Longmont1302 Samba Member
Joined: October 01, 2015 Posts: 324 Location: Longmont, CO
Posted: Sat Mar 17, 2018 9:09 pm Post subject: Forest Find 1961 Mouse Grey 11-Window Standard |
I’m belatedly starting a thread on this bus:
The floors are rusty, it has no glass, and it’s been painted with a broom (by children) several times. They even painted the engine: It lived its entire life at a children’s camp in Minnesota, where my dad works summers as a handyman. The camp’s owners bought it new in Germany and had it shipped to the states. I believe it was last licensed in 1998. When my dad mentioned I was interested in the bus, the owner generously gave it to him as a gift. My only problem is that I live 1000 miles away in Colorado.
One of my coworkers, Corinna, owns a 1960 Beetle. When I mentioned to her I could own a 1961 11-window standard if I could only find a way to drag it home, she said she and her partner had a truck and trailer and they’d be glad to help. I thought she was joking, but she wasn’t. We left on Friday afternoon and arrived at lunchtime on Saturday. My dad and his friend helped us out. They had moved the bus a little and replaced two tires, but couldn’t get it out of gear: the cabin floor is so rusty there’s nothing to bolt the shifter on. Nevertheless, in short time we got it on the trailer and headed west.
In hindsight, I should have removed the battery, as it bounced its way through some rust on the way. We received a lot of attention on the trip, mostly by Batman fans. I also wish we’d had time to go through a car wash (particularly to spray some gunk on the engine), but we made it home safe and sound by dinner time Sunday.
I have begun the process of taking the house paint off. Underneath I found the original mouse grey. So far one of my favorite methods is Citristrip Gel, towels, and a plastic scraper. Before it got too cold I got most of the aftermarket paint of the rear and much of the passenger side. It’s still a work in progress: the last bits of paint are the trickiest to remove without taking the OG paint, too. I’m hoping to perfect my paint removal technique before I attempt the nose. With some Samba help, I also managed to bust the shift coupler apart so I could hope to turn the engine.
During a December visit, my dad and I set a goal to start the engine (likely for the first time since the late 1990s). To prep, I replaced the plugs, wires, coil, and distributor cap, and did my best to rebuild the carburetor and fuel pump. When the fuel pump didn’t work, we just ran the hose to a gas can positioned above the carburetor. With a little help from my neighbor Bill, we made it happen:
https://www.youtube.com/watch?v=Ip_vM_8qaR4&feature=youtu.be
Since then I’ve got the fuel pump working (finally had to spend the big bucks on a WW diaphragm) and set the valves. This weekend I tested the compression: #1: 95 lbs, #2: 95, #3: 85, and #4: 90. Given that we're at 5,000 feet and the battery was nearly dead, I figure this is better than I could have hoped for after sitting in a field for 20+ years.
My goal is to get the aftermarket paint off, replace or clean the gas tank, replace crucial sheet metal (engine compartment, cabin floor), do the brakes, possibly replace the wiring harness, and otherwise do the absolute minimum necessary to drive the thing around the block with these guys. Repeatedly.
My next step is to pull the engine. While I have a Bentley manual, if anyone could point me to more detailed split bus engine removal instructions (suitable for a for a first-timer) I’d be grateful. |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Sat Mar 17, 2018 9:20 pm Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
how does the M-code plate read on this bus?
1961 Mouse grey buses are something special. _________________ .
Wanted:
Posted: Sat Mar 17, 2018 9:30 pm Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Lind wrote: |
how does the M-code plate read on this bus? |
Let me know if this isn't in focus enough:
Lind Samba Member
Posted: Sat Mar 17, 2018 11:01 pm Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Longmont1302 wrote: |
Lind wrote: |
Awesome. Like most of the other '61 mouse grey standards, it is a tourist delivery bus. Looks like 2 popouts, and USA specs of course. The plate on my '61 reads almost exactly the same, except mine got 6 popouts.
https://www.thesamba.com/vw/forum/album_page.php?pic_id=434605
I still have not seen a '61 mouse grey that was delivered to the USA. There is a single known Canadian delivered '61. _________________ .
Wanted:
AC Mack Samba Member
Joined: October 11, 2007 Posts: 369 Location: Redwood Highway Caught in the Devils Bargain
Posted: Sat Mar 17, 2018 11:04 pm Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Interesting M -Code 156 indicates ----- Second rear view mirror / Also used on Tourist Delivery Program.
I realize this is probably in reference to a outside passenger side mirror.
Is that a mirror above the passengers head ?
_________________ 1959 Model M1: 118
1964 Model 265
1965 Model 251 Deluxe walk thru
1966 Westfalia so42 Schiebedach fabrik 4864
1967 Model 231 EZ Kamper # 1940
1978 Westfalia P 31 / 1987 Westfalia Wolfram Grau
Split Bus Club / Lost Coast Bays / North Coast Vans
Long may that Split Bus run!
Always and Everywhere Volkswagen |
Burlyhammer Samba Member
Joined: March 07, 2002 Posts: 1693 Location: Great north woods Maine
Posted: Sun Mar 18, 2018 5:14 am Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Awesome bus. Looks like you’re on the right track and well on your way. |
obus Samba Member
Joined: March 08, 2001 Posts: 11070 Location: just off Garden State Parkway Exit 81
Lind Samba Member
Posted: Sun Mar 18, 2018 7:58 am Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
AC Mack wrote: |
[img]https://www.thesamba.com/vw/gallery/pix/1758290.jpg |
I think that the M156 = second rearview mirror is from a different model or year. For some unknown reason they stamped USA bound tourist delivery plates with a different style than normal USA delivered plates. I believe that M139 and M156 are standard on USA delivered buses, but are just wrapped into the 300 series USA spec code. Also a tourist delivery bus says M GRAU, while a USA delivered bus says M GREY. They stamped it to match the language of the first destination, not the final destination. _________________ .
Wanted:
Clara Samba Member
Posted: Sun Mar 18, 2018 8:35 am Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
.................It lived its entire life at a children’s camp in Minnesota, where my dad works summers as a handyman. The camp’s owners bought it new in Germany and had it shipped to the states. I believe it was last licensed in 1998. When my dad mentioned I was interested in the bus, the owner generously gave it to him as a gift.
Awesome look on your dad's face at about 13 sec. !!!
Get an Idiot Book for instructions on pulling the motor. Very user friendly for the non mechanic. It was first published in '69, so these were cheap used cars and it was written for the average owner to take car of services etc.
FWIW, you can manually change gear under the bus by moving the shift around under the front floor. Not while you are driving, of course, but when it's parked, to get it in neutral.
https://www.thesamba.com/vw/classifieds/search.php...ton=Search |
Posted: Sun Mar 18, 2018 9:13 am Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Thanks to all for the encouraging words.
AC Mack wrote: |
Yes. It's missing the mirror itself, but it's a cool contraption:
Posted: Sun Mar 18, 2018 9:21 am Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Clara wrote: |
Awesome look on your dad's face at about 13 sec. !!! |
Thanks, Clara. That's actually my neighbor, but it is a great smile. My dad was right there, too. He was only visiting for a few days, and this was the morning he had to leave, and in the 23rd hour we got the distributor to move and made it all work. Good times. |
Manfred58sc Samba Member
Posted: Sun Mar 18, 2018 9:31 am Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Cool Bus, and great story! _________________ Fat chick owner/operator |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Sun Mar 18, 2018 10:14 am Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Your kid's faces is the best picture I've seen in awhile. That inside mirror looks like an original VW bus outside mirror. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Sun Mar 18, 2018 1:12 pm Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Car quest carb cleaner worked great for removing house paint from a car that I had once without attacking the original paint. Acetone worked great on getting a repaint off of the original without attacking the original on my bus. Try in an inconspicuous spot first. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Mar 18, 2018 5:16 pm Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Cool Bus !!! Could you possibly post a pict of the dash ? Thanks _________________ 1959 Model M1: 118
1964 Model 265
srfndoc Samba Member
Posted: Sun Mar 18, 2018 5:22 pm Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
AC Mack wrote: |
Cool Bus !!! Could you possibly post a pict of the dash ? Thanks |
I was thinking the same thing.... does it have a MG dash? _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Mar 18, 2018 5:41 pm Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Bentley publishes many manuals. Which one do you have?? _________________ In Stereo, Where Available! |
Posted: Sun Mar 18, 2018 8:36 pm Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
AC Mack wrote: |
You betcha. I have some more paint removal to do here, and the ash tray is toasty.
Posted: Sun Mar 18, 2018 8:37 pm Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
Eric&Barb wrote: |
Bentley publishes many manuals. Which one do you have?? |
The big blue 1950-1962 Workshop Manual. |
Posted: Sun Mar 18, 2018 8:42 pm Post subject: Re: Forest Find 1961 Mouse Grey 11-Window Standard |
BarryL wrote: |
Your kid's faces is the best picture I've seen in awhile. |
Thanks. My 9-year-old totally has the "Alfred E. Newman meets Ed Roth monster-driving-a-hot-rod" look figured out.
BarryL wrote: |
Huh. Never thought of that. |
