TNBUS Samba Member
Posted: Wed Mar 14, 2018 9:38 am Post subject: 1971 Steering Column Rebuild Help Needed |
Trying to correctly assemble/rebuild steering column from a 71 bus-particularly the upper steering shaft portion--any bearings,washers, insulating parts needed?; I think my dashboard mounting bracket/collar is okay-I did not disassemble it. Took column apart to install new ignition switch-that went sriaght forward. Now I am trying to get the horn to work-didn't work when I bought the bus. I can only find a 1968 steering column diagram or a diagram that covers several years--I think 71 had some differences? I am looking for a 1971 specific steering column diagram or even actual pictures of all the parts I may need-there has been some mucking around by previous owners I would like to correct if possible. Any help or input is greatly appreciated. |
TNBUS Samba Member
Posted: Wed Mar 14, 2018 10:11 am Post subject: Re: 1971 Steering Column Rebuild Help Needed |
I found this picture- https://www.thesamba.com/vw/gallery/pix/464322.jpg
I do not have the cup/bearing? at base of the spring or the insulating ring/washer at top edge of the mounting bracket that covers the collar edge and I assume helps to separate the turn signal collar from the mounting bracket. |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3900 Location: Seattle, WA
Posted: Wed Mar 14, 2018 11:24 am Post subject: Re: 1971 Steering Column Rebuild Help Needed |
Steering column changed only in some small details from 1968-1974. There's an exploded diagram of the parts at Fig. 9-12, Front Axle
chapter, in your Bentley service manual. P/N's for bearing, thrust ring/spring seat, and lock housing insulator are 211-415-585A,
113-415-589A, and 211-415-597 respectively. _________________ '67 bug: seized by the authorities
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Miked914 Samba Member
Joined: August 18, 2009 Posts: 127 Location: Santa Clarita, CA
Posted: Fri May 31, 2019 10:11 pm Post subject: Re: 1971 Steering Column Rebuild Help Needed |
In my friends 71 bus, the steering column moves up when turning. I noticed this from the passenger seat. He said he didn't know it was happening. I drove it and its way harder to turn than my bus. Then I grabbed it and just moved it up and down, almost an entire inch. I looked underneath and you can see the rubber coupler flexing up and down. Something has got to be missing here, right? _________________ Mike D.
'68 Fastback w/T4
'74 Porsche 914-6 3.0 Hot Rod
'73 TinTop Westy
'13 VW Sportwagon TDI |
Posted: Tue Jun 04, 2019 2:46 pm Post subject: Re: 1971 Steering Column Rebuild Help Needed |
Anyone? Did a search, can't find another topic about the steering shaft sliding up and down in the column. I think at this point, we are just going to take it apart and compare everything to the diagram. _________________ Mike D.
'68 Fastback w/T4
'73 TinTop Westy
Posted: Tue Jun 04, 2019 4:32 pm Post subject: Re: 1971 Steering Column Rebuild Help Needed |
The flange on the steering box splines might not be clamped tightly like it should be. The rubber
coupler might be torn or just plain shoddy aftermarket stuff - real couplers do not flex very much.
Maybe somebody forgot to put nuts on the coupler bolts. All sorts of possibilities. _________________ '67 bug: seized by the authorities
Dead 1 Samba Member
Joined: October 31, 2005 Posts: 1374 Location: Burning shores of Lake Michigan
Posted: Fri May 29, 2020 5:21 pm Post subject: Re: 1971 Steering Column Rebuild Help Needed |
Anyone know the torque value for the four bolts that go through the steering rubber coupler? _________________ "I reject your reality and replace it with my own"
"The American Dream - true enough because you gotta be asleep to believe it"
71, 1776 cc. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51157 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri May 29, 2020 7:01 pm Post subject: Re: 1971 Steering Column Rebuild Help Needed |
Dead 1 wrote: |
Anyone know the torque value for the four bolts that go through the steering rubber coupler? |
The Holy Green book says 1.5 mkg or 11' lbs _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Dead 1 Samba Member
Posted: Fri May 29, 2020 9:20 pm Post subject: Re: 1971 Steering Column Rebuild Help Needed |
What page? I looked but I guess not good enough. 🤷🏻 _________________ "I reject your reality and replace it with my own"
71, 1776 cc. |
mmqos Samba Member
Joined: November 21, 2010 Posts: 2 Location: palo alto, ca.
Posted: Tue Oct 27, 2020 12:40 pm Post subject: Re: 1971 Steering Column Rebuild Help Needed |
TN:
Did you ever find the parts for your steering wheel and if so where?
I need the same ones and AirHead does not stock. |
mmqos Samba Member
Posted: Tue Oct 27, 2020 1:27 pm Post subject: Re: 1971 Steering Column Rebuild Help Needed |
TN:
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Tue Oct 27, 2020 3:11 pm Post subject: Re: 1971 Steering Column Rebuild Help Needed |
Email Chris Morrice he has a wrecking yard in Oakland/Hayward and you can
Find his info here in the bus parts for sale ad’s
There’s also the bus lab in Berkeley. _________________ V.W.owner since 1967 |
Xevin Samba Member
Posted: Tue Oct 27, 2020 4:11 pm Post subject: Re: 1971 Steering Column Rebuild Help Needed |
PM sent _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
