Fenix Samba Member
Joined: October 05, 2016 Posts: 468 Location: St Louis
Posted: Tue Mar 13, 2018 6:49 am Post subject: Name that part- New part for the Zombie |
Just wanted to lighten up the day. Guess this part I just printed for the zombie.
Hint: It is about 4.125" in diameter. Holds 5 5mm cylindrical shaped electrical components and two 1" strips with small square versions of the same electrical components and fits within something else.
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Mar 13, 2018 7:08 am Post subject: Re: Name that part- New part for the Zombie |
Speedo and idiot lamp bezel?
Fenix Samba Member
Posted: Tue Mar 13, 2018 7:48 am Post subject: Re: Name that part- New part for the Zombie |
Dale M. wrote: |
Dale |
That didn't take long!
Yeah, got a roll of Carbon Fiber Filled PETG filament in today for the ROSTOCK and wanted to give it a try after changing out the extruder. I'll test fit it tonight. If i measured everything correctly it should fit into the housing and let the face plate assembly slip right in on top of it.
It will hold 5mm leds for the alt (still keeping the incandescent but has room for the 100 ohm 2w resistor as well), oil, independent directionals, and hi-beam indicator. The perimeter is setup to allow 2 1" lengths of SMD LED strips to be mounted. Since the PO butchered the housing and the fuel gauge alond with every other light feature, was removed from the Speedo I have some extra room to print a custom VW - Zombie logo for the center of the gauge. |
