jacksonp32 Samba Member
Joined: November 28, 2015 Posts: 377 Location: fort collins
Posted: Fri Mar 16, 2018 4:08 pm Post subject: can’t get into gear? |
hey all. i was just driving my car for about a hour and one i cost to my destination in the parking lot i began having issue getting into first and second gear. sometimes it would not go in at all and i needed to try like say 5 times for it to actually go in. after i parked i tried shifting into gears and i still had the same problem where it would not want to go in for a few attempts then it would work totally fine for a few tries, then wouldn’t again. any idea what this could be? |
andrewvwclassic Samba Member
Joined: January 25, 2012 Posts: 920 Location: los angeles
Posted: Fri Mar 16, 2018 4:55 pm Post subject: Re: can’t get into gear? |
Check to see if the bolts are tight that secure the shifter as well as the shift rod bushing wich I am sure is bad. last but not least remove inspection plate in rear seat area and check the linkage. These bushings never go bad.
https://www.youtube.com/watch?v=RF92BYupbw4
Last edited by andrewvwclassic on Fri Mar 16, 2018 4:58 pm; edited 1 time in total |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11739 Location: Redding, CA
Posted: Fri Mar 16, 2018 4:56 pm Post subject: Re: can’t get into gear? |
Shift rod bushing needs replacement, and/or the coupler.
You might even have loose bolts at your shift housing, but I’d bet it’s the shift rod bushing is shot.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5360 Location: Lefty, CA
Posted: Fri Mar 16, 2018 9:16 pm Post subject: Re: can’t get into gear? |
thank you everybody for the responses! i will look into it the next few days and post results! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24671 Location: Olympia Wash Rinse & Repeat
Posted: Sat Mar 17, 2018 7:33 pm Post subject: Re: can’t get into gear? |
Could also be you need to adjust for proper clutch pedal play. _________________ In Stereo, Where Available! |
Posted: Tue Mar 20, 2018 11:32 am Post subject: Re: can’t get into gear? |
Just checked it out. The shifter was completely loose! tightened the two bolts and it was perfect! easy fix! thanks everyone! |
Posted: Tue Mar 20, 2018 11:58 am Post subject: Re: can’t get into gear? |
jacksonp32 wrote: |
Great that it was an easy fix! Still do check your pedal play and adjust as needed. Keeping it in the proper range makes for longer lasting clutch friction surfaces and less long term damage to the transaxle. So better to check it now and then, like at tune up time. _________________ In Stereo, Where Available! |
