55 ragger Samba Member
Posted: Mon Mar 12, 2018 5:32 pm Post subject: Spark plug wires mixed up |
Can I damage my
40 hp if the plug wires are mixed up.
thanks |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Mon Mar 12, 2018 5:37 pm Post subject: Re: Spark plug wires mixed up |
Mixed up as in different brands?
No
On the wrong cylinders... the engine will not run right and will most likely not run or backfire. _________________ Glenn
Member #1009
#BlueSquare |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Mon Mar 12, 2018 5:40 pm Post subject: Re: Spark plug wires mixed up |
Not really, if you get it fixed right away. It'll run like crap if it starts at all!
You need to get the #1 piston at top dead center (TDC) then remove the distributor cap and note the position of the rotor. Where ever it's pointing. That is the lug on the dist. cap where your #1 plug wire attaches. Then it's just a simple follow up 4-3-2 clockwise.
Don't look at the notch on the dist rim. These engines have been rebuilt many times over the years and dist drive shaft could be in any of 12 different positions.
Just make sure that you have the #1 piston at TDC before you rearrange the plug wires.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Last edited by 67rustavenger on Mon Mar 12, 2018 5:47 pm; edited 1 time in total |
Posted: Mon Mar 12, 2018 5:43 pm Post subject: Re: Spark plug wires mixed up |
Glen
Wires where wrong and I dove it, now after rebuild on the carb
its popping out the carb.
not backfiring out the tail pipes |
Posted: Mon Mar 12, 2018 5:59 pm Post subject: Re: Spark plug wires mixed up |
Its now wired correct ,
As I said it popping out of the carb . just like a backfire
its fine as it reeves higher but as it take the gas
it pops .
Engine is all stock 40 hp
28 pic
except 4 tipp Abarth |
Posted: Mon Mar 12, 2018 6:28 pm Post subject: Re: Spark plug wires mixed up |
I'm wondering if a valve got damaged ?
Or is it still the carb
stock 6 volt with electric choke |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Thu Mar 15, 2018 9:44 am Post subject: Re: Spark plug wires mixed up |
I doubt you damaged the anything in the engine by having the firing order wrong. It just won't run very good until you correct it. _________________ Andy T.
mukluk Samba Member
Posted: Thu Mar 15, 2018 12:03 pm Post subject: Re: Spark plug wires mixed up |
How, specifically, were the plug wires mixed up and for what length of time did you drive the car with them in such a condition? _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Thu Mar 15, 2018 12:16 pm Post subject: Re: Spark plug wires mixed up |
How long ...
She is only grocery getter, it ran rough but I really thought it was the
4 tipp Abarth
I used the wiring order from the technical forum for wirering ...
as per the diagram. on the layout of the plugs wires running off the distributer cap !!
My bad .anyway its smoother now ..
just it does a lot of popping out of the carb
Will only start if the choke is held open to much gas is getting into the oil
I did rebuild the carb, but somthing for sure is not correct !! |
mukluk Samba Member
Posted: Thu Mar 15, 2018 12:49 pm Post subject: Re: Spark plug wires mixed up |
You didn't answer the question. How, specifically, were the plug wires mixed up? Were they in the wrong firing order, and if so, which ones were swapped? Were they all off by one position? Was one left sitting in the corner of the garage? Was one end shoved between the coil and fan housing?
Since correcting your plug wire mixup, have you done anything else to find the cause of your continued problems? Checked valve adjustment? Dwell? Timing? How about a compression check or leak down test?
You mention too much gas is getting into the oil. Is the fuel pump leaking? Is your fuel pressure too high? Is the carb float needle valve leaking? Do you have gas trickling down the throat of the carb after you shut the engine off? Is your carb jetted or adjusted horribly rich? _________________ 1960 Ragtop w/Semaphores "Inga" |
Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Thu Mar 15, 2018 1:47 pm Post subject: Re: Spark plug wires mixed up |
When did you rebuild the carb? After this wiring issue or before? _________________ '63 Ragtop |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Thu Mar 15, 2018 1:52 pm Post subject: Re: Spark plug wires mixed up |
I'm guessing that you still have the plug wires arranged wrong. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Thu Mar 15, 2018 4:24 pm Post subject: Re: Spark plug wires mixed up |
First thanks for the interest..
1. plugs were wired wrong and what order ... I dont know
really but it did seem to get real hot on number 3-4 side of the engine.
2. valves have been set @ .06
3. timing set static @ BTDC
4. injector tube has nice fine spay
5. pic 28 still 6 volt electric choke that works
But as i said it will not start unless its held open
6. No compression test was rebuilt last yr .. all stock
but I could do that for sure , telling me about the valves .
7. Rebuilt the carb 2 weeks ago and figured out the wiring was messed up.
8. Runs a lot smoother now but the carb pops . the same as a backfire bkut out of the carb
9. check with . propane torch and carb cleaner no leaks
10. The carb does have a bit of play on the throttle body but its 50 yrs old , |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Thu Mar 15, 2018 4:48 pm Post subject: Re: Spark plug wires mixed up |
55 ragger wrote: |
I hope you meant .006" |
Posted: Thu Mar 15, 2018 4:53 pm Post subject: Re: Spark plug wires mixed up |
Yes ... thanks |
Posted: Thu Mar 15, 2018 4:58 pm Post subject: Re: Spark plug wires mixed up |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
vwoldbug Samba Member
Posted: Fri Mar 16, 2018 4:08 pm Post subject: Re: Spark plug wires mixed up |
Can you get a video of engine running . |
Posted: Mon Mar 19, 2018 5:09 pm Post subject: Re: Spark plug wires mixed up |
This video shows more of the problem .
https://youtu.be/VapVvjcf48o
Learning curve ... |
