted: Thu Apr 05, 2018 10:07 am Post subject: Re: Backup Lights Wiring |
To ad more information. . to show the fuse holder clip and reversing lamp fuse location for a 1967.
From here https://www.thesamba.com/vw/archives/manuals/techbulletins/e3.php
vdubmyk Samba Member
Joined: October 24, 2008 Posts: 508 Location: Corona, CA
Posted: Wed Oct 24, 2018 12:35 pm Post subject: Re: Backup Lights Wiring |
Meiang wrote: |
The kit includes:
2) gearbox switch
Would you happen to have a picture of the fuse holder? I am installing some lights and would like a "period correct" one. _________________ 64 stock bug, 12V (converted 6v unit), 40 hp, all documents even sales contract and dealer window sticker! |
KTPhil Samba Member
Posted: Wed Oct 24, 2018 3:46 pm Post subject: Re: Backup Lights Wiring |
The typical retrofit kit did not come with a fuse. Here are the instructions:
You can see that they used the end fuse in the existing fusebox.
There is another kit, which used a switch inline with the speedo cable (lower left, below); that type might have used a fuse, but I just see a connector that probably went to the existing fusebox, like the later kit.
If you want to wire it like the originals, use a fuseholder off the coil and the tranny switch. The photos further above show a type similar to the original. Original below:
harrymarlin Samba Member
Joined: June 07, 2018 Posts: 723 Location: Washington, DC
Posted: Thu Jan 02, 2020 5:37 pm Post subject: Re: Backup Lights Wiring |
Following up on this - my 67 (mid-Oct) also only has a clean wire from the coil to the back-up lights, although my new Wolfsburg West wiring harness calls for a fuse. I would like to keep my car as stock as possible, so should I include it? Garwood suggests it should have been there from the beginning, so any ideas on why mine (and Buggo's) 67s may have not had inline fuses, when others seem to? It's not like mine was at the very start of 67 production. _________________ -Harry
1967 Ruby Red Convertible Beetle ("Becky")
ISO Albuquerque "Imported Motors" dealership paraphernalia |
