King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Sun Mar 18, 2018 7:58 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
This is before they were match ported to Manifolds
Posted: Sun Mar 18, 2018 8:02 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
waiting for Car to be finished, Building car because I got the Engine. Dyno is not aviable for 2 weeks due to vw drag's.
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Sun Mar 18, 2018 8:09 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
I think my first guess going to be pretty close. 247-258hp
I saw those trailing arms in your gallery. They are badass. _________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
Posted: Sun Mar 18, 2018 8:12 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
Ron Lummus is making them now for 1k. One inch narrowed.
This same engine at race compression would be more like 275hp-286hp. _________________ 4inBhore
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Sun Mar 18, 2018 8:18 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
What is "the goal" of this project? Simply to prove it will live on the street? The Der Renn Kafer cars of Shawn Geers, and Rich Dickson come to mind as the baddest N/A street cars to come down the pike. They weren't what most considered street cars either, but ran 10.80's with 280+ on tap. It's great if you do get it to "live" on the street, but don't be surprised if you come across someone with a smaller engine with a little hotter tune have a faster car. |
Posted: Sun Mar 18, 2018 8:28 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
This engine kinda fell into my lap. Grew up racing in the late 80’s. Folts offered me the engine for a steal, so the build started there. Found a ragtop to put it in. Tom Schuh and Folts are both optimistic it will be streetable. I drive about 30 miles a day, no daily commute just running around. |
Posted: Sun Mar 18, 2018 8:43 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
I'd bet Shawn's DRKC car had more than 280hp, easily into the 300+.
[email protected] wrote: |
jason Samba Member
Posted: Sun Mar 18, 2018 10:14 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
Sorry, meant without a distributor. My friend had fuel injection on his big motor, damn thing would barely get to temp. Took about 15 minutes. I went with IDA’s and wish I would of gone feul injection. |
Posted: Mon Mar 19, 2018 3:27 am Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
I was trying to leave as many parts on the engine I could that was on the engine when it was in their dragster. The cam and carbs We’re changed. not often you get an engine with as much history as this one has.
Wreck Samba Member
Posted: Mon Mar 19, 2018 5:23 am Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
It might pay to run the Autocraft oil spray bars in the heads to help with the head temps .Also Porsche piston squirters if it hasn't already got them . It would be worth while to run a quality CHT gauge like a MGL TC-1 . a well set up WI system even NA is also a great way to manage head temps . |
oldschool5er Samba Member
Posted: Mon Mar 19, 2018 5:46 am Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
I don't think oil cooling methods in itself or squirters are going to do enough to reduce heat buildup in this particular motor, I have had a hard time using AC cyl. and heads like that keeping them cool. I think running a E85 setup as has been suggested before is the best way to get it on the street. I know it's a PITA and you might have to get rid of the Webers and go FI since it would be hard to keep enough fuel in the bowls among the other issues with E85 use in carbs. The benefits I think would be worth it in the long run and would even allow you to bump CR a bit more. You shouldn't really care about fuel economy anyway with this motor. _________________ HRE in Westerville,Ohio
Full machine shop with all types of CNC. Rapid prototyping available, CNC Plasma cutting, 3D printing and Laser engraving.
cousineddy Samba Member
Joined: October 05, 2009 Posts: 48 Location: United States
Posted: Mon Mar 19, 2018 5:47 am Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
That’s awesome! I’d do it in a heartbeat,what are you doing for a clutch? _________________ 65 bug blow thru 2276 turbo
73 Thing |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Mon Mar 19, 2018 8:55 am Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
My hat's off to you! Awesome project and have fun with it!!! _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Mon Mar 19, 2018 8:59 am Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
Folts has been talking with Kennedy, they have a 9” with springs between the material(not in the center) that they say will hold up, its on order now. With a stage 2. Trans will be a 091 with Peloquin diff, no spider gears. |
Posted: Mon Mar 19, 2018 9:01 am Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Mon Mar 19, 2018 1:29 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
I love this! Your a Automotive Gangsta for give this a try!
Rocker spray and all that the others mentioned is great. But one thing that is important is outside weather. Your in SoCal I'm guessing? Right now in this cool weather, you can get away with all kinds of Air Cooled "No-No's" that would not fly during summer heat.
I think everyone assumes the worst when it comes to aircooled cooling details. They imagine the person driving stop and go 110 degrees. Which is good, but also its just as important for the driver to recognize he can get away with a lot if the air is already cool. _________________ [email protected] MPH 1/4 Mile & 8.1 @ 83.7MPH in 1/8 Mile with Mild Type 1 VW Mag Case 2234cc commuter engine in stock weight bug w/only .491 total lift(CB2292 Cam), 42x37 heads, 48idf's, Street tires, Belt on, Mufflers, Pump gas, video of the run here: https://youtu.be/M3SPqMOKAOg
Transmission by MCMScott:
Rhino case, Klinkenberg 4.12, Superdiff, 002 mainshaft with 091 first idler. Weddle 1.48 Third & 1.14 Fourth. |
Posted: Mon Mar 19, 2018 1:39 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
Yes you’re correct, SoCal. Had lots of people in the 80’s say a 2165 with a K8 cam wouldn’t last? Ran 13.0 in 1/4. Drove it 30k a year with no issues. |
-Alex77- Samba Member
Joined: December 09, 2008 Posts: 513 Location: Finland
Posted: Mon Mar 19, 2018 2:09 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
I think only way to make the engine run cool is to use E85 fuel, if you are really talking about real street driving, not just short 10-15min runs to at weekends.
My friend is building similar engine, which will be E85 fueled 2919 (90x101.6) but he will be using my billet heads and custom iron cylinders which are fully finned, just to avoid cooling problems.
_________________ Lasercut parts and CAD design |
k@rlos Samba Member
Joined: October 04, 2012 Posts: 485 Location: Suffolk, England
Posted: Mon Mar 19, 2018 2:20 pm Post subject: Re: AutoCraft 2783cc street engine in 63 Rag |
Gonna be well over 270hp I should think, will be epic fun for the couple 1000 miles it lasts on the streets |
