jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Wed Jun 20, 2018 3:37 pm Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
They call it Copper. It’s surprisingly thin and takes two days to get hard.(wait...that sounds like me!) |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Wed Jun 20, 2018 4:35 pm Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
^^^ WOW, you derailed your own thread. It usually takes someone like me or C21Darrel to do that. Good work, carry on _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Thu Jun 21, 2018 12:54 am Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
Nice progress - what brand Kafer bar did you use? It looks different to others because it has the two angle rods on each side. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Thu Jun 21, 2018 7:05 am Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
It’s from CoolRydes.
Took two days and some massaging of the parts to make it fit. |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Thu Jun 21, 2018 8:30 am Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
jeffrey8164 wrote: |
So you mentioned at the top of the page.
Posted: Thu Jun 21, 2018 10:38 am Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
That's a little disconcerting. I plan to use the same Kafer bar on a 70 Ghia. Do have any frame damage/distortion? Were you able to identify the source of the mismatch?
Emil _________________ “…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
Posted: Fri Jun 22, 2018 9:06 am Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
I'm the second owner of this Ghia. It was tapped in the front drivers headlight bucket which was properly repaired after the body was water blasted which is when the damage was found. So, no there is no frame damage.
The major installation issues were the mounting tabs that attach to the shock tower had to be tweaked about three degrees for the trailing arm rods to fit without binding. Out of the box there was too much stress on the clevis pins.
Also I chamfered the clevis pins so they wouldn't dig into the mounting tabs.
The metal in the tabs is much softer that the clevis pins. |
Posted: Mon Jun 25, 2018 12:03 pm Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
Repainted the trunk this weekend |
Posted: Mon Jun 25, 2018 12:07 pm Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
And painted the tank, steering column, ignition housing and some other things while the paint was out. |
Posted: Mon Jun 25, 2018 12:09 pm Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
Started getting the turn signal switch and ignition switch sorted out as well |
Posted: Sat Jul 07, 2018 9:11 am Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
I finished my Mini Me project.
Here is the full size version
It has a few blemishes. Its hard to block sand something so small but I think it came out OK. |
Exaktaphile Samba Member
Posted: Sat Jul 07, 2018 12:09 pm Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
That's pretty cool! |
Posted: Mon Sep 03, 2018 8:10 am Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
Ok. So, it's been a while. I put in the newly painted steering column with the new turn signal switch. I got a reproduction steering wheel. The description said up to 71. Rose is a 70 with a bunch of 71 parts in the mix. The steering column is from a 71. I had forgotten that the 71 column was one year only. The new steering wheel came with the wrong horn ring for my 71 and the splines were different so the wheel wouldn't fit. So I did what any self respecting garage tinkerer would do. I used a triangle file on the splines of the steering wheel to make the wheel fit on the shaft and performed minor surgery to fit a 71 horn ring and canceller.
Posted: Mon Sep 03, 2018 8:20 am Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
Then I started putting the trunk area back together starting with a new master cylinder since the old one was leaking just sitting there. The old brake light harness was crusty so I found a NOS harness from a nice lady in the Philippines.
Then I reconnected all the headlight wiring that I disassembled to paint the trunk and started on the front suspension
Finally getting to use the dropped spindles I got in 2001. |
Posted: Mon Sep 10, 2018 12:19 pm Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
After installing the new ball joints and tie rod ends I’m going to do a preliminary tape measure alignment. I plan to take it to my local shop to have a real alignment performed once the new engine is installed and broken, or broken in, whichever comes first.
Toe seems to be pretty straightforward but I’m using flat bar strapped to the spindles. I plan to make them equal even though I know there should be an 1/8 inch between front and back measurements.
Question is, what degree +/- should the camber be? As I move the camber eccentric that changes the toe so I think I need to do the camber first. I’m also not up to speed on the geometry changes in the suspension. Does the camber stay the same throughout the travel or does it change ? |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Mon Sep 10, 2018 1:34 pm Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
The car needs to be on the ground to get the alignment correct, toe changes as the suspension is cycled up & down. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Sep 10, 2018 4:32 pm Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
OK, so what if I compress the suspension half way? |
Posted: Wed Sep 19, 2018 7:41 am Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
Well it has been a few weeks since I've been able to work on Rose. My wife had some other ideas to fill my time.
I did however come across some old video tapes that had my old Fisher Buggies commercials on it. I converted them to DVD and uploaded them to YouTube so I could share.
https://youtu.be/tWVPSiucSnM |
c21darrel Samba Member
Tanoki Samba Member
Joined: September 27, 2010 Posts: 88 Location: The Netherlands
Posted: Sat Sep 22, 2018 8:36 am Post subject: Re: I'm refreshing Rose. My 70/71 bastard child. |
Good looking car!
Those commercials are great! 😃😃
Cheers! _________________ “Let me know the rules so I can ignore them”
My Ghia build : https://www.thesamba.com/vw/forum/viewtopic.php?t=703728 |
