mas00 Samba Member
Joined: February 08, 2016 Posts: 184 Location: Los Angeles/Texas
Posted: Sun Mar 11, 2018 7:47 pm Post subject: Original Factory Tar/Glue Mats on chassis? |
Hello everyone, I gutted out my bug this weekend and took the sound deadening insulation off the floor boards and there are these thick tar glue like mats that they were stuck to. They are all over the chassis. My uncle told me that they are the original factory that came with the car, can anyone verify this?
They are about 1/16 thick and some parts still glued other parts rock hard and break off. What would be the best way to take this stuff off? I thought a scrapper would do but it's just gonna leave a mess and I don't think it would even take all of it off.
In advance thanks for the suggestions.
Mas
mukluk Samba Member
Posted: Sun Mar 11, 2018 7:56 pm Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
Yes, that is the factory installed insulation. Unless there's a good reason to remove it such as rust that requires attention, I'd say just leave the insulation in place. _________________ 1960 Ragtop w/Semaphores "Inga" |
mas00 Samba Member
Posted: Sun Mar 11, 2018 8:07 pm Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
Well.. I guess my qualm is then what do I do when I remove the body off the chassis and repaint/seal the chassis with POR-15? The whole area in the front is half paint half primer you can see some of the primer on the first photo where the battery sits.. |
mukluk Samba Member
Posted: Sun Mar 11, 2018 8:24 pm Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
You could refinish the areas that need it and leave those that don't alone... or redo the whole thing. It's your car, do with it as you wish. _________________ 1960 Ragtop w/Semaphores "Inga" |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Sun Mar 11, 2018 8:30 pm Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
Save it, you'll never be able to reproduce it. Work around the tar board, get creative Man. you can do it. _________________ 1960 Convertible |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Mon Mar 12, 2018 3:41 am Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
Based on the pictures in your gallery this isn’t a restoration. I’m going to be the voice of descent and encourage you to tear that crap out, clean it up, and por15 it to death. I hesitated on my 64 as it was a dry Texas origin car. When I did begin to scrape up the tarboards I found the beginnings of rust lurking underneath. Zero regrets in doing so as I saved my pans. VW engineered an outstanding car, but these tarboards weren’t the best idea IMO. They can fail after this amount of time and allow moisture underneath which is then trapped and festers. It’s a crappy job, but a 3in1 painters tool and a lot of elbow grease will get you there.
Exception being I wouldn’t mess with the ones on the tunnel. Doubtful there is moisture under them. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
anthracitedub Samba Member
Posted: Mon Mar 12, 2018 7:19 am Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
Get a little bottle torch and a putty knife, heat from the bottom and it chips off p easy. Use a wire wheel to knock off all the little pieces.
I’m willing to bet there is rust forming in the low points of the stampings. |
Balmoral1958 Samba Member
Posted: Mon Mar 12, 2018 8:04 am Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
Agree- if there is any moisture under that tar - it will rust.... not so much much on the tunnel but I had it on may pans - ended up using dry ice and chipped it off- but heating works as well... _________________ 2x 1974 Karmann Ghia Coup
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa |
mas00 Samba Member
Posted: Mon Mar 12, 2018 9:22 am Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
thanks for all the suggestions, this car was built and has been in Texas it's whole life, but I know for a fact we pulled out the passenger side pistons and they have a bunch of crude on the inside rings and a little build up. We can save them due to cleaning and I have a honing tool because it's not much. But I have a strong inner knowing that the whole passenger side of this car will have more build up and weather damage due to how this was stored outside on my uncles land.
I saw a video where someone used a air chisel and that seemed to work wonders. Dry ice and heat was a bit more of a head ache? |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Mon Mar 12, 2018 6:13 pm Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
Believe it or not, EMPI sells a really nice, thick floorboard insulation. You will have to trim it so it fits better though. _________________ If you`re going to do something, do it right. |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
mukluk Samba Member
Posted: Tue Mar 13, 2018 11:02 am Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
Sharp64 wrote: |
I’m going to be the voice of descent... |
You sure you're down with that?
I'm not really seeing where you're voicing dissent, you basically echoed pulling up the insulation where rust is and leaving the insulation where it doesn't need to come off. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Tue Mar 13, 2018 11:10 am Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
mukluk wrote: |
Sharp64 wrote: |
I'm not really seeing where you're voicing dissent, you basically echoed pulling up the insulation where rust is and leaving the insulation where it doesn't need to come off. |
I'll head down the rabbit hole. Unfortunately, there's no way to tell if you have a problem until you remove it. My pans, looked fanfreakintabulous with the OG tar boards. For some reason though I had a hunch and started pulling one up and found rust had started. It was still very slight and came off with a wire wheel, but it was in fact starting. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Tue Mar 13, 2018 3:47 pm Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
I had a Benz coupe that died a rusty death from the floors rotting out. Underside had factory undercoat, inside factory sound deadner. The undercoating got damaged, water got in, and the floor oxidized unknowingly until the passenger seat sank through when someone got in the car. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
mas00 Samba Member
Posted: Tue Mar 13, 2018 6:09 pm Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
I'm probably going to tear the floor out and leave the tar boards where the e-brake and stick shift are. Do yall know of any good replacements? I've read of all types of people using different materials, from yoga mats, to thin sound foam.
thanks |
Posted: Tue Mar 13, 2018 6:27 pm Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
Look up sound deadener. There are lots of options. I used second skin damplifier. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
mas00 Samba Member
Posted: Wed Mar 14, 2018 12:02 pm Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
thanks and what is your overall consensus of second skin damplifier? Did you get what you paid for or is it worth it going with dynamat, hushmat, etc.
Did you go with the pro or just regular? |
Posted: Wed Mar 14, 2018 12:06 pm Post subject: Re: Original Factory Tar/Glue Mats on chassis? |
Meh. It’s ok. I’m not an audiophile or anything. Just wanted something to dampen rattling and interior noise a bit. Probably better/cheaper products out there. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
