btracy Samba Member
Posted: Fri Mar 16, 2018 6:39 pm Post subject: Rear axle seal |
ive read a lot of post on here on rear bearings but cant find nothing on how to remove inner axel or bearing seal.1971 sb.
thanks for your input. |
andrewvwclassic Samba Member
Joined: January 25, 2012 Posts: 920 Location: los angeles
Posted: Fri Mar 16, 2018 7:15 pm Post subject: Re: Rear axle seal |
Do you have a swing axle or IRS? |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sat Mar 17, 2018 6:03 am Post subject: Re: Rear axle seal |
The inner one is usually the one that needs replaced since they rarely get greased. Been quite a while since I did one, so bear with my memory. You need to push out the stub axle. I like to clean up the lip on the axle that goes around the seal since they are usually chewed up some. Pretty sure the seal itself is easy to pop off. Also there is a spacer tube that runs between the bearings...The one thing I missed the first time I did one was there is a snap ring holding the bearing in place that needs removed before you try to tap the bearing out. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Dark Earth Samba Member
btracy Samba Member
Posted: Sat Mar 17, 2018 9:08 pm Post subject: Re: Rear axle seal |
vice grips grab and rip |
btracy Samba Member
now need to find them original vw seals |
