annieq Samba Member
Joined: May 06, 2007 Posts: 41 Location: Savannah, Georgia
Posted: Sat Mar 17, 2018 5:48 am Post subject: propane heater fan |
What would cause my propane heater blower to turn on when the van is parked and the thermostat is turned off? I believe it is the cause for my battery running down... _________________ curlygirl and the sandeeman |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Sat Mar 17, 2018 12:49 pm Post subject: Re: propane heater fan |
Don't know- just got my Eurovan full camper, and MY heater fan won't come on, cso I can't get it heating. Just spent 3 nights from Colorado to DC w/o heat.
To you older-timers familiar with such problems. The aux battery seems alive, but the switch doesn't bring the fan to life. If it's a fuse, where is that fuse? Can I put a jumper to the wire actually running to the fan so I know the fan motor still works-- where would I try to tie in to it? Thanks. -Chris (old Vanagon guy moving an era closer to get some new creature comfort.) |
annieq Samba Member
Posted: Sat Mar 17, 2018 1:02 pm Post subject: Re: propane heater fan |
So does that blower run off the auxiliary battery?? I don’t have a manual so I’d appreciate any pointers out there! _________________ curlygirl and the sandeeman |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Sun Mar 18, 2018 8:19 am Post subject: Re: propane heater fan |
The furnace shouldn't run unless your thermostat on the wall is telling it to. The more likely cultprit is the propane alarm running down your battery over time...
how old is the battery?
But hey, you may need to replace that thermostat too... here's a walkthrough:
https://www.thesamba.com/vw/forum/viewtopic.php?p=7458773
As for the furnace fan not working at all? it could be that you need a new thermostat as well... or your fan is siezed. here's a walkthroughon replacing that:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8373156
The fan blower for the furnace runs off your aux battery (it would kill the car otherwise). Youv'e got about 7-8 hours of furnace time on a full charge with a 29dc deep cycle battery and you'll eat through about a half gallon of gas if you're running it that long. _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
