Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Mon Mar 19, 2018 4:22 am Post subject: Shifting question “notchy” second |
I’ve read through several threads and not finding the exact issue I’m having. When shifting from 1st to second too quickly I get a quick grind and sometimes from second to third as well. It’s hard to classify it as a grind as it’s just for very quick second. Almost more of an exaggerated click than a grind really. I’ve adjusted the clutch cable, moved the plate around about a hundred times but can’t seem to get rid of this. Now if I shift nice and slow there isn’t an issue 99% of the time. Only when trying to shift quickly.
Don’t remember the year of trans, I did look it up once(64 iirc), it’s not a split case for sure. Has an Empi shifter, but did the same thing with the stock shifter. As mentioned, I’ve adjusted the shifter in every possible direction, going so far as to drive around my neighborhood with a socket, ratchett and hammer to tweak adjustments while I’m puttering around. Am I just trying to shift faster than the trans can handle? First is good, sometimes pops out but I seem to have adjusted that out. Going into fourth is never an issue. It always goes into all the gears. Just isn’t smooth feeling. Trans oil was changed 6 months ago. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
anthracitedub Samba Member
Posted: Mon Mar 19, 2018 5:42 am Post subject: Re: Shifting question “notchy” second |
Trans could be showing its age... worn fork, rail, slider, hub or synchro. |
Posted: Mon Mar 19, 2018 6:08 am Post subject: Re: Shifting question “notchy” second |
anthracitedub wrote: |
It wouldnt surpirse me I guess. Trans is in a dune buggy so it hasnt been babied by any means. I always thought syncro issues reared their heads as forcing the car out of that gear? I had a 63 ones that would pop out of 4th all the time until I had it fixed and was told it was the syncro? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Zundfolge1432 Samba Member
Posted: Mon Mar 19, 2018 6:30 am Post subject: Re: Shifting question “notchy” second |
An oil change with a friction modifier such as MoS2 molybdenum disulfide might help. Sometimes just new oil does wonders. I went with a nice synthetic in mine and it seemed to help. |
Posted: Mon Mar 19, 2018 6:43 am Post subject: Re: Shifting question “notchy” second |
Zundfolge1432 wrote: |
I did drain and replace the oil a few months back with 80w/90. One of my least favorite jobs ever. Made no difference. I will say I kind of pulled a boneheaded move and realized I only took out the higher up plug and not both. Of course I already had 2 containers of oil already in when I realized. Guess I’ll change it again and make sure to take out both. Did I mention I hate doing that?
You saying something like this:https://www.autobarn.net/lubro-moly-engine-treatment.html?site=google_base&gclid=Cj0KCQjwv73VBRCdARIsAOnG8u2acrADSDaOEGLDi17uvSkisc4A3I9d7qEGaQvik3AhbrU_6KFgMxcaAiT3EALw_wcB _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
Posted: Mon Mar 19, 2018 8:31 am Post subject: Re: Shifting question “notchy” second |
That’s item # LMY2019 according to their web page about 10 bucks. They sell a nice little pump that screws onto oil containers, makes less mess just go slow good luck |
