Mrshaund79 Samba Member
Posted: Sat Dec 03, 2022 10:04 am Post subject: Re: Subaru swap guide/info |
I just came across this thread as I have decided to go the swap route, I am trying to find an Ej20t to put in my 74, my question is do I need to go full roll cage doing this, as I want the car to look stock as possible. Most vids I have found have full roll cage.
Also with cutting the firewall am I going to have to delete the rear seat completely? |
mauricemonge Samba Member
Joined: October 19, 2015 Posts: 63 Location: San Jose
Posted: Sat Dec 03, 2022 10:42 am Post subject: Re: Subaru swap guide/info |
Mrshaund79 wrote: |
If you keep the turbo in the stock location, the back luggage area will need to be cut, but you’ll keep your back seat. Custom headers could put the turbo anywhere, but stock location is kinda nice since there’s less modifying.
I think people put in a roll cage because crashing at the speeds you can reach can be deadly. I maxed out at 120mph with a stock non turbo 2.5. A stock turbo motor could probably get you around 150+. I’ve only been to 135 a number of times, and there’s a lot more to go, these cars don’t crash well.
You’d likely need a truss bar in the back, the extra weight and power of the engine would flex the frame horns a bunch. |
bruceo98 Samba Member
Posted: Sun Jan 15, 2023 2:46 pm Post subject: Re: Subaru swap guide/info |
Running a Subaru transmission. What shifter are you using ? _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
Posted: Sun Jan 15, 2023 4:33 pm Post subject: Re: Subaru swap guide/info |
bruceo98 wrote: |
Running a Subaru transmission. What shifter are you using ? |
An Acura RSX shifter from the junk yard. A lot of manual Honda’s use cable shifters. I made my own linkage setup. It’s simple but it works. |
Posted: Sun Jan 15, 2023 4:52 pm Post subject: Re: Subaru swap guide/info |
Really? I thought they had to use the linkage with the Subarugears adapter. Have any pictures of your setup? _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
Posted: Sun Jan 15, 2023 4:56 pm Post subject: Re: Subaru swap guide/info |
bruceo98 wrote: |
Really? I thought they had to use the linkage with the Subarugears adapter. Have any pictures of your setup? |
I’ll grab some pics later. I’m mid engine, so I had to go with a cable setup. |
Posted: Sun Jan 15, 2023 5:44 pm Post subject: Re: Subaru swap guide/info |
Ok thanks . Must use 2 cables? Trying to visualize this . _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
Posted: Tue Jan 17, 2023 8:04 pm Post subject: Re: Subaru swap guide/info |
Does anyone know what axles (length) I’ll have to get running a Subaru transmission? And who sells them? I’m guessing I’ll have to get the Subarugear extended axle stubs that go in the trans so they will be shorter . What is everyone running on the axle stub on the control arms . I see where you can get kombi 100 mm or 930 . This has me confused as to what combo will work . _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
Posted: Tue Jan 17, 2023 8:29 pm Post subject: Re: Subaru swap guide/info |
bruceo98 wrote: |
Does anyone know what axles (length) I’ll have to get running a Subaru transmission? And who sells them? I’m guessing I’ll have to get the Subarugear extended axle stubs that go in the trans so they will be shorter . What is everyone running on the axle stub on the control arms . I see where you can get kombi 100 mm or 930 . This has me confused as to what combo will work . |
I run 15.625” axle length with 930 CV joints. I ran the same axles with a bus transmission too. If your car is slammed and have totally flat axles, you might be able to go shorter.
If you’re really worried, I could possibly be convinced to remove my coilover and tire, and see how it spins at full compression. |
Posted: Tue Jan 17, 2023 9:03 pm Post subject: Re: Subaru swap guide/info |
If you’re really worried, I could possibly be convinced to remove my coilover and tire, and see how it spins at full compression.[/quote]
Is that a custom length axle? Where do you get them from? When you say you are running 930 cv joints do you have to change the axle stub on the control arm on an irs to fit them? I’m sure the bolt pattern is different, is it? _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
Posted: Tue Jan 17, 2023 9:30 pm Post subject: Re: Subaru swap guide/info |
bruceo98 wrote: |
Is that a custom length axle? Where do you get them from? When you say you are running 930 cv joints do you have to change the axle stub on the control arm on an irs to fit them? I’m sure the bolt pattern is different, is it?[/quote]
I got them from pacific customs, just looked and they’re still there in that size. You’d need different stub axles. They’re a bigger diameter than bug or bus, and they’ll handle solid power. Never had problems even with the least expensive empi cv joints and axles, even with launching hard on them. |
