1974 Camper engine conversion! ABA 2.0
Page: Previous  1, 2, 3, 4, 5, 6, 7  Next
KrisBalfe
KrisBalfe is offline
PostPosted: Mon Jul 16, 2018 4:47 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
👍I'll see if I can remember to sketch something out for the next guy.
Should have done it with my ABA too.
Ride_On
Ride_On is offline
PostPosted: Mon Jul 16, 2018 9:01 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
How did I miss this!? Another local bus that has had open heart surgery. Great work, good luck finishing it off - it's SO worth it! Kudos to you for having the ability to DIY the conversion too - very impressive!
1977 Westfalia 2.0 FI Skills EJ25 w SubaruGears 5sp
https://www.thesamba.com/vw/forum/viewtopic.php?t=687254
2018 Golf Sportwagen 4MO DSG (Dieselgated 2013 Golf Wagon TDI DSG)
Ericfb
Ericfb is offline
PostPosted: Wed Jul 18, 2018 7:00 am    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
Thanks Ride_On, been a fun journey so far. Definitely looking forward to pulling away from stop signs with confidence!
My wiring isn't complete but I did not draw up a new diagram, Maybe it's laziness but it didn't feel necessary. Also keeping it as original as possible will make it easier to chase wires in the future - with original diagrams. Perhaps a solid list of wires that can be cut would be helpful for the next guy, although I think it's important to go through all the diagrams to get a good understand of what's going on behind all the sheathing.
Feeling much better, thanks Craig!
Ericfb
Ericfb is offline
PostPosted: Sun Oct 14, 2018 1:15 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
Update!
Nothing new with the camper, it's officially a storage rack for incomplete odds and ends. But for a good reason. Been a busy summer with family camping trips, new house (3 car garage woo hoo!) and a new job.
I am very excited to have this thing running for next spring - here in my part of Canada around May ish. Tent camping is going to be my motivation moving forward.
This is more of an interim update as it'll probably be another month before I can pick up the tools again. Just so you don't think I gave up Wink
vwwestyman
vwwestyman is offline
PostPosted: Sun Oct 14, 2018 1:35 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
Tent camping sure has its place, but Bus camping is so much easier!
Keep on keeping on.
Dave Cook
1973 Wild Westerner
My Thing
Ericfb
Ericfb is offline
PostPosted: Fri Dec 07, 2018 8:54 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
Finally got to turn some frosty wrenches. -13 Celsius today and had the afternoon off. Also figured I'd do a update post now that I can feel my fingers again.
Stock support bar with an "extension" welded to it so I could use the factory bolt holes.
Passenger side engine mount using threaded holes in the block. One of them used to house a plastic clip - not sure what the other was for. Seems solid, got my dad to lower the jack while I watched for flex and it didn't budge. Hopefully that remains the case. It's pretty damn close to my coolant flange.
Got most of my coolant system plumbed up. A few areas still need to be supported but as far as I'm concerned it's done, aside from the coolant bottle and hooking up the aux heater core which is pretty low on the priority list. Also need to wire my fans, but we'll call that wiring for now instead of plumbing Wink
2" Plastic conduit from lowes to protect my coolant hose from chafing.
Next up will be creating some sort of loop for the heater core, which should be easy but VW in their infinite wisdom designed it to have two different size openings so it's not as simple as looping a chunk of 5/8th hose. Grr.
Also have been avoiding the exhaust for a long time so i'll have to start scratching my head over that. Already bought a muffler so I think i'll just mount the muffler where I think it should go then just... curse and swear until it's connected to the manifold.
danfromsyr
danfromsyr is offline
PostPosted: Fri Dec 07, 2018 9:20 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
Soo am I seeing this as you have a solid motor mount?
that pass side bolted to the motor directly to the mustache bar w/o an isolating rubber mount?
if that's so. will make ALOT of LOUD engine/interior noise and vibration.
not saying I like the looks of your mount 'tabs' either but not here to nitpick.
just make sure the motor stays IN the engine compartment.
Abscate wrote:
vwwestyman
PostPosted: Fri Dec 07, 2018 11:06 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
As someone who had a hose connection come undone under the Bus and toast a motor: Please make sure your metal parts of the coolant lines have some kind of flange to prevent the rubber from slipping off, and also please clamp those rubber hoses!
Dave Cook
1973 Wild Westerner
My Thing
Abscate
Abscate is offline
PostPosted: Fri Dec 07, 2018 11:56 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
I think that's conduit for chafe, no clamps required
.ssS!
John Revolver
John Revolver is offline
PostPosted: Sat Dec 08, 2018 5:13 am    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
Epic journey so far man! keep up the great work
-1977 westfalia
-1967 21 window
-1991 mk2 gti
Ericfb
Ericfb is offline
PostPosted: Sat Dec 08, 2018 5:43 am    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
I appreciate your concerns Dan, I'll definitely be keeping a close eye on the tabs (and all my welds) for the first little while to make sure nothing is cracking or bending. The trans mount is still in place as a second line of defence so no need to worry about the engine falling out. Engine will be mounted on stock vw bus engine mounts - not pictured.
All hoses will have clamps, common guys 😉. Also here is my diy bead roller I made/ used on all the plumbing. I regret cheaping out and got the pliers with 6" grips rather than the larger pair but it got the job done with sore hands.
KrisBalfe
PostPosted: Sat Dec 08, 2018 2:58 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
👍🏼nice work.
Sloride
Sloride is offline
PostPosted: Thu Dec 27, 2018 6:44 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
Good to see you got time to work on it. Thought I’d see it on the road last summer. That said, I never really got out and about with my bus either. Was too busy coaching my kid’s basketball. Now that I’ve picked up a 64 beetle I’ve been spending the little garage time I have on that. Was sizing it up the other day and thinking subaru swap.
1972 Westfalia - 1.8 VW in-line h2o conversion
Ottawa, Ontario, Canada
Link to the engine swap:
http://www.thesamba.com/vw/forum/viewtopic.php?t=565304&highlight=
1964 Ruby Red Beetle
https://www.thesamba.com/vw/forum/viewtopic.php?t=705757&highlight=ruby+red
Ericfb
Ericfb is offline
PostPosted: Wed Jan 02, 2019 4:51 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
Oh man i'm jealous! A '64 beetle swap would be sweet.
That'll be my next project. My wife has a sweet spot for the convertible beetles.
vwwestyman
PostPosted: Wed Jan 02, 2019 7:01 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
What is the name of the tool you used to make the beads?
Dave Cook
1973 Wild Westerner
My Thing
Ericfb
Ericfb is offline
PostPosted: Wed Jan 02, 2019 7:10 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
I made it. Not sure they have a formal name but they work quite well and stow nicely in the toolbox.
Check out this video if you want to make your own set:
https://www.youtube.com/watch?v=JVDUM2ZxoW0
Ericfb
Ericfb is offline
PostPosted: Sat Jan 05, 2019 1:41 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
Got the exhaust done up last night. After staring at it for at least a few hours, I ended up using the stock manifold down pipe. I modified it by removing the elbow (section removed shown in pic) so it would shoot strait down where I welded in a few angles. I wouldn't qualify the sharp 90 degree angle as great for performance but as long as it's quiet and does it's job i'll be happy. Once leak tested, I plan on wrapping the whole thing in black exhaust wrap.
I also didn't have a flex pipe on hand, what are your thoughts? Give it a go as is, or suck it up and weld one in?
I figured it's such a short section that it wouldn't need one, also there is some "flex" where the manifold meets the down pipe. But that's mostly just me justifying not using one. I may also see if I can hang the exhaust off the engine - therefore eliminating the need as the exhaust will just move with the engine...
Sloride
Sloride is offline
PostPosted: Sat Jan 05, 2019 6:09 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
I’d be putting a flex joint in there. There isn’t enough flex at the dual down pipe.
vwwestyman
PostPosted: Sun Jan 06, 2019 12:24 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
What muffler have you got there?
Dave Cook
1973 Wild Westerner
My Thing
Ericfb
Ericfb is offline
PostPosted: Mon Jan 07, 2019 5:54 pm    Post subject: Re: 1974 Camper engine conversion! ABA 2.0 Reply with quote
Its a Walker "pro-fit economy" muffler. Part # 17914. 6" round, body is 18". 2" in/out
Page 3 of 7
