78 Busdriver Samba Member
Posted: Mon Mar 12, 2018 5:18 pm Post subject: Rear side window seal |
You guys ever have any issues putting window seals on? I installed 4 of the 5 windows with no problem...but I can't get the rear side drivers side window in? Bad seal maybe? |
Rodmullet Samba Member
Posted: Mon Mar 12, 2018 6:15 pm Post subject: Re: Rear side window seal |
I had an awful time when I replaced the passenger rear side window/vent with the full one piece glass that is the same as the passenger side...I had to get a couple of industrial size suction cups, and pull with all my weight, then pull the rope a bit, etc., while my wife hammered at the seal with a big rubber mallet at the point where I was pulling the rope. We eventually got it in, but it took way too much work...This was using a Bus Depot seal...I am going to try the Wolfsburg West seal when I replace the passenger side seal.
Good luck,
Rod |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Mon Mar 12, 2018 6:21 pm Post subject: Re: Rear side window seal |
Do you have the vent window frame installed? Or are you going for "one-piece" glass on the rear side?
I like to install the vent window assemblies first and then use the common cord method of flat glass installation. Someone folks on here do it the opposite, which I could never figure out. Hopefully they'll chime in too.
www.airschooled.com |
SGKent Samba Member
Posted: Mon Mar 12, 2018 7:22 pm Post subject: Re: Rear side window seal |
I've seen bad seals, mis-numbered parts. How easy is it to put the seal on the window? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Mar 12, 2018 8:32 pm Post subject: Re: Rear side window seal |
No vent wing...and it goes on like the rest of the seals...this is the second bus I have done and never had a problem. The seals i got where from bus depot both times. I don't see a problem anywhere, took me and one other to do the other 4..took 3 people and no luck doing the one I can't get. |
Posted: Mon Mar 12, 2018 8:37 pm Post subject: Re: Rear side window seal |
I would like to mention that this window was broken when I got the bus....so I bought it off of a local mechanic that had several buses he was parting out. When I brought it home I laid it on top of the other side it it matched up fine? |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Tue Mar 13, 2018 4:39 am Post subject: Re: Rear side window seal |
Maybe just a bad day for putting a seal in, slick it up with some Super lube or Dielctric grease, push the window in square and hold it in then start pulling the rope from the bottom center, pull to rear about half way up then to the front half way, finish the rear portion then the front across the top, you may need to spray silicone as you go to keep it slick. |
Posted: Tue Mar 13, 2018 7:12 am Post subject: Re: Rear side window seal |
Well it was a good day to put the other 4 windows in. The 5th one doesn't seem to even come close to going in. I have an email to bus depot to give me there thoughts on the seal. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Mar 13, 2018 9:30 am Post subject: Re: Rear side window seal |
It might have had body work or damage- go to the easy side with a tape measure and check the dimensions- Then take the seal off the glass and fit it in the hole to see if there are any tight spots that can be altered by a glass shop. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Tue Mar 13, 2018 10:13 am Post subject: Re: Rear side window seal |
I did Measure both sides..dead nuts on. I'm going to try what the guy from bus depot said, soak in hot water for a bit first |
Posted: Tue Mar 13, 2018 10:27 am Post subject: Re: Rear side window seal |
You didn't fall for the old wives tale that par boiling will shrink the glass did you? |
Posted: Tue Mar 13, 2018 10:35 am Post subject: Re: Rear side window seal |
I haven't boiled anything. |
Posted: Sun Mar 18, 2018 7:15 pm Post subject: Re: Rear side window seal |
Let sit out in the sun for 4 hours along with window seal, lubed up with water and soap and had 3 other friends help. Went right in. |
Posted: Fri May 11, 2018 6:24 pm Post subject: Re: Rear side window seal |
I finally got around to installing a rear side window using a Wolfsburg West seal, and it went in much easier than the Bus Depot seal I used previously, as mentioned above. Still had to use a rubber mallet to tap a bit on the top half of the seal in order to get it close enough to pull the cord, but much easier. Not sure if it a size difference, or just a different rubber formulation...
Hope this helps someone along the way.
Rod |
