DougB Samba Member
Joined: January 09, 2007 Posts: 1076 Location: Falls Church, Virginia, USA
Posted: Wed Mar 14, 2018 6:40 am Post subject: Argh, &%$#$% Engine Install :-( |
Hello all,
I'm having a hell of a time getting my type 4 engine to mate with my 5-rib 002 tranny (which is in the vehicle), and just wanted to see if I'm missing anything.
Brief backstory:
- removed engine to replace bad pilot bearing
- using the same flywheel, pressure plate and now clutch disc (just to remove any variables from new parts)
- nothing different about my configuration except that the thin metal piece through which the flywheel bolts and tranny input shaft pass was not previously installed (though it shouldn't be an issue since my clutch alignment tool fits inside it without issue)
- tranny is still in the car, and starter is still in the tranny
The issue I'm having is that I just can't get the two fully mated. There are no flapper boxes installed, so it's not like they're interfering with the firewall crossbrace or the starter (a mistake I was making earlier). Clutch plate is definitely aligned, throwout bearing is fully pulled in so it's not in the way. I can get them mated enough to have the toothed part of the flywheel nested inside the tranny bell housing, but not far enough to get nuts on the 2 studs on the bottom (rear, or front if FIF) of the engine. I've tried detaching and re-attaching, while moving both the flywheel and the input shaft a bit, several times as well just in case it was spline interference. I've also verified that the clutch plate moves well on the input shaft splines.
Question: I noticed that Ratwell has removing the starter as part of his process...but I feel like I've installed the engine in the past with the starter installed. Is that a must-do?
Any advice for a very weary soul? Thanks in advance,
- Doug :-/ _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
A very, very understanding wife |
SGKent Samba Member
Posted: Wed Mar 14, 2018 6:54 am Post subject: Re: Argh, &%$#$% Engine Install :-( |
turn the engine a little with the alternator until you feel the input shaft slide thru the clutch. View the gap between sides and be sure that all are parallel. I am assuming you used a clutch tool to put the clutch in, and if new that you checked it first to be sure it slides onto the input shaft smoothly. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Mar 14, 2018 6:57 am Post subject: Re: Argh, &%$#$% Engine Install :-( |
^X2^, and put the bus in 4th gear with the brake on while doing that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
DougB Samba Member
Posted: Wed Mar 14, 2018 6:58 am Post subject: Re: Argh, &%$#$% Engine Install :-( |
That idea to turn the engine a bit from the pulley side is a good one, hadn't tried that. I did use a clutch tool and have also verified that the clutch disc slides well on the input shaft splines.
So if Steve didn't come back saying "of course you need to remove the starter" then perhaps it's not necessary? I mean, with the starter drive gear retracted it doesn't even touch the flywheel when even when the tranny and engine are fully mated, correct?
Thanks!
- Doug _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
zabo Samba Member
Posted: Wed Mar 14, 2018 7:00 am Post subject: Re: Argh, &%$#$% Engine Install :-( |
what thin metal piece? the pressure plate collar?
anyway yes- sounds like an alignment issue to me. You may need to adjust the jack position under the engine or try to tip it forward or backwards a bit while pushing it in. _________________ 1960 6 volt sedan- 1978 adventurewagen
–wanted bill spreen atlanta dealer tag frame |
SGKent Samba Member
Posted: Wed Mar 14, 2018 7:03 am Post subject: Re: Argh, &%$#$% Engine Install :-( |
I've always put the starter in last myself so I can't answer that. I have fought like you with an engine for many minutes and then suddenly when it is just right it simply slides together. The main thing to watch are the gaps. That will tell you if the engine and trans are really aligned. For me, T4 engines are a lot harder to put with the transmission than T1 were because you have to come up and in, rather than straight in like a T1 with the removable apron. That is why I pull the transmission and engine as a unit. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Wed Mar 14, 2018 7:07 am Post subject: Re: Argh, &%$#$% Engine Install :-( |
The starter is fine. I never remove mine during engine removal/install.
Although this is not the problem, you do want to use a new 5-hole washer (thin metal piece) and new flywheel bolts on installation. The bolts have serrated faces that dig into the 5-hole washer, guaranteeing that they will not back out.
Last time I had trouble getting the engine and transaxle to get together, even though they were lined up, it was because the clutch cable was too tight, meaning that the fingers in the pressure plate were engaging with the throwout bearing during the install, keeping things from going together without enough force to depress the pressure plate. Did you mess with your clutch cable adjustment at all? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Randy in Maine Samba Member
Posted: Wed Mar 14, 2018 7:09 am Post subject: Re: Argh, &%$#$% Engine Install :-( |
Sometimes you have to change "the angle of the dangle" and jack up the transmission a bit to get them to mate up correctly. |
Abscate Samba Member
Posted: Wed Mar 14, 2018 8:36 am Post subject: Re: Argh, &%$#$% Engine Install :-( |
You don't have to pull the starter.
Clutch should be eased of freeplay
Most likely you need to turn the engine that 15-30 degrees to mate splines _________________ .ssS! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Wed Mar 14, 2018 8:48 am Post subject: Re: Argh, &%$#$% Engine Install :-( |
Fought "Grey whale" for almost an hour and a half (3 of us)- and after a group swear- it slid right in. I have known of some "risk takers" to hook up just the starter, and bump it round a bit after it's close enough to engage teeth , that made the last quarter inch a snap fit. - there are hazards of course.--
Ours hit about where the pilot bearing would have been, so suspected that was the issue. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Wed Mar 14, 2018 8:52 am Post subject: Re: Argh, &%$#$% Engine Install :-( |
Just don't EVER EVER try to draw it close with the bolts/nuts
When its right, it will go together. _________________ .ssS! |
Posted: Wed Mar 14, 2018 8:59 am Post subject: Re: Argh, &%$#$% Engine Install :-( |
Check that the clearances are the same all the way around between the engine and bellhousing and then while pushing lightly on the engine turn the crank a few degrees and you should feel the engine move forward a bit as the splines align. Done right it is very easy to get a Type 4 engine to mate. |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Wed Mar 14, 2018 1:43 pm Post subject: Re: Argh, &%$#$% Engine Install :-( |
he said the pilot bearing was trashed. what does the end of the input shaft look like? if it's all mangled you may have fucked up the new bearing, and if it's got a nasty burr that could be stopping it from going in. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Wed Mar 14, 2018 1:59 pm Post subject: Re: Argh, &%$#$% Engine Install :-( |
Stupid question. Did you remove the mount bolts from the "rabbit ears" on the bell housing? To allow more movement of the trans, and support the trans with a jack to keep the two aligned? Like I said stupid question. |
bbrowncods Samba Member
Joined: December 27, 2014 Posts: 58 Location: Virginia
Posted: Wed Mar 14, 2018 3:12 pm Post subject: Re: Argh, &%$#$% Engine Install :-( |
Just put mine in a couple of weeks ago and had the same problem on going in that last 1/2-3/4 inch. Finally put my feet on the heat exchangers and wiggled it back and forth and it just popped in. |
DougB Samba Member
Posted: Wed Mar 14, 2018 6:01 pm Post subject: Re: Argh, &%$#$% Engine Install :-( |
Success! Steve gets the prize for the first winning suggestion but maybe Abscate wins for probably the most “bad habit correcting” advice (don’t use the bolts to draw the pieces together). Rotating the crank on the pulley side did the trick. The clutch adjusted to the correct pedal travel, too.
Now it’s time to plug everything back in...thanks so much again!!!
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Wed Mar 14, 2018 6:06 pm Post subject: Re: Argh, &%$#$% Engine Install :-( |
Sweet! _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
jtauxe Samba Member
Posted: Thu Sep 22, 2022 6:46 pm Post subject: Re: Argh, &%$#$% Engine Install :-( |
I did this all over again with an engine reinstallation this week. It had been awhile, and my notes did not include the tidbit about both putting the transaxle into gear and turning the engine "by hand" with the alternator bolt. One I did both those things, it slipped right in. I have updated my notes. _________________ John
http://vw.tauxe.net
SGKent Samba Member
Posted: Thu Sep 22, 2022 10:11 pm Post subject: Re: Argh, &%$#$% Engine Install :-( |
Good job John. One night we tried 3 times to put a racing engine in. Usually it was a 2 minute transaction but this particular night nothing worked. Frustrated, we pulled the engine out again and tried a 4th time, same angles, same everything and it just slid in. Sometimes they are just a PITA. Sometimes a simple rotation fixes it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
