fxshov Samba Member
Posted: Sat Mar 17, 2018 7:02 pm Post subject: What vacuum psi pressure does a brake booster require? |
I put new new dual carbs on my 71 bay. No port for the brake booster is supplied. I'm not drilling and tapping a hole in my manifolds. I want to add a separate vacuum pump. Does anyone know what vacuum psi the brake booster requires? _________________ GOOD AINT CHEAP AND CHEAP ANIT GOOD
73 Bay Window
05 Tundra
12 Scion
93 HD Softtail
18 NX 2500
I need a bigger garage. |
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Sat Mar 17, 2018 7:06 pm Post subject: Re: What vacuum psi pressure does a brake booster require? |
-18 to 22 in Hg _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
fxshov Samba Member
Posted: Sat Mar 17, 2018 7:13 pm Post subject: Re: What vacuum psi pressure does a brake booster require? |
thanks _________________ GOOD AINT CHEAP AND CHEAP ANIT GOOD
73 Bay Window
05 Tundra
12 Scion
93 HD Softtail
18 NX 2500
SGKent Samba Member
Posted: Sat Mar 17, 2018 7:35 pm Post subject: Re: What vacuum psi pressure does a brake booster require? |
it better be a big vacuum pump to be able to refresh after a couple brakes. Probably will want to add some kind of a reservoir to keep the pump from being over whelmed. Worst case is you would run out of vacuum coming down a grade or stop and go traffic. For you probably not a problem. For your wife - mmmmm? Only need to tap one side. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
scubaseas Samba Member
Joined: May 24, 2013 Posts: 442 Location: ME & Texas, in a Bus or on a boat somewhere
Posted: Sat Mar 17, 2018 8:25 pm Post subject: Re: What vacuum psi pressure does a brake booster require? |
Turbo Volvo electric pump circa 2007 should be big enough. You will also need a pressure switch to activate the pump. And a relay. And a fuse, A reservoir might be an idea as well if not tapping into the manifold/s.
I have had duals for years and tapped the manifold. Never had a problem with the booster loosing power. _________________ Al
08/1970 T2a Westphalia owned since 1980
ASE Master certification. 50 years pushing a wrench
Retired |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun Mar 18, 2018 9:37 am Post subject: Re: What vacuum psi pressure does a brake booster require? |
I have a ‘71 with dual Kaddies. I run the booster off a tee in the balance tube. It works great. I urge you to reconsider. Tapping the manifold would be the simpler and therefore least likely to fail option. Either way, best of luck to you! _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon Mar 19, 2018 7:20 am Post subject: Re: What vacuum psi pressure does a brake booster require? |
none... How sensitive do you want your brakes? _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
fxshov Samba Member
Posted: Mon Mar 19, 2018 7:59 am Post subject: Re: What vacuum psi pressure does a brake booster require? |
currently running it without. Kinda reminds me of driving all the old trucks Ive driven. So, anything is an improvement.. _________________ GOOD AINT CHEAP AND CHEAP ANIT GOOD
73 Bay Window
05 Tundra
12 Scion
93 HD Softtail
18 NX 2500
Posted: Mon Mar 19, 2018 9:50 am Post subject: Re: What vacuum psi pressure does a brake booster require? |
Many diesel automobiles had electric vacuum pumps for their brakes. Personally I would do as others suggested and just tap the manifolds or tie into the balance tube. |
camit34 Samba Member
Joined: January 14, 2006 Posts: 1567 Location: Commerce City CO
Posted: Mon Mar 19, 2018 10:49 am Post subject: Re: What vacuum psi pressure does a brake booster require? |
Wildthings wrote: |
I'm putting a single Dell on my '71 Bus and went through this in my mind and here is what I came back with.
Purchase extra crap...
Mount extra crap...
Wire in extra crap...
Maintain extra crap...
Drill & Tap some aluminum...
I'm going with the latter.
Good luck in whatever you chose and if you do go the pump route, please document and post the pieces you use and the process for mounting it and getting to work, I'd be interested in seeing that. _________________ In search of a Vanagon
1971 Westy (SOLD)
1971 Deluxe (SOLD)
1967 Freedom Camper (SOLD)
Danwvw Samba Member
Posted: Mon Mar 19, 2018 12:54 pm Post subject: Re: What vacuum psi pressure does a brake booster require? |
That's about how I feel about adding a Vac Pump to my 71 Bus! I drilled holes in both the #1 and the #3 but realized they may not like sharing Thought about Check valving them both before connecting together. Wound up plugging #1.
It actually works really well on just #3.
Cheap end castings may be a problem, drilling mine I found they were very thin and the aluminum internal structure is crystallized pretty course, not real strong. They did thread ok but I used J-B Weld to seal the threads. It was a good decision.
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
Posted: Mon Mar 19, 2018 1:58 pm Post subject: Re: What vacuum psi pressure does a brake booster require? |
Danwvw wrote: |
It actually works really will on just #3.
Just use a welder to build up a thick area where you can drill and tap. |
SGKent Samba Member
Posted: Mon Mar 19, 2018 6:58 pm Post subject: Re: What vacuum psi pressure does a brake booster require? |
tying the two sides together is commonly called a balance tube. Helps smooth out things. One can put a tee in it for the booster too if one has a balance tube. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
