Let the process of saving 2222069996 begin
Page: Previous  1, 2, 3  Next
Wasted youth
Wasted youth is offline
PostPosted: Thu Apr 12, 2018 9:46 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Thank you for spelling brakes and Bentley correctly.
Booster and Servo are the same part, as far as I know. I had my 1977 servo/booster rebuilt by Karps in Southern California. They did a great job.
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
malcolm2
malcolm2 is offline
PostPosted: Mon Apr 16, 2018 7:16 am    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Spent lots of time on the bus this rainy weekend.
2nd failed attempt to push the caliper pistons out. Decided to go with 72 calipers. Ordered and on the way.
Re assembled the CV joints they were cleaned and inspected a few weeks back. Made sure that the small tab on one part was pointing to the large tab on the other part. Everything moves properly. Painted the axle shafts... ORANGE!
Removed the upper brake fluid res and the pipe leading to the lower res. Had to remove the drivers seat. Did some wire brushing and vacuuming on and under the seat perches. Brake fluid had been leaking for a while.
Took a closer look at the hard brake lines for the front. Some are good, some are not.
My Toys: '75 Porsche 914, '86 VW MK1 Cabriolet, '92 Ski Nautique and now a 1972 VW Transporter Deluxe
malcolm2
malcolm2 is offline
PostPosted: Mon Apr 16, 2018 8:56 am    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
The little stuff makes me feel like I am going NOWHERE. But it has to be done.
malcolm2
malcolm2 is offline
PostPosted: Thu May 03, 2018 7:50 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
UPdate: the bus is almost totally disassembled. Front and rear axles remain. Rear hatch window and front windshield remain. That is about it.
Now that I almost have nothing but a shell, I need some advice.
I have spent quite a bit of time under the bus. Looks like mostly surface rust. I do see some holes in places.... WHAT SHOULD I DO?
I thought I would try to use one of those cheap sandblasters Rolling Eyes .... what ever I do how do I have to move it? Either to my street for some lying on my back blasting or to a pro. I have a blaster guy near me at work, gonna go talk to him tomorrow. I always see rotisseries in his yard.
Guess I'll have to make a roller out of it, or build a cart of some kind.
THoughts?
KentPS Premium Member
KentPS is offline
PostPosted: Thu May 03, 2018 8:40 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
malcolm2 wrote:
THoughts?
My thought is I'm not the only one who is going to learn to MIG weld soon. Cool
You will find a lot of good info in the Samba Body/Paint forum.
As for the surface rust on the underside, from all I've read on the subject, it's easiest to use one of the rust converter products (like POR-15, which is getting less popular lately), then prime, paint and undercoat it. That sounds like a lot less work than trying to blast off all the surface rust, after which you still have to prime, paint and undercoat it.
Of course, holes need to be patched first. MIG time!
-Kent-
1976 Riviera, my 1.7l FI chrome yellow VAN - "Chloe"
--> Whatever you do, have fun doing it! Smile
WildIdea wrote:
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. Its.... like driving a celebration!"
malcolm2
malcolm2 is offline
PostPosted: Fri May 04, 2018 6:32 am    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
KentPS wrote:
malcolm2 wrote:
THoughts?
Well, that is a thought. POR just came out with a new rust remover. I bought a gallon and thought I would try it. Problem is that they want you to "submerge" the work piece. At least 20 minutes up to overnight.... HA. I will be working on the underside of the floor!
I did ask them if working on smaller sections and just using a paint brush, continually "painting" for 20 minutes, keeping the section wet would work.
Since it is new, they can't promise anything, but the guy thought that method would work. Can't hurt to try.
I also thought maybe I would attempt to replace the whole floor. Once the floor panels are removed I would have a good view of the beams... Cool
malcolm2
malcolm2 is offline
PostPosted: Tue May 08, 2018 1:03 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Rust Remover is only working on items that are submerged. As the directions say. So if you have small parts or several sized buckets it will work. I have been leaving items in the bath overnite, then turning them over and pulling them out after work.
Here is the rear "whatcha ma call it", hub maybe, bearing carrier Question ? soaked on one side over nite. you can see the clean line.
I spent 3 hours on the Steering Wheel and Steering column last night. Those small castle nuts on the connection with the gear box had rusted cotter pins.
I ended up breaking the ends off of the pins and just wrenching them off. Now I can't get the horn button out. My steering wheel is all cracked and the center hub is breaking up. I guess a WTB is in my future.
My Pitman Arm puller should arrive this evening, so maybe I can get the gearbox off tonight. Not much stuff left on this bus.
Clatter
Clatter is offline
PostPosted: Tue May 08, 2018 1:16 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Time to build that rotisserie!!
Bus Motor Build
Fastback Build
malcolm2
malcolm2 is offline
PostPosted: Tue May 08, 2018 6:58 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
I need to build a BARN 1st. I have no room. Too many cars. I am leaning toward letting someone else blast it.
Clatter
Clatter is offline
PostPosted: Wed May 09, 2018 11:15 am    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Nowadays, there are more and more of those mobile wet-blasting outfits.
They show up, and, if it's a nice day, they can do it all in one day in your driveway.
Because it's wet, they don't warp panels, and can totally haul ass.
Plus, it's dust-free, so the neighbors can't complain.
Bus Motor Build
Fastback Build
malcolm2
malcolm2 is offline
PostPosted: Wed May 09, 2018 2:40 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
I need to check that out. Hell, buy a franchise😜🚌
vwwestyman
vwwestyman is offline
PostPosted: Wed May 09, 2018 4:19 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
I was thinking the same thing! First I'd heard of it.
Dave Cook
Stuartzickefoose wrote:
I'm gonna punch vwwestyman then shake his hand when I meet him.
notchboy wrote:
Ill just punch you in the face. Wink
1973 Wild Westerner
My Thing
malcolm2
malcolm2 is offline
PostPosted: Fri May 11, 2018 10:37 am    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
I used a cheapo sandblast gun from HF when I re-did my 914. It just won't cut it now so I bought a nicer one. Still cheap tho, from Amazon. Made quick work of the front torsion arm surface rust and undercoating splatter. Works great on small parts like this.
I had a bucket of filtered play sand and a large blue tarp. Sat in the front yard and blasted for 2 hours. 50 lbs of sand lasted me that long. I dumped the tarp back in the bucket and it was still half full. Probably cleaned 8 parts. A couple of the arms, the rear hubs, the trailing arms, the backing plates, the stick shift.
I will use up the Rust Remover or save it for nuts and bolts. Very small stuff. But the blaster is 100% better. Next will be POR metal ready and then paint. Maybe just rustoleum rattle can stuff.
malcolm2
malcolm2 is offline
PostPosted: Fri May 11, 2018 10:44 am    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
By the way... I found a mobile blaster. I sent him a request for quote. We shall see.
https://www.countylinemobileblasting.com/
Tcash
Tcash is offline
PostPosted: Fri May 11, 2018 11:32 am    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Do yourself a favor and put some anti-seize an the threads of the brake adjuster so it does not rust solid.
Lightly coat the thread and the shaft splines of the stub axle. So the nut and brake drum do not rust in place.
Good luck
Tcash
malcolm2
malcolm2 is offline
PostPosted: Fri May 11, 2018 11:47 am    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Good luck
Tcash
Hell no, the next guy (in 46 more years) Very Happy needs to work as hard as I have.
Just kidding. Everything is gonna get a coating.
malcolm2
malcolm2 is offline
PostPosted: Sun May 20, 2018 5:04 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
steering box is out and in pieces. Waiting on parts now. Photos on assembly.
Pulled the front axle to clean it up and remove the pivot mechanism. Purchased the rebuild kit. Funny, BugHaus' ebay site had it for way cheaper than their actual site.
Anyway, the Axle was loaded up with tar and grease and rust. So I am glad I pulled it. I would have been on my back all weekend. 8 bolts and it's out and on the table.
I think I spent 8 hours, removing, it, cleaning it, and prepping it for paint with marine clean and metal ready. I think I am gonna use POR 15 gloss black, then maybe a quick topcoat with rattle can.
malcolm2
malcolm2 is offline
PostPosted: Sun May 20, 2018 5:07 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
and then on to the wheel well. TAR everywhere. Figured I would scrape it off and look for rust. No rust in this picture. But there is some to the right and to the left. 3 holes left and one big one right.
LEFT, in and under the lowest part of the door.
Small spot on the jack point.
Tcash
Tcash is offline
PostPosted: Sun May 20, 2018 7:37 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
Note wear the front beam rust. Water collects in the bottom of the trough.
My thought was to drill weep holes and install duck bill drains.
https://www.thesamba.com/vw/classifieds/detail.php?id=1490056
Good luck
Tcash
77 Front Beam Rebuild Reply with quote Edit/Delete this post Delete this post View IP address of poster
https://www.thesamba.com/vw/forum/viewtopic.php?p=7099422#7099422
malcolm2
malcolm2 is offline
PostPosted: Sun May 20, 2018 8:02 pm    Post subject: Re: Let the process of saving 2222069996 begin Reply with quote
I poked a coat hanger in and did not feel any blockage. Nothing came out either when i rinsed. I suppose mine have not clogged. Thanks for the info. I dig deeper and double check further.
Page 2 of 3
