HENDO Samba Member
Joined: November 23, 2012 Posts: 202 Location: Spring Branch, TX
Posted: Thu Mar 15, 2018 12:19 pm Post subject: Tach Wiring to engine compartment??? |
I have an 84 with a tach. From what I understand the 9th pin in the connector on the back of the dash panel is supposed to be green. Mine is not. It is red/black. I was told this 9th pin is for the tach.
I am trying to hook my tach back up while doing an engine conversion and I have no green wires in the engine compartment junction box which is what I was told to look for.
Any ideas?
Thanks. _________________ 84 Westy AKA "Sludge" |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Thu Mar 15, 2018 12:23 pm Post subject: Re: Tach Wiring to engine compartment??? |
Yes, in 84 Wolfsburg models VW used a red/black wire for the tach. The engine end of that wire run is on the ignition coil. What color wires do you have plugged into each side of the coil?
Mark |
HENDO Samba Member
Posted: Thu Mar 15, 2018 12:27 pm Post subject: Re: Tach Wiring to engine compartment??? |
Well...my coil has been removed.
This is where I am right now in the process...
Posted: Thu Mar 15, 2018 12:34 pm Post subject: Re: Tach Wiring to engine compartment??? |
Look inside the black engine compartment wiring box. You may need to use a meter to find the exact wire.
Mark |
HENDO Samba Member
Posted: Thu Mar 15, 2018 12:37 pm Post subject: Re: Tach Wiring to engine compartment??? |
OK. I messed around trying to find it last night but this was after being out in the garage working on this install for about 10 hours. I was exhausted. I will get back out there this evening and give it a go.
HENDO Samba Member
Posted: Fri Mar 16, 2018 7:57 am Post subject: Re: Tach Wiring to engine compartment??? |
I found it...red/black in the connection box.
😎 _________________ 84 Westy AKA "Sludge" |
