King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Mon Mar 01, 2021 6:56 pm Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
Picked up a New 105mm Autocraft case from the samba. Thanks James.
Thinking of gathering parts for a E85 with NOS engine. Roller cam, Street driven for sure. I have a 63 ragtop in storage or put it in the 61.
Any thoughts on what you would put in it?? size crank? it's going to be a Marine crank, the stroke is the question. I have Autocraft barrels, need pistons..Heads I was thinking JPM.
This will be a Geers build for sure.
_________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
https://www.instagram.com/king_vw61/?hl=en |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Mon Mar 01, 2021 10:07 pm Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
If this case was mine. And I had Shawn as a builder?
I'd let Shawn dictate the build and pay him well for the work he does,
You already know the triumphs and the pit falls of running an extreme HP engine on the street! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Mon Mar 01, 2021 11:13 pm Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
He will be deciding the important things like size of cam and all the little tricks he does.
This is down the road and looking to see what people say, He will for sure get the last say.
If I can get 250 to the wheels N/A and add 100 shot for the oh shit factor I will be happy, With E85 having 106 octane not sure how hi I can go on Compression but I will push the envelope.
Something to talk about.... _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Mar 02, 2021 4:59 am Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
Draw thru turbo _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
sled Samba Member
Posted: Tue Mar 02, 2021 7:51 am Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
105 x 90 = 3117cc's
-grab some MS250 heads or even 330EVO heads from JPM in Sweden (as you mentioned)
-1.6:1 5-bolt rocker arm assemblies JPM
-roller cam from JPM
-roller throttle bodies (or traditional butterflies) of appropriate size
I'd think that could make 250 to the wheels pretty easily...and be an absolute monster of a real street engine.
_________________ drive your split. |
mark tucker Samba Member
Posted: Tue Mar 02, 2021 9:39 am Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
sweet case!!! |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Tue Mar 02, 2021 10:46 am Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
Angle flow heads water cooled with boost. _________________ Steve
Steve's 87 Syncro project |
Posted: Tue Mar 02, 2021 9:26 pm Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
Got my gauge's all set up on the laptop. Innovate Tc-4 plus x 2 and the Lm2 for AFR and RPM.
I can record from either the LM2 or the laptop itself. With CHT and EGT I should be able to get this thing fine tuned, Now if I just had heads for it.......
sled Samba Member
Posted: Tue Mar 02, 2021 9:39 pm Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
EVO 340!
-Alex77- Samba Member
Joined: December 09, 2008 Posts: 513 Location: Finland
Posted: Thu Mar 04, 2021 6:34 am Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
sled wrote: |
105 x 90 = 3117cc's
105mm bore will never work on any long term application, cylinder wall thickness would be at most 3mm. Also the case needs to have some sealing surface.
90x101.6 with MS250 / billet heads could do probably 220-240hp from wheels with some reliability with good cylinders. _________________ Lasercut parts and CAD design |
Posted: Thu Mar 04, 2021 10:47 am Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
if I were to do a big bore for the street..I would relocate the cylinder locations.off set rods a tad and stretch the heads a little...and have empty pockets again |
Posted: Thu Mar 04, 2021 12:37 pm Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
mark tucker wrote: |
Why for extra 100cc and little more less reliability?
102mm bore can be done "safely" and 90 stroke all T4 mains flanged crand is most what i would use. Power is in the heads and cam. _________________ Lasercut parts and CAD design |
Posted: Mon Mar 08, 2021 6:14 pm Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
Still waiting on heads. almost 3 months now. Sucks...
I got a Innovate SSI-4 Plus it has 4 inputs for RPM, MAP Oil Pressure ect.
https://www.summitracing.com/parts/INN-3914
also a https://www.summitracing.com/parts/INN-3926 pressure switch 0 to 150.
It will be here tomorrow. I will record RPM, AFR and Oil pressure along with the EGT and CHT of all 4 cylinders.
This should be all I need for now. I do have 2 channels open for future gauges, they Do make a E85 gauge to show % of ethanol.
This will also let me remove the analog cable running to the LM2. I will use that on cars I am tuning.
My LM2 also Died, wont power up with the 12v, so it wont preheat the 02. I sent it back for repair. Bought another (open box) 220.00 to my door. all the extra cables and bosch 02 included. _________________ 1961 Ragtop, Autocraft 2783cc for street/strip 10k miles and counting...230.84 HP to the wheels thru Muffler 13.4 to 1 on E85
Posted: Wed Mar 10, 2021 8:55 pm Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
Some pictures of the progress, Shawn says Soon they will be done. I can't wait.
Rocker Side supports are the second photo, my old ones were aluminum, these are steel, He says they are a pain to make but way stronger.
Posted: Wed Mar 10, 2021 9:40 pm Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
Wow!
I want a Dial indicator mount like that model.
Who makes it? _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Thu Mar 11, 2021 5:18 am Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
You mean that fancy oil pump cover? _________________ 'Black Ice'Drag Buggy 'Turbo'
calvinater Samba Member
Joined: September 06, 2014 Posts: 3328 Location: 802 The Pointless Forrest
Posted: Thu Mar 11, 2021 5:25 am Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
The one with the ball and socket joint? _________________ "Albatross"! |
Tobias Bylund Samba Member
Joined: December 10, 2007 Posts: 202 Location: Varberg - Sweden
Posted: Thu Mar 11, 2021 5:56 am Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
Looks like a NOGA indicator base with fine adjustment:
Posted: Sun Mar 14, 2021 2:56 am Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
Picked up the wet sump from Tony on the samba. Also got another bottom plate oil pickup. I got one from him last year. Now I have 2. Hardware for the sump and the case hardware is coming from mike at autocraft.
Still no heads.
Bad bug Samba Member
Posted: Sun Mar 14, 2021 4:18 am Post subject: Re: AutoCraft 2783cc street engine in 61 Rag |
ivkings4 wrote: |
Still no heads.
I have one of these sumps for my 2.2Ltr oxyboxer. About running 105mm liners, this is my opinion. I think the best case to run those liners is a T4 engine, the distance between each liner is greater allowing for a more even cooling of large liners. |
