Nekomorgan Samba Member
Joined: March 23, 2018 Posts: 88 Location: South Carolina
Posted: Fri Mar 23, 2018 3:09 pm Post subject: Help! My 72 beetle won't drive right. |
So I recently put a new 34 pict 3 carb in,new 009 distributor ( old dist. Was also 009), new spark plugs (ngk iridium) because I want to get a 45k volt electronic ignition. But I also replaced the plug wires too. And all gaskets and seals from the carb down to the dual port to head. I've also timed it to 32 degrees and I don't hear backfire when it revs I've also noticed a loud whooshing sound from the engine now, I don't know if that's normal. Also the car runs perfectly fine when it idles in neutral. Nothing wierd, no hesitation, no stumbles, no backfire, no anything. But when Its in gear and under load it hesitates really bad. I'll push the gas down like halfway and it's unresponsive for the first few seconds then gets going.
It's a 1972 standard 1.6 do |
Hatracks Samba Member
Joined: July 10, 2016 Posts: 664 Location: Renton, WA
Posted: Fri Mar 23, 2018 3:25 pm Post subject: Re: Help! My 72 beetle won't drive right. |
Nekomorgan wrote: |
So I recently put a new 34 pict 3 carb in,new 009 distributor ( old dist. Was also 009), |
What was the old carb? The hesitation is known for the 009/034 as an issue but some people have made it work? _________________ 73 Super Build |
AlmostHeavenWV_VW Samba Member
Posted: Fri Mar 23, 2018 3:42 pm Post subject: Re: Help! My 72 beetle won't drive right. |
Nekomorgan wrote: |
New carbs and distributors are often inferior quality. If you still have the old parts and then are genuine Bosch distributor/ solex or bocar carb, I'd try to get them cleaned up/refurbished and reinstall those.
You can do so if you are so inclined or these fine gentleman can help:
Carbs:
https://www.thesamba.com/vw/classifieds/detail.php?id=1715786
Distributors
https://www.thesamba.com/vw/classifieds/search.php?username=tasb
https://www.thesamba.com/vw/classifieds/search.php?username=glenn
https://www.thesamba.com/vw/classifieds/search.php?username=wcfvw69
As mentioned above, the 34pict/009 dist combo have an inherent hesitation, but I suspect that 'whooshing' noise you have could be a vacuum leak (and a sizeable one at that if you can hear it) Time to go looking for vacuum leaks, and sadly you have a lot of gaskets you've disturbed and it could be.
An old mechanic I knew once used incense sticks to 'smoke' the engine along the carb, intakes, gaskets etc to see where the leaks were. If the smoke gets pulled in- there's a leak there _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Starbucket Samba Member
Posted: Fri Mar 23, 2018 4:02 pm Post subject: Re: Help! My 72 beetle won't drive right. |
Look down the carb bore and with motor off slowly open the throttle to WOT, you should see a stream of gas shooting down the carb from the VERY start until the WOT, if not adjust the accelerator pump arm toward the + sign until it runs strong off idle. If no gas you got a bad carb. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Fri Mar 23, 2018 5:32 pm Post subject: Re: Help! My 72 beetle won't drive right. |
It most likely is that 009. They are known for that flat spot, right off the bat. That flat spot is accentuated with any deficiencies, in any of the systems (gas, ignition, compression, exhaust).
I would say, based off of what you wrote, you have a vacuum leak at the intake to heads, or at the carb base, or throttle shaft bushings. Add that with the poor advance capabilities of the 009 at below 2000 rpms. and you got a bad flat spot.
Get a good distributor, with a vacuum advance can. Find the vacuum leak. Then go run that thing like a mad man! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sun Mar 25, 2018 1:38 pm Post subject: Re: Help! My 72 beetle won't drive right. |
Hatracks wrote: |
Nekomorgan wrote: |
What was the old carb? The hesitation is known for the 009/034 as an issue but some people have made it work? |
The old carb was bocar. I'm probably going to rebuild it and clean it. |
Posted: Sun Mar 25, 2018 1:42 pm Post subject: Re: Help! My 72 beetle won't drive right. |
AlmostHeavenWV_VW wrote: |
Nekomorgan wrote: |
Carbs:
Distributors
An old mechanic I knew once used incense sticks to 'smoke' the engine along the carb, intakes, gaskets etc to see where the leaks were. If the smoke gets pulled in- there's a leak there |
I figured out with the help of a friend that noise is the fan rubbing against the shroud. The noise got really bad and squeaky too. I've checked and no intake leaks. Also I figured out when looking at the generator pulley it wobbled. And with the belt off. You can hear the generator is shot when you turn it. So I'll put in an alternator. But the problem is that the 36mm nut on the back of the fan won't come off even with a breaker bar. So now I have to drop the engine. |
Posted: Sun Mar 25, 2018 2:20 pm Post subject: Re: Help! My 72 beetle won't drive right. |
Nekomorgan wrote: |
Nekomorgan wrote: |
Carbs:
Distributors
Its just a big nut on a small shaft, are you turning it the correct direction? |
