lbucci Samba Member
Joined: February 05, 2009 Posts: 10 Location: Norhtern, AZ
Posted: Tue May 01, 2018 8:42 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
Most large trucks use sight glasses in the pressure tank to quickly check coolant levels. Usually 2 to represent the full and low levels. These could be added to a new/ used RMW tank and would make a great addition. Even better if the tank came with them installed.
?Waldo? Samba Member
Posted: Tue May 01, 2018 8:53 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
Only one would be needed. Anything less than full is low. |
andrewvwco Samba Member
Joined: February 23, 2017 Posts: 298 Location: Estes Park colorado
Posted: Wed May 02, 2018 2:26 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
lbucci wrote: |
That is a great idea. thank you. |
msinabottle Samba Member
Posted: Tue May 29, 2018 8:00 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
How would we add a sight glass? Wouldn't one have to drill, tap, and collet? Or am I ignorant of something?
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32598 Location: Reading Pennsylvania
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Wed May 30, 2018 4:09 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
He said "bung". _________________ '90 Syncro Westy w/GW2.5L |
Posted: Wed May 30, 2018 6:05 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
[quote="djkeev"]
msinabottle wrote: |
Best! |
You of course need to get the correct size:
https://www.google.com/search?q=aluminum+weld+bung...mp;bih=600 |
Paulbeard Samba Member
Posted: Wed May 30, 2018 6:25 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
Now to see if RMW adds this to later versions of their tank.
It is tempting to replace the old plastic tank when you learn how hard it is to find a good pressure cap (just rolled back from my FLAPS where I tested one I ordered right at the counter and pronounced it DOA). I have an OEM one on the way but I figured if I had two, that was better. I expect the replacement they find will be no better but maybe I'll be surprised. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
baltik Samba Member
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
the joker Samba Member
Posted: Mon May 04, 2020 3:52 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
I like to see a version for the early 1.9L/ diesels engines, I may have one custom made |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17124 Location: Retired South Florida
Posted: Mon May 04, 2020 6:29 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
Mimicking a stock tank in aluminum is fairly straightforward. Weldable cap and hose bungs are readily available. Access to a shear and someone that can TIG weld and you have a tank.
But, for most folks, something like GW or RM is a good value for the cost. Unless they are fabricating them in Mexico, they aren’t making a lot of profit. They do solve a problem that can lead to a catastrophic engine failure. That’s good for business to have these out there running. _________________ ☮️ |
Posted: Mon May 04, 2020 2:48 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
I sent a feeler out to a local mariner /boat fabricated , he needs and old tank, to pull the numbers from but said it was doable cost he said a close estimate would come after the paper plan /mockup
I need to find a junk tank in the mean time, |
valvecovergasket Samba Member
Posted: Mon May 04, 2020 2:58 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
the joker wrote: |
its a bit of a custom job hose wise, but generally speaking the fitment is more or less a drop in, at least it was on tdi swap. no reason you couldnt make it work with the stock diesel hoses - this was hacked up due to lack of an oil warmer.
can easily swap the fittings for different hoses sizes to suit...
_________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4777 Location: Bemidji, MN
Posted: Mon May 04, 2020 3:25 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
Paulbeard wrote: |
It is tempting to replace the old plastic tank when you learn how hard it is to find a good pressure cap (just rolled back from my FLAPS where I tested one I ordered right at the counter and pronounced it DOA). I have an OEM one on the way but I figured if I had two, that was better. I expect the replacement they find will be no better but maybe I'll be surprised. |
i switched to the RMW tank in no small part because of the cap issue. i've found the RMW cap venting is so freakin' reliable that the overflow tank serves as a true level indicator, no sight glass needed. pressure tank is always plumb full. besides, there IS a level indicator... the tank probe and temp gauge LED. _________________ -dan
www.thefixitworkshop.com |
Posted: Mon May 04, 2020 6:25 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
the joker wrote: |
The original plastic tank would be hard and expensive to try and duplicate because of the rounded shape it has so that the plastic will not overly deform under pressure. If you are having a metal tank fabricated then having a flat sided tank is fine and would be way way cheaper. |
jimf909 Samba Member
Posted: Mon May 04, 2020 6:41 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
DanHoug wrote: |
Paulbeard wrote: |
i switched to the RMW tank in no small part because of the cap issue. i've found the RMW cap venting is so freakin' reliable that the overflow tank serves as a true level indicator, no sight glass needed. pressure tank is always plumb full. besides, there IS a level indicator... the tank probe and temp gauge LED. |
This has been my approach with the Bostig coolant tank. Checking the overflow tank is covers the van's needs, checking coolant in the pressure tank does not provide helpful additional information.
$299
_________________ - Jim
Abscate wrote: |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Mon May 04, 2020 7:45 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
jimf909 wrote: |
$299
Damn, that's beautiful! Well done Jim Akiba! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
coqcitywesty Samba Member
Joined: February 20, 2018 Posts: 401 Location: Coquitlam, BC
Posted: Tue May 05, 2020 10:23 am Post subject: Re: Stock coolant tank vs. RMW's The Tank |
^^^^^^ Agreed - beautiful workmanship! _________________ 1991 Westfalia EJ251, 1972 Volvo 1800 ES |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4087 Location: East Kootenay, British Columbia
Posted: Tue May 05, 2020 1:31 pm Post subject: Re: Stock coolant tank vs. RMW's The Tank |
jimf909 wrote: |
$299
Are you running the stock plastic Zetec thermostat housing? _________________ Currently:
