Stainless steel exhaust for 1973 thing
miguelcueva
miguelcueva is offline
PostPosted: Sun Mar 18, 2018 8:41 pm    Post subject: Stainless steel exhaust for 1973 thing Reply with quote
Hello, I am looking for stainless steel exhaust options for my Thing. I am looking specifically for the double exhaust, the one that has a muffler on each side. I know they exist because I have seen pictures but I have not been able to find them.
I checked on vintage speed and I also emailed them asking but they do not carry those.
any ideas?
YDBD
YDBD is offline
PostPosted: Sun Mar 18, 2018 9:29 pm    Post subject: Re: Stainless steel exhaust for 1973 thing Reply with quote
The Thing Shop
http://www.thethingshop.com/POLISHED-STAINLESS-DIVIDED-HEADER-EXHAUST-SYSTEM/productinfo/181DHS-P/
'56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing"
miguelcueva
PostPosted: Tue Mar 20, 2018 1:13 pm    Post subject: Re: Stainless steel exhaust for 1973 thing Reply with quote
cool, thanks!!
ldj1002
ldj1002 is offline
PostPosted: Tue Mar 20, 2018 5:10 pm    Post subject: Re: Stainless steel exhaust for 1973 thing Reply with quote
Some of those kind of exhaust you can't adjust valves because you can't get valve cover off. Some the valve cover will come off. Check with them. If you can't get valve cover off without removing exhaust that is not good Sad
KAmes
KAmes is offline
PostPosted: Tue Mar 20, 2018 5:36 pm    Post subject: Re: Stainless steel exhaust for 1973 thing Reply with quote
I have that exhaust, I really like it. You can remove the valve covers no problem. It's pretty tight to do the valve adjusting as you can't get a screwdriver straight on, I've had fair results using a screwdriver bit in a 1/4 box wrench. It's a little fiddly but it can be done.
911pickup
911pickup is offline
PostPosted: Wed Mar 21, 2018 1:50 pm    Post subject: Re: Stainless steel exhaust for 1973 thing Reply with quote
I curious as to why you haven't considered the Vintage's Thing exhaust system with the single muffler out back.
I have one on my Thing and I'm very happy with it. Excellent quality.
