MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4087 Location: East Kootenay, British Columbia
Posted: Mon Mar 19, 2018 8:45 am Post subject: Re: Knocking from rear end |
Wildthings wrote: |
MsTaboo wrote: |
fxr wrote: |
MsTaboo wrote: |
Definitely keep the old axle if replacing with cheap FLAPS part.
Remember to label the axle for transaxle side and wheel side. This is so the axle goes back in with the same torque twist direction.
Only if swapped to the other side of the van, surely? Swapping trans-axle to wheel on the same side doesn't change the thrust direction inside the CV. |
The idea is to keep the torque direction the same on the axle. |
How often does a bus axle fail for this reason? Don't think I have ever heard of an instance. Guess you should never downshift on a hill either if this particular failure is a concern to you. |
It's just standard good practice. There have been failures, mostly heavily loaded Syncros, but why tempt fate?
Read the part about axle orientation. (yes I know, that's a sand rail page, but consider how small our axles are for the load)
http://moira.meccahosting.com/~a0008423/cv_clocking.htm _________________ Currently:
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Mon Mar 19, 2018 9:05 am Post subject: Re: Knocking from rear end |
Be sure to double check the axle rotation changes if any are made. It's more than keeping the rotation the same, in fact the true desire is to reverse the torque direction on each CV to start wear on a fresh surface. However, this is trickier than you'd think and I highly recommend someone talking to a tech bring in the diagram from the Van Cafe article (unsure if its up on the new website with RMW) showing how to do this correctly.
On the art school in the woods. Wow. Small world. My girlfriend attended that one magical summer. Very cool place with powerful and beautiful memories of things I treasure to this day. Thanks for mentioning it.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Mon Mar 19, 2018 10:53 am Post subject: Re: Knocking from rear end |
Switch CVs left to right, leave the axles on the same sides.
The knocking on my Syncro Westy comes from worn lower shock mounting bolts (and steel bushing sleeves) on HD rear shocks .. a simple job I've postponed for no good reason. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1115 Location: over by 'der
Posted: Tue Mar 20, 2018 12:40 am Post subject: Re: Knocking from rear end |
Switching the axles around but leaving them on the same side will not change the direction of force applied. The only way to do it is to change the drivers side axle to the passenger side and vice versa. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
gears Samba Member
Posted: Tue Mar 20, 2018 8:37 am Post subject: Re: Knocking from rear end |
.. which is exactly why you want to leave the axles on the same side, while swapping only the CVs from side to side. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
fxr Samba Member
Joined: December 07, 2014 Posts: 2321 Location: Bay area CA
Posted: Tue Mar 20, 2018 9:03 am Post subject: Re: Knocking from rear end |
gears wrote: |
.. which is exactly why you want to leave the axles on the same side, while swapping only the CVs from side to side. |
Ah, I get what you mean - leave the axles on the same sides (you have to with an automatic anyway I gather) but swap the CVs from driver's side to passenger side and vice versa.
On a manual you might just as well swap the axles as well of course... _________________ Jim Crowther
Vespa GTS 300 |
Posted: Tue Mar 20, 2018 9:19 am Post subject: Re: Knocking from rear end |
The OP has already established he has a manual. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
gears Samba Member
Posted: Tue Mar 20, 2018 9:20 am Post subject: Re: Knocking from rear end |
Yes. I'm not an axle expert, but in dragracing it was well known that changing axles side to side would lead to premature failure. As I often hear of broken axles when off-roading Syncro vans, I have to wonder if those broken axles had changed sides at some time. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Posted: Tue Mar 20, 2018 5:23 pm Post subject: Re: Knocking from rear end |
Gears,
Was that drag racing with solid axles, or with independent CV type axles? I could see solid axle shafts having been twisted with use, then reversed and they'd perhaps take less energy to "untwist" with torque and then end up twisted in the other direction causing point stresses here and there. And a bang.
On the CV's the purpose is to cause the ball to switch sides in the cage and start wearing a groove in the opposite ramps. So it always made sense to me to do it the way Van Cafe's site specified (including diagrams). It is SOOOOO easy to do this wrong, and I did it once before double checking the diagram and having to move things around.
Gears, you'd appreciate this. Last night my son Dirk (whom you've met) and I finished working on what will be his Supra in the garage by sitting and watching an episode of the Hoonigan's website showing the Donut Garage and cars doing burnouts. They showed in slow mo a perfect example of axle windup and release on an old rat rod. It was cool. Also, a guy in a Porsche 912 with a 6 cylinder stuffed into it shatters a custom aluminum drive shaft. Lots of carnage!!
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Mar 20, 2018 6:42 pm Post subject: Re: Knocking from rear end |
IdahoDoug wrote: |
...Hoonigan's website showing the Donut Garage and cars doing burnouts...
...in slow mo a perfect example of axle windup and release on an old rat rod... |
Cool, indeed! Share...???!!!???
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
E1 Samba Member
Joined: January 21, 2013 Posts: 6543 Location: Westfalia, Earth
Posted: Tue Mar 20, 2018 9:31 pm Post subject: Re: Knocking from rear end |
+1 on the share. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Wed Mar 21, 2018 12:29 am Post subject: Re: Knocking from rear end |
What is going to break the axle is the difference between the maximum forward torque and the maximum reward torque on the axle. Swapping the axles side to side would effectively be increasing the maximum torque differential. For a high powered dune buggy lets say the axle can handle only 10,000 full load cycles before it would break, but on a stock van in street use where the maximum loads might be half or even a third of what a dune buggy or off road crawler sees, the number of cycles the axle can with stand might well be in the hundreds of millions or essentially infinite.
Most every rear engine VW out there has had the axles moved from side to side multiple times over the years and there is no epidemic of axles breaking that I have heard of and I don't think that the epidemic will suddenly start tomorrow. |
Posted: Wed Mar 21, 2018 12:35 am Post subject: Re: Knocking from rear end |
Though I can understand how that could happen, I don't think that anyone in a vanagon who isn't drag racing has anything to fear concerning swapping axles. I would think that the CV joints would be the most vulnerable point on the axle and would give out before the shaft itself. especially on those who are running abnormally high lifts and wheels. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
Posted: Wed Mar 21, 2018 9:44 am Post subject: Re: Knocking from rear end |
Dhaavers/E1,
Don't say I didn't warn you. If you have never seen this bunch, you will not be able to stop laughing and watching their automotive mayhem. It's Ken Block's (rally champion) garage, staffed by a bunch of auto enthusiasts with a destructive slant. Automotive icons and celebrities are encouraged to stop by with hot cars and do burnouts, or try to get up the loading ramp burning rubber, cross the cargo area, get through a narrow concrete doorway into the shop, spin come back out the door still burning rubber, get back to the parking lot and do donuts in its narrow confines, etc. Its a tiny lot in LA which leads to unexpected drama when they run out of room. You will see engines blown, tires shredded, priceless classics do $50,000 in damage in 3 seconds, etc.
They talk these people into jumping their cars, putting the nose against a concrete wall to burn rubber down to rims, they drag race the length of a shipping container. Things go horribly wrong, usually involving a fully restored Porsche, vintage race car, etc.
Here's the link of the episode with the '55 doing a burnout and you can see the tires grab, release and repeat. What's happening is the axles are twisting and untwisting and the slow-mo lets you see it clearly. Enjoy: https://www.youtube.com/watch?v=j7elRjtVbYM
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17121 Location: Retired South Florida
Posted: Wed Mar 21, 2018 11:06 am Post subject: Re: Knocking from rear end |
In over 40 years, I have never seen a cv axle in a stock application snap for any reason. Not saying it can't happen, but who can be sure after 30 years their CV axles haven't had their rotation direction swapped. I don't think it is something to lose sleep over. You should not place the balls in different ramps when you resassemble the joints after cleaning. _________________ ☮️ |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32592 Location: Reading Pennsylvania
Posted: Wed Mar 21, 2018 12:09 pm Post subject: Re: Knocking from rear end |
Dave,
Just for grins, buy a $3 needle fitting for your grease gun and try the "shoot grease in the boot" cure. I'd be curious how fast it quits knocking. Within minutes, or a half day of errand running, etc.
Mark,
Your comment about the balls needing to stay where they were is extremely important. I have opened joints (CV and Birfields) greased and haphazardly put the balls wherever on reassembly only to be rewarded with horrendous knocking as the balls wore the ramps to their particular size. They'll shut up but I know perfectly well that's only after removing metal to get them to match and that is now in my fresh grease.
For years now, I use a procedure of marking the ramps and the balls to ensure they stay where they were. The result? Silent joints after regrease.
No mechanic will take the time to do this but for all you DIY'ers I think it's good procedure.
I think this should be discussed and put into an FAQ and I volunteer you to do it! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2329 Location: Southeast Kentucky
Posted: Wed Mar 21, 2018 12:46 pm Post subject: Re: Knocking from rear end |
In 1986, in our 83 Air-cool tin-top driving south on the Cassiar Highway (HWY 37) in north central British Columbia (dirt road then), I began hearing this strange noise that sounded like a helicopter overhead. So, after a quick inspection beside the road, I proceeded on south for well over 100 miles (no other choice) to a little community (New Hazelton) on the Yellow Head (16). I stopped at a Standard Service Station at closing time. The two dudes put the Van up on the rack and greased the CV Joints using a very long needle.... problem solved. $20 donation and I was on my way in 15 minutes!
Then, in the summer of 2014 in Dawson City, Yukon, I had a new made in Germany Lobro CV Joint to begin whacking on my 84 tin top... I removed both axles in the Campground and re-greased them.... no more whacking.
So, hopefully the OP's CV Joints only need some grease, or better yet, just tightening the bolts!
_________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003.
Posted: Wed Mar 21, 2018 1:20 pm Post subject: Re: Knocking from rear end |
The CV's on my quite new '91 Multivan started making noise when they had less than 30K on them. Being in a remote location with few resources at this time I managed to come up with a grease gun from one source, a short needle and some plain jane lithium grease from another. The noise disappeared immediately and I didn't every pull down the joints until the tranny failed a dozen plus years later. |
gears Samba Member
Posted: Wed Mar 21, 2018 3:33 pm Post subject: Re: Knocking from rear end |
It seemed we'd see at least one Syncro axle break each year at SyncroFest, back when guys were actually off-roading their Syncros hard (although 4 times as many CV cages broke).
According to Tom Lengyel, "Axles usually break at the inner side of the cv splines, leaving the broken stub in the star wheel of the cv joint. They seem to break on both the inner and outer joints."
I'm betting that Seth saw his fair share of breakage (in his monster off-road Syncro, before upgrading to custom axles & CVs). _________________ aka Pablo, Geary
'87 Syncro GL 2.5
