Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Mon Mar 26, 2018 3:03 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
djkeev wrote: |
It is 3,000 miles across the USA, a lot if it empty and many of the highways I choose to take are are not well traveled or populated. I once traveled for two hours in Southern Idaho and saw eight cars.
Many areas haven't any surface water. |
I guess it must be different in Australia then, seeing as we have such a densely populated country with an abundance of water. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32579 Location: Reading Pennsylvania
Syncro Jael Samba Member
Posted: Mon Mar 26, 2018 6:31 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
I am much like Dave.
My wife says I spend almost as much time crawling under, over, and around the van than I do with her! I am always checking for leaks, noises, and everything to do with the van.
I had the old plastic overflow tank crack open while off in the back roads of Utah. It is not a lot of fun to look back and see white smoke and smell antifreeze. I was able to J-B Weld the crack after it cooled and get home. I also have had the caps leak, get cross threaded, and fail too many times.
Ever since I installed the RMW tank, years ago, I have had zero issues with the expansion tank.
Worth the money.
I have (3)three new blue caps, and (2)two new plastic expansion tanks for my families other vans. Just in case they want them. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
andrewvwco Samba Member
Joined: February 23, 2017 Posts: 298 Location: Estes Park colorado
Posted: Mon Mar 26, 2018 7:21 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
djkeev wrote: |
Mellow Yellow 74 wrote: |
djkeev wrote: |
I check all fluid levels before embarking on a days journey.
As mentioned, You cannot see inside the aluminum tank. IF the hose between the RMW tank and the VW overflow tank gets compromised somehow, a hole in the hose or a loose connection, this will NOT allow the vacuum created on system cool down to draw the liquid expelled when hot to be drawn back in.
If this happens, your system is now low on coolant.
A risk I'm not willing to assume.
I worry a tad, I think I watch the oil pressure gauge and the temperature gauge while driving more than I glance at the Speedometer......
Dave |
So every day before driving you open the rear hatch, remove the engine cover and remove the cap on the RMW tank to visually check the level in case you have a hole in the hose between the two tanks?
Even if there was a hole in the hose and your system was low on coolant, the coolant level alarm would keep flashing after you start the car and you would know about it immediately, particularly if you have an audible coolant alarm. |
Absolutely Yes. ^^^
Fact is, most coolant leaks happen on a stone cold engine. So after cool down and the system draws coolant back in, during the night, or during days of being parked, the system can leak.
I had my thermostat cover leak once. I discovered it in the morning hours outside of Billings Montana.
My tank was low so I began seeking why, I found that I had a puddle on the ground.
I had it fixed in 20 minutes or so (nice job on a cold engine, it would be hell on a hot engine) and we were off for a day of trouble free motoring to Great Falls.
Bonus! I had water available and a place to clean up afterwards.
Here in the States dash warning lights are called "idiot lights"..... for a reason.
I don't trust them 100% for electronic systems do fail.
I do however trust my eyes.....
I Look at all fluids, belts, hoses, general overall engine area condition.
I even stop and open the lid a SECOND time after a few miles (I pack accordingly) and my automatic transmission oil gets to operating temperature.... time to check it.
Many areas haven't any surface water. I much prefer using distilled water and always carry a few gallons "just in case".
I'm not going to risk a break down somewhere like in the barrens of Eastern Montana because I was lazy and didn't take a few minutes in the morning to pop the cover and look...... such a simple task to skip.
Off topic, but....
I don't play much music either. I prefer to spend the time with my Wife talking, or in mutual silence watchingbthe World go by and I listen to the vehicle and the highway roll by.
A running antique VW will tell you a lot about its health ....... if you listen to it.
These quirks of mine keep me rolling without any serious mechanical problems.
I Err on the side of caution, my vacation time is too precious to waste making PREVENTABLE roadside repairs or waiting for a tow truck.
If I ever see you stranded along the highway, I'll stop and help.
I carry the tools, parts and supplies that are probably needed to get you rolling again.
Dave |
I would agree with Dave most Leaks or fails happen at night when it sits. Mine leaks more at night then on the road at the cap. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Mon Mar 26, 2018 8:17 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
Get serious. The major engine threatening leaks more often happen when the system is under the most pressure, namely when the engine is running.
Sure, sometimes you get leaks while cold and these can provide valuable warning that something is up. Pay attention to any sign of dripping, parked cold or hot under pressure when you stop for gas.
Seeing the level in the tank without opening the cap is a big advantage of the stock tanks. I doubt I would give that up. I have replaced quite a few stock tanks without many failures of the replacements. The main issues I see are from over tightening of the sensor in the tank leading to failure of the sensor.
Mark
andrew163980 wrote: |
Posted: Mon Mar 26, 2018 8:22 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
crazyvwvanman wrote: |
Mark
Well mine did would leak a tiny amount on road checks then would park it come back 1-2 hours and be a small puddle cup or so. Seems like the cap it holding on for life and the threads have served their job saving for the metal I love peace of mind and RMW is close. |
dsdunbar Samba Member
Joined: December 19, 2014 Posts: 564 Location: Crozet VA
Posted: Mon Mar 26, 2018 12:27 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
Dave,
I was the one that got your old tank and cap and just recently installed it in my van. I want to take another opportunity here to say "thanks" for the tank and cap. It is holding up awesome. _________________ '89 2WD Westy "Grey Goose" - Manual 4spd
Crozet VA
Vanaru EJ25, Peloquin |
FrankenSubySyncro Samba Member
Joined: May 03, 2007 Posts: 638 Location: Vancouver, WA.
Posted: Mon Mar 26, 2018 2:17 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
I am going to try a moroso 63773 aluminum tank on my svx build. It comes with a sight tube. Just need to buy the fittings and some new hoses.
https://www.summitracing.com/parts/mor-63773?seid=...o7EALw_wcB _________________ Syncronize it!
1987 Franken Syncro (converted 2WD auto)
2004 2.5 SOHC Subaru
F & R lockers, decoupler, SS, 6.17 R&P
Trans Cooler
EMPI race prepped 930 CVs and axles
Bilstein coilover front, rear ProComp MX-6066R shocks, 14" hypercoil springs
30x9.5 15" BFG Muds
Custom skid plates
Nose job (custom front bumper) http://www.flickr.com/photos/subyvanagon/sets/72157624970330925/ |
kamzcab86 Samba Moderator
Posted: Fri Apr 27, 2018 1:26 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
djkeev wrote: |
djkeev wrote: |
djkeev wrote: |
Now you will be incessantly opening the tank cap when cold to check the coolant level! (unless you completely trust idiot lights) |
I have queried this before but this seems fairly unnecessary to me and would be interested to see if the average person thinks this is necessary. I drive my van every day and have never felt the need to check the level in th RMW tank since I installed it and bled it. I would sell my van if I had so little faith in its intergrity that I felt compelled to do this incessantly. |
Yes, we have discussed this, not sure why you bring it up again.
Here is the link to your last query..... you might continue the discussion in there instead of doing it all over again here..........
It all has to do with the level of pre trip checking that you are comfortable with.
Dave |
Umm, actually you brought it up again |
As a "tongue in cheek" joke with Kam.
Did you notice the laughing emoji?
I know Kam is very diligent about her vehicle maintenance.
Dave |
So as not to take the RMW/VC thread off-topic, I'll respond to the above here.
First, I'll repeat what I posted over there: Went on a Lowe's run a few weeks ago. Arrived home to see a puddle... again. Blasted level sensor O-ring, only 2-3 years old, was hard as a rock. Two tanks, two level sensors, three O-rings in 8 years... damn the expense, but I'm done with that poorly-engineered plastic crap. And, as Dad said (happened to be visiting the day the tank arrived), the welds are works of art.
Second, to answer Mellow's question, I won't be taking the cap off every single time I drive the van. During a pre-flight check before a lengthy road trip, absolutely, but more for simple peace of mind. My van is an anomaly, based on all the topics around here : I've never had a bleed issue, have never had to open the radiator bleeder, and the expansion tank has never run low (nor did the plastic tank ever like being brim full -- it preferred being just above the upper hose). While it is a little weird not being able to glance at the reservoir and see the coolant level, my van has never (knock on wood) given me reason to be concerned about having this new metal tank installed. The only issues I have ever had with the plastic version: Leaky level sensors (thanks mainly to faulty O-rings) and 2 leaky tanks thanks to cracks, which all, fortunately, presented themselves at or near home.
Third, a bonus to the RMW tank: I got to cut about a foot off that overflow hose; no longer hovering over the A/C compressor as a result.
Fourth, here's a picture of the beauty installed:
_________________ ~Kamz
2016 Golf GTI S
?Waldo? Samba Member
Posted: Fri Apr 27, 2018 11:57 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
What level sensor does RMW use and is it available separate from the tank as a replacement part? |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Fri Apr 27, 2018 1:26 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
KamZ, as usual with the cleanest engine picture(s) I have ever seen. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Fri Apr 27, 2018 1:42 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
?Waldo? wrote: |
Sensor brand/part #, don't know, but, yes, it's available separately: http://www.van-cafe.com/home/van/page_2449_227/coolant_level_sensor_for_aluminum_reservoir.html .
The cap is available at your FLAPS -- Stant #31518.
bobbyblack wrote: |
KamZ, as usual with the cleanest engine picture(s) I have ever seen. |
Not the cleanest out there, but I try... _________________ ~Kamz
2016 Golf GTI S
Posted: Fri Apr 27, 2018 1:47 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
Cool. Thanks. |
RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Fri Apr 27, 2018 4:59 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
It sounds like the stock tanks (aftermarket) may have gotten worse. Years ago, when I installed my Subaru engine, I bought a later one (I have an '84) because it fit better in my cooling design. No problems whatsoever and there were no problems with the original. The vanagon tank looks to be made of the same material as the Passat I owned. That tank doesn't fail, but the glued in sensor does sometimes after 100,000 miles or more.
Plastic tanks are used everywhere and there is nothing wrong with using them, unless they are designed/manufactured badly or are experiencing some environmental factor outside of design limits. I'm an old engineer and saw the transition from craptastically cheap plastic to engineered plastics that are stronger than most steels. Most people still have a bias against plastics because of the cheap stuff toys (and poorly designed products) are made of. _________________ Rich |
jimf909 Samba Member
Posted: Fri Apr 27, 2018 5:08 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
?Waldo? wrote: |
Cool. Thanks. |
Hehe (as in coolant?) _________________ - Jim
Abscate wrote: |
Posted: Sat Apr 28, 2018 3:13 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
RichBenn wrote: |
Plastic tanks are used everywhere and there is nothing wrong with using them, unless they are designed/manufactured badly or are experiencing some environmental factor outside of design limits. I'm an old engineer and saw the transition from craptastically cheap plastic to engineered plastics that are stronger than most steels. Most people still have a bias against plastics because of the cheap stuff toys (and poorly designed products) are made of. |
My Grandfather (born in the 1880's) LOVED plastic!
He embraced plastic with great enthusiasm.
Early plastics were Bakelite and similar hard fragile items.
Honestly? They were crap, I thought so as a child, but he was forward looking for his day.
He would be standing right next to you expounding the attributes of plastic!
Me? I'm installing aluminum, steel and stainless getting rid of that plastic crap.
My Grandfather would be so very sad and disappointed in me........
Ghia
Vanagon
Beetle
chompy Samba Member
Joined: August 12, 2014 Posts: 400 Location: Cascade Locks
Posted: Sat Apr 28, 2018 6:12 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
Does anyone know how much coolant the rmw tank holds Compared to stock? Curious as I'm researching aluminum tanks at the moment. _________________ '81 Westfalia Subaru EJ22
Manual Transmission |
dhaines Samba Member
Joined: April 27, 2011 Posts: 43 Location: Denver, CO
Posted: Tue May 01, 2018 7:35 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
I got the tank to replace the crap factory plastic tank when I did my subaru conversion.
It is a fantastic tank, built to last and wont crack or leak like the plastic one did.
Not having to buy the stupid german style blue cap was another bonus.
The only downside that I have experienced is that some coolant can slowly weep out of the threads of the level sensor.
I have tried tightening up the sensor.
I have tried removing and redoing the thread tape.
I guess it must be hard to seal a plastic sensor against an aluminum tank. Probably something to do with different material expansion rates.
At the end of the day I just accepted the fact that this minor weeping of coolant was never going to stop.
If I every buy another van, I'd get a Tank for it as well. |
warrenmzz Samba Member
Posted: Tue May 01, 2018 7:56 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
dhaines wrote: |
I had the same weep from the level sensor. RMW sent me a new sensor. All good now - no weeping. |
