eth727 Samba Member
Joined: February 21, 2007 Posts: 542 Location: san diego
Posted: Fri Mar 23, 2018 5:01 pm Post subject: Cutting,trimming tool for sheet metal. |
I've got some circular holes that I would like to weld up. I was wondering what would be the best tool to use to cut,trim sheet metal. I don't have room for a huge band saw either.
Thanks |
67ctbug Samba Member
Posted: Fri Mar 23, 2018 5:28 pm Post subject: Re: Cutting,trimming tool for sheet metal. |
How big are the holes? Can you just weld them shut? _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Mar 23, 2018 5:32 pm Post subject: Re: Cutting,trimming tool for sheet metal. |
Rotary file bits for my drill, 4.5" angle grinder & a sawzall is all I've ever needed. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Fri Mar 23, 2018 10:49 pm Post subject: Re: Cutting,trimming tool for sheet metal. |
smaller than 1/4 I just weld them up, with a chunk of copper held against the other side. 1/2-3/4 hole would be kind of odd, yeah it would be nice to have a way to create small coin size patches. Never really thought about it in depth.
It would be nice to have them punched out of sheet, as the slightly bent edges would be good to reduce distortion. It's tough to weld up a 1/2" hole without distorting the heck out of everything. If you make it slightly concave....then smoosh it flat after it's welded in that will help counter the distortion. |
eth727 Samba Member
Posted: Sat Mar 24, 2018 12:06 am Post subject: Re: Cutting,trimming tool for sheet metal. |
Like 3" . I definitely need to trace them on paper and transfer to sheet metal and cut them exactly the same. |
parker007 Samba Member
Joined: December 21, 2011 Posts: 132 Location: california
Posted: Sat Mar 24, 2018 1:31 am Post subject: Re: Cutting,trimming tool for sheet metal. |
simplest way is angle grinder with thin wheels. I also use large hole saw to cut blank but you end up with 1/4 hole in middle. use belt sander to finish. |
modok Samba Member
Posted: Sat Mar 24, 2018 1:13 pm Post subject: Re: Cutting,trimming tool for sheet metal. |
eth727 wrote: |
yeah!
I use magnets to stick the template to the sheetmetal, then I paint it with some random color of spray paint to make a line to cut on. |
vwjetboat Samba Member
Posted: Sat Mar 24, 2018 1:23 pm Post subject: Re: Cutting,trimming tool for sheet metal. |
perfectly round ? hole saw.. jig saw with metal blade.. metal sheers. |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Mon Mar 26, 2018 5:03 am Post subject: Re: Cutting,trimming tool for sheet metal. |
modok wrote: |
1/2-3/4 hole would be kind of odd, yeah it would be nice to have a way to create small coin size patches. Never really thought about it in depth. |
Sheet metal punch or the punch outs from electrical boxes. _________________ 71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead |
kman Samba Member
Posted: Mon Mar 26, 2018 5:06 am Post subject: Re: Cutting,trimming tool for sheet metal. |
eth727 wrote: |
Thanks |
angle grinder w/cut off wheel. jig saw. file. Though I just use a hole saw on my drill press. _________________ 71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead |
beetlenut Samba Member
Posted: Mon Mar 26, 2018 5:59 pm Post subject: Re: Cutting,trimming tool for sheet metal. |
So true, I just cut the top half of a firewall off with these things. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Mon Mar 26, 2018 7:48 pm Post subject: Re: Cutting,trimming tool for sheet metal. |
Angle grinder with a cutoff wheel . . . less than $25 at Harbor freight tools.
I like to fit-up patches made from the same thickness with as small a gap as possible.
I have even resorted, when necessary, to using my Dreamel tool with a super thin cutoff wheel for fine tuning.
My practice piece . . . a bent rear clip someone tried to toss into the garbage . . .
Look Ma, NO Bondo!
_________________ Jesucristo es mi Seņor y Salvador! |
Posted: Mon Mar 26, 2018 7:54 pm Post subject: Re: Cutting,trimming tool for sheet metal. |
Dremel wheels suck... I broke 25 when I replaced my rear quarter... _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Mar 26, 2018 8:11 pm Post subject: Re: Cutting,trimming tool for sheet metal. |
67ctbug wrote: |
Dremel wheels suck... I broke 25 when I replaced my rear quarter... |
Did you try to do your entire quarter panel with dremel cut off wheels?
I fit my patch panels as accurately as possible using my angle grinder... The Dremel tool is used simply for fine-tuning the gaps... It is equipped with these...
Posted: Mon Mar 26, 2018 9:11 pm Post subject: Re: Cutting,trimming tool for sheet metal. |
When I say quarter panel I mean this-
And then I cut it to just around the bold holes with a grinder and then cut around my lines with a dremel. I would say I cut most of the piece with a dremel because I had to make sure all the lines were accurate.
Here, you can see what I did kind of-
https://www.youtube.com/watch?v=rBWn2r3c8Gs
go to right around the 11 minute mark if you want to skip the beginning of the repair. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Tue Mar 27, 2018 8:44 am Post subject: Re: Cutting,trimming tool for sheet metal. |
57BLITZ wrote: |
67ctbug wrote: |
I like these Fiberglass-reinforced ones. Seems like they'd stay together better than the rigid/brittle stone ones. Where did you get those? _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Posted: Tue Mar 27, 2018 10:28 am Post subject: Re: Cutting,trimming tool for sheet metal. |
Biggest hardware store you have ever seen!
https://www.mcmaster.com/#1257a76/=1c5k61m
I have yet to break any of them . . . _________________ Jesucristo es mi Seņor y Salvador! |
eth727 Samba Member
Posted: Tue Mar 27, 2018 10:16 pm Post subject: Re: Cutting,trimming tool for sheet metal. |
I used a handheld jigsaw flipped upside down on a work table. It's like a poor mans band saw. |
