Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Thu Mar 15, 2018 12:39 pm Post subject: Converting to u Joint |
Any tips for converting to u Joint steering on a 69 baja using the stock steering shaft? I'd like to keep the blinker switch and everything that's in the car. Could I cut off the colapsable part of the steering shaft and use a weld on u Joint? I'd prefer to use something that could be replaced without more cutting and welding should a u Joint fail or something. Thank you. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20377 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Mar 15, 2018 1:11 pm Post subject: Re: Converting to u Joint |
I believe Borgeson makes a set of joints that are for steering applications....With your concept you will probably ave to add a bearing at lower end of steering column and put a solid plug in end of shaft for joint to clamp to....
https://www.google.com/search?q=Borgson+steering+u...p;ie=UTF-8
Believe the are available most any upscale parts places, would look at Summit Racing or JEGS or someplace specializing in off road steering...
Dale
Edited for clarity. _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Thu Mar 15, 2018 1:34 pm Post subject: Re: Converting to u Joint |
Dale M. wrote: |
I believe Borgeson makes a set of joints that are for steering applications....With your concept you will probably ave to add a bearing at lower end of steering and put a solid plug in end of column for joint to clamp to....
Dale |
They carry those at my local bug place, I'm going with a rack and pinion on the new beam in my baja and I probly should have worded my question better. I'm more concerned on how to connect the u Joint to the stock steering shaft above the colapsable portion. |
plotch Samba Member
Joined: December 22, 2004 Posts: 539 Location: jeffersonville, vermont
Posted: Thu Mar 15, 2018 3:36 pm Post subject: Re: Converting to u Joint |
And hopefully designed so that in the event of a front end crash the steering wheel will hit the roof and not your chest. Good luck and post some pictures please. |
Posted: Thu Mar 15, 2018 6:21 pm Post subject: Re: Converting to u Joint |
plotch wrote: |
Well if I cut the stock shaft just behind the collapsible portion the angle of the u Joint will be close to 40 degrees I think. So if it does come to a front end crash I think the shaft will move towards 90 degrees vs pushing the steering wheel into the car. Either way there's no way or room to leave the collapsible portion unless I use the stock shaft and extend it. We shall see once I get some parts and the tank pulled out of the way. |
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 350 Location: Green Bay, WI
Posted: Thu Mar 15, 2018 8:23 pm Post subject: Re: Converting to u Joint |
Use a Super Beetle steering column, it's already set up for a U-joint. I believe the U-joint spline also matches the Standard Beetle steering box, but the shaft may need to be lengthened/shortened. _________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
Posted: Tue Mar 20, 2018 12:35 am Post subject: Re: Converting to u Joint |
vwfreek61 wrote: |
Use a Super Beetle steering column, it's already set up for a U-joint. I believe the U-joint spline also matches the Standard Beetle steering box, but the shaft may need to be lengthened/shortened. |
The old lady would probly leave me if I got rid of the screwdriver turn signal lever haha. I'm semi restricted to what I can do to the car. It was given to us by her father who built it 30 years ago and it was her first car blah blah blah... anyways I got the beam, ordered the adapter and have to get some steering and brake parts to run new brake lines. Also have to figure out if I can raise the fuel tank or have to go with one of those aluminum or stainless buggy tanks. I also contiplated buying a bender and bringing the cage out to the beam but the welder I have access to is a 110v non gas mig and I'm not 100% confident with it. I'll keep you guys posted on how it goes and take pictures, going to be a few weeks gathering parts and materials. |
cbeck Samba Member
Posted: Tue Mar 20, 2018 3:34 am Post subject: Re: Converting to u Joint |
Bender-pick up 180*dies, buy once cry once.
Welded with handler 140 w/flux core wire. It's a step up from the old lincoln buzz box I used in the early 80's, but still a pain to clean up.
_________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
Axitech Samba Member
Joined: August 31, 2011 Posts: 1265 Location: Bucks County, Pa
Posted: Tue Mar 20, 2018 5:34 am Post subject: Re: Converting to u Joint |
I got tired of replacing turn signal switches because my boot kicked it when climbing in. I put signal switch on a standard three position switch between the seats. Much easier to use too once you ‘learn’ the muscle memory for its location. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson |
Posted: Tue Mar 20, 2018 12:59 pm Post subject: Re: Converting to u Joint |
Since we all like pictures this is the beam I picked up for $500
cbeck Samba Member
