BC VAN MAN Samba Member
Joined: March 20, 2018 Posts: 9 Location: Vancouver BC Canada
Posted: Mon Mar 26, 2018 9:55 am Post subject: Re: when to shift?, 1993 Eurovan Weekender MV |
Thank you for reading and thank you for your feed back!
I live in Vancouver BC and the streets can be pretty hilly. I've been starting off in 2nd than shifting up around 30 rpms, feels pretty good, still not sure exactly where I should be shifting though. Haven't done any really big climbs yet.
Thanks again everybody![/img] |
Joined: August 31, 2013 Posts: 12816 Location: North Carolina
Posted: Wed Mar 21, 2018 11:54 am Post subject: Re: when to shift?, 1993 Eurovan Weekender MV |
'93s had that weird button on the dash (don't push that while cruising down the highway!) that would hold the transmission in third (maybe even second) to keep it from shifting up & down during hill climbs. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
IdeaNerd Samba Member
Joined: May 24, 2016 Posts: 596 Location: Central California
Posted: Wed Mar 21, 2018 10:50 am Post subject: Re: when to shift?, 1993 Eurovan Weekender MV |
@BC VAN MAN
In general, D for Drive is fine for all normal forward-moving use. The two exceptions to that for me are: 1) when the van is shifting back-and-forth frequently while climbing a hill, I drop the selector down a notch to keep it in the lower of the two gears it's switching between, and 2) when I'm having to ride the brakes to slow it down while coming down a hill, I move the selector down a notch to let the engine help some with the braking and not overheat the brakes.
If memory serves, I think the manual touches on this some as well.
If you're on reasonably flat terrain, D is all you'll likely need.
HTH |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22568 Location: NYC/Upstate/ROW
Posted: Tue Mar 20, 2018 4:17 pm Post subject: Re: when to shift?, 1993 Eurovan Weekender MV |
I think D means ypu let the car Decide.
(Sorry, long day)
_________________ .ssS! |
Posted: Tue Mar 20, 2018 2:49 pm Post subject: when to shift?, 1993 Eurovan Weekender MV |
Hello,
I have a 1993 Eurovan Weekender MV. It's automatic, I'm not really sure when I should be shifting gears, if I should always start in 1st or 2nd or just leave it in drive? I've been going by feel so far but not I'm not sure how high the rpms should be when I shift? especially on the hills.
Any help would greatly appreciated!!!
Thank you!!! |
