chrisfreed1 Samba Member
Posted: Mon Mar 19, 2018 10:42 am Post subject: "S" Switch |
What is it?
I think the part number is 701927127
I found something that says its a transmission switch. Maybe sport? And I've seen roof blower switch.
Any ideas?
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
Posted: Mon Mar 19, 2018 12:22 pm Post subject: Re: "S" Switch |
Its in a 1993 MV with AC that I recently obtained. |
Posted: Mon Mar 19, 2018 12:23 pm Post subject: Re: "S" Switch |
I also have reason to believe that this van has been through some stuff. Maybe new/used dash, door panels and who knows. |
Posted: Mon Mar 19, 2018 12:36 pm Post subject: Re: "S" Switch |
a few more photos from inside the van...
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Mon Mar 19, 2018 1:35 pm Post subject: Re: "S" Switch |
Have you tried pressing it? _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Mon Mar 19, 2018 1:58 pm Post subject: Re: "S" Switch |
As far as I can tell it does nothing. |
Joshwa Samba Member
JMB3 Samba Member
Posted: Mon Mar 19, 2018 4:17 pm Post subject: Re: "S" Switch |
chrisfreed1 wrote: |
transmission switch. Maybe sport? |
I imagine this guess is correct. I'm not sure how you would confirm it, though, unless you were really good at sensing the responsiveness of the transmission. I think I remember seeing some tables in the Bentley that specified the exact speeds at which the transmission shifted. Maybe you could use that to tell if it's doing its thing. |
Gruppe B Samba Member
Posted: Tue Mar 20, 2018 6:25 pm Post subject: Re: "S" Switch |
The early 90's Eurovans had the "sport" switch to allow the transmission to Rev higher during acceleration. My 2 Eurovans had these switches but something must have broken in the 26 years that they were on the road as they did nothing too. |
BALDY & BLONDIE Samba Member
Joined: July 12, 2013 Posts: 14 Location: United Kingdom
Joined: August 31, 2013 Posts: 12854 Location: North Carolina
Posted: Thu Mar 22, 2018 12:36 pm Post subject: Re: "S" Switch |
Do NOT push that button at highway speeds!! That button is used to make the transmission hold a lower gear longer when climbing & descending hills. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
logans5vw Samba Member
Posted: Mon Mar 26, 2018 4:54 pm Post subject: Re: "S" Switch |
When I had my 93 we called it the "retro-rocket" switch cause it gave a big boost to trans shift points. It was a hoot around town. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Mon Mar 26, 2018 8:10 pm Post subject: Re: "S" Switch |
Someone you don’t know gets $1,000,000 if you push that button _________________ .ssS! |
santeko Samba Member
Posted: Wed Apr 04, 2018 11:44 am Post subject: Re: "S" Switch |
My 1992 manual says its a Sport switch. I don't touch it, however, I have a follow up question, I recently drove up a friends insanely steep driveway (we're talking 14%+ grade) and as the van slowed, it kicked into a super low gear that I didn't recognize from normal driving. Is this related? It felt like it downshifted from 1 into.... 0.5 gear? |
