AutoCraft 2783cc street engine in 61 Rag
Page: 1, 2, 3 ... 60, 61, 62  Next
ivkings4
ivkings4 is offline
PostPosted: Sun Mar 18, 2018 3:41 pm    Post subject: AutoCraft 2783cc street engine in 61 Rag Reply with quote
Who thinks I'm crazy for making this a daily driver?? Built by Tom Schuh (was their back-up engine for dragster in 1997)
Autocraft dry sump case made to be a wet sump
86 x 101.5
Autocraft heads with 50mm x 39mm titanium valves
Venolia Pistons
cc's in head 62
aluminum buttons
FK 89/91 .605 lift intake .582 exhaust
Scat Crank
Carrillo rods
Crank Trigger
Msd 7AL2
9.87 compression
Manton 7/16 tapered pushrods
52 ida's by JAyCee
2" step sidewinder by A1(He has a video of engine running on his instagram)
Going into a 63 rag, being built from ground up, Irs with 091 tranny by folts.
Anyone have a guess on HP at flywheel?
ps2375
ps2375 is offline
PostPosted: Sun Mar 18, 2018 3:55 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
I suppose you can dd almost anything, just depends on what you're willing to put up with. Who knows, it might be OK. Not sure how long Ti valves will last.
Sure is purdy.
EVfun
EVfun is offline
PostPosted: Sun Mar 18, 2018 4:07 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
Have you talked to the builder about this idea? Sometimes race engines use parts for power that may not be good for engine life. It is also possible the cooling system is not adequate for driving the distance.
Wildthings wrote:
woodoctr
woodoctr is offline
PostPosted: Sun Mar 18, 2018 4:11 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
Big difference in a motor set up to run for seconds to minutes at a time compared with one that must run for hours in various environments...... Doesn't look very daily driver to me......
ivkings4
ivkings4 is offline
PostPosted: Sun Mar 18, 2018 4:12 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
This engine was his idea, Tom has built me both street and race engines over the years. He does a lot of custom things inside and out of the engine to make them last.
Howard 111
Howard 111 is offline
PostPosted: Sun Mar 18, 2018 4:48 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
It's a shame to ruin that nice engine to try to make it run on the street. It will burn up in no time. Just look at the fit and lack of tin.
1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
Onceler
Onceler is offline
PostPosted: Sun Mar 18, 2018 5:40 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
Maybe run it on E85 to reduce heat? Don't know squat about the rest
1972 Karmann Ghia
-defund Facebook believer-
ivkings4
ivkings4 is offline
PostPosted: Sun Mar 18, 2018 6:05 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
E 85 is an option, waiting for the Dyno results to see, the fan shroud that is in the above picture of the engine has been altered to cover the cylinders more. Running a large race oil cooler with a shrouded 12 inch spal fan
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Sun Mar 18, 2018 6:08 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
I guess it depends on what your definition of "street" is. You could run it down to In & Out, but you're not going on Drag Week.
Onceler
Onceler is offline
PostPosted: Sun Mar 18, 2018 6:18 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
I really don't see why u couldn't run that on the street, as long as your willing to modify/change whatever it is that makes it not street able. Pretty vague I know, but it's the extent of my knowledge and just thought its cool
1972 Karmann Ghia
jason
jason is offline
PostPosted: Sun Mar 18, 2018 6:45 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
Why not crank trigger and fuel injection? I would put a shroud that covers more.
ivkings4
ivkings4 is offline
PostPosted: Sun Mar 18, 2018 6:57 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
It does have a crank trigger. Autocraft engines are set up to where you kind a need to run their shroud, fuel injection was not an option, I wanted to stick with the old-school 48’s. We talk to several people before making the decision for carburetors, did not want to be tied to a tuner, some of them are pretty flaky
Teeroy Premium Member
Teeroy is offline
PostPosted: Sun Mar 18, 2018 7:12 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
I bet with that cam you could run a little more compression, I don't see any deflectors under the cylinders. I don't see driving it everyday in stop and go traffic, but see no reason it wont work for a fun (and scary fast) weekend toy
Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org
esde
esde is offline
PostPosted: Sun Mar 18, 2018 7:15 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
Will it even fit? Wondering how widely spaced those carbs are?
Might need to do some "trimming" to get it in there.
modok wrote:
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Mar 18, 2018 7:19 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
I bet it never makes it past 5000 miles without needing work.
I just don't see the heads lasting in traffic.
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
ivkings4
ivkings4 is offline
PostPosted: Sun Mar 18, 2018 7:42 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
It will fit, we cut out the side shelf’s of the engine bay. Not sure on the apron with the large exhaust. Mike at Autocraft said to run oilers spraying on the rockers if we need to, so it is plumbed for that. New altered shroud covers the barrels now and the deflector tin would not fit with the 10mm studs, there is only 1/16 or less between the barrels.
HotStreetVw
HotStreetVw is offline
PostPosted: Sun Mar 18, 2018 7:47 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
I don't know anything about the heads besides valves, so assuming min cross section is about 86% of the valve diameter (ported), your looking at 247hp - 258hp corrected to sea level.
Compression is low considering the cam.
I agree with some of the others that it's not daily driver material. More like a sporting trip to the cruse night hangout.
When is it going on the dyno?
4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP
ivkings4
ivkings4 is offline
PostPosted: Sun Mar 18, 2018 7:51 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
Going on dyno in 2 weeks. Ports are somewhat stock, use to have 2 spark plugs per Hole
HotStreetVw
PostPosted: Sun Mar 18, 2018 7:55 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
Do you have a picture of the ports? As they say, power is made in the heads.
4inBhore
PumaVW79
PumaVW79 is offline
PostPosted: Sun Mar 18, 2018 7:58 pm    Post subject: Re: AutoCraft 2783cc street engine in 63 Rag Reply with quote
So what are you waiting for?
Page 1 of 62
