Gauche1968 Samba Member
Posted: Mon Mar 26, 2018 1:01 pm Post subject: Lubricate Brake Slide Pins? |
Not sure the correct terminology, but should one lubricate the pins that the brake pads slide on on an early WBX with the early style dual piston calipers? _________________ 1984 Vanagon GL
1984 Vanagon Westy |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Mon Mar 26, 2018 9:58 pm Post subject: Re: Lubricate Brake Slide Pins? |
Yes you should.
There is special grease for it.
https://www.google.com/search?source=hp&ei=2s6...KzbB0cw%3D _________________ This free advice is worth exactly what you paid for it.
Posted: Tue Mar 27, 2018 11:08 am Post subject: Re: Lubricate Brake Slide Pins? |
Ah, thanks!
I have some of that somewhere! _________________ 1984 Vanagon GL
danfromsyr Samba Member
Posted: Tue Mar 27, 2018 1:58 pm Post subject: Re: Lubricate Brake Slide Pins? |
I tend to buff them on the wire brush as well.
the surface gets rough over time. _________________
Abscate wrote: |
vanagonjon Samba Member
Posted: Wed Mar 28, 2018 3:49 am Post subject: Re: Lubricate Brake Slide Pins? |
If the surface is rough, replace the pins. Using a wire wheel to clean the pins usually removes a lot of the plating that is protecting the metal. Without the plating the pins will rust very quickly, especially in areas where road salt is used.
John |
