hylomatt Samba Member
Posted: Thu Mar 15, 2018 9:55 am Post subject: Re: How far to go with a 66 coupe? |
Which you have pretty much done. Seems like it's not a don't but more of a why bother. |
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Thu Mar 15, 2018 10:13 am Post subject: Re: How far to go with a 66 coupe? |
hylomatt wrote: |
ok so i hear the advice. keep the 1600 and the discs. i just hope i can get them to stop squealing one of these days. i'm going to try that hi-temp rtv as suggested above.
i read on the samba that the wheels were actually black so i have since painted them black but w/o beauty rings. any suggestion on where to find a set of them? i called wolfsburg west but they said that the ones they currently sell are stainless and junky. they didn't have the nicer ones currently.
i'll just put the trim back into the front and rear window rubbers and continue with the interior changes. someone painted the chrome strip on my dash black, probably because the chrome started to flake off. i'll replace that 68 dash pad too so i can get the dash handle back and look more like a 66. |
Sounds like a good plan. For redoing the chrome strip see what it looks like after stripping. If the chrome is bad you may want to consider having it done with spray on chrome. Its far cheaper than traditional rechroming and is ideal for trim pieces like this. _________________ Ghia Owner Emeritus |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Thu Mar 15, 2018 11:02 am Post subject: Re: How far to go with a 66 coupe? |
YOU, want to do it properly so you have 90% of the battle won. All the advice you have been given comes from Ghia lovers so accept it as it comes. Make the car look and feel the way you want it too and enjoy it every chance you get. The purists and thoroughly seasoned Ghia owner/expert will the ones who notice the differences, but only the purists will take exception. _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Thu Mar 15, 2018 11:13 am Post subject: Re: How far to go with a 66 coupe? |
Thanks Evil_Fiz!
Anyone know where I could pick up some decent beauty rings? |
Posted: Thu Mar 15, 2018 11:15 am Post subject: Re: How far to go with a 66 coupe? |
Thanks to NOVA as well. Yeah I've been thinking about stripping them to see what's under the black paint. |
Posted: Thu Mar 15, 2018 11:57 am Post subject: Re: How far to go with a 66 coupe? |
My dash:
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
theghiagirl Samba Member
Joined: February 15, 2004 Posts: 537 Location: Near Portland, OR
Posted: Thu Mar 15, 2018 2:03 pm Post subject: Re: How far to go with a 66 coupe? |
It looks like the previous owner may have replaced a section of the engine bay sheet metal. That section just in front of the air-cleaner with the bump on it should be flat up to 1967. I believe this sheet metal was changed in 1968 when they added the auto-stick canister set-up. |
Posted: Fri Mar 16, 2018 9:50 pm Post subject: Re: How far to go with a 66 coupe? |
This just keeps getting better |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Sun Mar 18, 2018 11:26 am Post subject: Re: How far to go with a 66 coupe? |
Quote: |
Various engine area right rear plates....
Up through 1965 |
Actually the engine bay side panels were 2 types up thru 64 1/2 model year (still in '64 cal. year). Earlier style had a large rectangular depression with an embossing in it. Front edge of the depressed area went just about all the way to the rear of the wheelwell hump. Right side would be nearly mirror-image other than the battery clamp retaining lip:
'64 1/2 thru '65 style had smaller depression without any embossing:
'66 would have the same as '65 except the battery clamp lip moved to the left side of the engine compartment, and the right side received the air cleaner stand.
Yes, theGhiaGirl knows her Ghia details!
Hylo, hope you can find a good quality set of the beauty rings for your Ghia. Try NOS, or BugCity here in USA (https://www.bugcity.com/shop/shop.lasso?pquery=beauty+rings). The shape of the cooling slots are larger/wider on the rings for 4-bolt wheels compared to the ones on a '66-only Ghia. 4-bolt wheels have either 8 slots. The slots on a '66 rings are more like small sausages- thin and long. 10 slots total. It appears that you have 4.5" wide deep-dish steel wheels which can influence the choice of ring sets, because the hubcaps sit deeper in the wheel center compared to the outer rim than on other wheels. 9556GR should work with those wheels. Once you have the rings on your 4-bolt rims together with your current hubcaps, the car will look fine. It'll actually look like a '67 Ghia from a distance because '67s did not have any side marker reflectors on the rear quarter panel, and were the first year to have the wide-track rear axle like the '68 rear axle on your pan. |
Posted: Sun Mar 18, 2018 1:56 pm Post subject: Re: How far to go with a 66 coupe? |
Thanks Rome and theghiagirl. I think I'm going to go for the "border rings" rather than the slotted rings. This style: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=ZVW34WW
What do you guys think of that style?
Rome, I'll have to check on the axles. I'm not sure if they're short or long style but the vehicle still has a swing axle transmission. |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Sun Mar 18, 2018 3:25 pm Post subject: Re: How far to go with a 66 coupe? |
I kinda like the look of those but you have to commit to them permanently, the only thing that holds them on are spring loaded steel teeth, they will scar the paint & even the wheel themselves. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Mar 18, 2018 5:01 pm Post subject: Re: How far to go with a 66 coupe? |
I didn't know those were only for early ghias. I really haven't found much information about when and when they did not belong. They just really caught my eye was all. |
Posted: Sun Mar 18, 2018 5:41 pm Post subject: Re: How far to go with a 66 coupe? |
Thank you djkeev, I see now. So since the chassis change, the wheels are 4 lug, of course the slots on those wheels don't match what should be on a 66.
I guess I could swap out the rear drums for 5 lug drums. And maybe look for 5 lug rotors for the front. Then I'd be able to put the right wheels back on it with matching trim rings. |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Mon Mar 19, 2018 12:05 am Post subject: Re: How far to go with a 66 coupe? |
djkeev wrote: |
I've never seen five lug disc. The size makes this nearly impossible hence the four lug change.
Again, only the sharpest tacks in the box will be counting trim ring slots.
Dave |
You can get aftermarket bolt on wide 5 disc conversion kits for both king and link or ball joint front ends. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon)
Last edited by Mellow Yellow 74 on Mon Mar 19, 2018 3:58 am; edited 1 time in total |
