67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Tue Mar 27, 2018 4:54 pm Post subject: "J" tubes and sled tins |
I'm at a point in my engine build that I am installing the exhaust.
I have an 1 5/8" merged header and the "J" tubes pass below the push rod tubes.
I'm kinda at a loss as to what to do about sled tins to deflect the spent cooling air out the rear of the lower portion of the engine.
I did a search and found a few tins that were modified and some were custom made. But really none of them were great.
So I'm curious. What have you done when running "J" tubes? _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76947 Location: Sneaking up behind you
Posted: Tue Mar 27, 2018 5:26 pm Post subject: Re: "J" tubes and sled tins |
You're going to have to modify stock sleds and fabricate tins to close it off. Industrial tins will not work with that header. _________________ Glenn
Member #1009
#BlueSquare |
modok Samba Member
Posted: Tue Mar 27, 2018 5:55 pm Post subject: Re: "J" tubes and sled tins |
Although some maintain that the sled tins aid cooling, I'm not really convinced..... I mean....maybe, it is logical to direct the hot air backward if the car is going forwards, but the air under there is going all different directions, so common sense may not actually work. Certianly the first 2" of the sled tins are important because they have a shape in them that directs the air AROUND the cylinders, just like the back smaller pieces that bolt below the upper tins. In fact, they may be identical, I know one side is but maybe not #3. yeah, if you cut the #1 sled tin you can make it into a #4 rear deflector.
Anyway, right sled tin is important to run if you have a thermostat, but if you don't, then, maybe it isn't worth re-creating the sled tins exactly VW did. You can make your own solution. |
Glenn Mr. 010
Posted: Tue Mar 27, 2018 6:41 pm Post subject: Re: "J" tubes and sled tins |
modok wrote: |
You can't fit the thermostat one most headers that run under the cylinders. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Tue Mar 27, 2018 8:31 pm Post subject: Re: "J" tubes and sled tins |
Sadly there will be no therostat on this build. So that will not interfere wit the sled tins.
So what I'm guessing is that most don't even run sled tins with "J" tubes.
Thank you for the input so far. _________________ I have learned over the years.
Buy Once, Cry Once!
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Tue Mar 27, 2018 8:54 pm Post subject: Re: "J" tubes and sled tins |
You can make them fit. A simple washer welded and a hose clamp makes for a secure fit |
jason Samba Member
Posted: Wed Mar 28, 2018 8:18 am Post subject: Re: "J" tubes and sled tins |
I remember that they help over 45mph. Hard for the air to exit underneath, high pressure low pressure not playing well. If you have ever messed with HVAC, you’ll understand. I just cut a hole and put it through. Industrial tins on outside |
Glenn Mr. 010
Posted: Wed Mar 28, 2018 9:02 am Post subject: Re: "J" tubes and sled tins |
The Berg headers clear the thermostat and stock sleds.
Member #1009
#BlueSquare |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed Mar 28, 2018 9:17 am Post subject: Re: "J" tubes and sled tins |
I have not run thermostat or sled tins in over 30 years and none of my engines have ever melted down. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Wed Mar 28, 2018 12:35 pm Post subject: Re: "J" tubes and sled tins |
Quote: |
I have not run thermostat or sled tins in over 30 years and none of my engines have ever melted down. |
That is a worthless statement because there is no way to measure the effect ( good, bad or indifferent) of simply leaving parts of the motor and saying " it didnt melt down ". |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9969 Location: Huntington Beach, CA
Posted: Wed Mar 28, 2018 12:43 pm Post subject: Re: "J" tubes and sled tins |
I have an Empi 1 5/8" hide away muffler installed on my 1600. The sled tins fit great, no interference.
Now, after I installed the muffler, it seemed like the car was running hotter, than it did with the stock muffler with heater boxes. So, I bought an IR temperature gun and kept it in the glove box. I recorded, for over two weeks the temperature at the head, right next to the exhaust exit port. I do not remember the numbers, I would have to get back into my old notes, but the temps surprised me, I wanna say around 265. So, I fabricated some Industrial tins from a template from tS. Bolted them onto the engine and went for a drive. They do not bolt to the heads, they just rest upon them on the underside near the valve cover gasket. With the IR gun, I noted a rough 40 degrees drop on both sides, at that spot on the heads. The car no longer smelled hot or acted like it was hot. It has been a great improvement! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
yamaducci Samba Member
Joined: March 30, 2010 Posts: 2335 Location: Mount Airy, Maryland
Posted: Wed Mar 28, 2018 2:10 pm Post subject: Re: "J" tubes and sled tins |
I just posted in my rebuild thread a few pics where I fit the sled and industrial tins around the roll cage. Which is like a header. What I did was use a hole saw to cut a hole where the tube will go through the sled tin, cleaned it up with a die grinder and then cut the tin in half across the hole with an air-hacksaw. The top part of the tin bolts to the cylinder shroud and the bottom part bolts to the case. The industrial tins bolt to the lower sled. _________________ -John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested. |
Posted: Wed Mar 28, 2018 5:19 pm Post subject: Re: "J" tubes and sled tins |
VW_Jimbo wrote: |
So, I fabricated some Industrial tins from a template from tS. Bolted them onto the engine and went for a drive. They do not bolt to the heads, they just rest upon them on the underside near the valve cover gasket. With the IR gun, I noted a rough 40 degrees drop on both sides, at that spot on the heads. The car no longer smelled hot or acted like it was hot. It has been a great improvement! |
I have the same exhaust system with the hide away muffler.
Do you remember the link for the sled tin template?
I picked up a crappy set of sled tins from Avery's Aircooled last weekend knowing that I would need to fabricate/fit them with the header.
I can only imagine the head temps with a 2180.
This is what I'm dealing with,
Buy Once, Cry Once!
Glenn Mr. 010
Posted: Wed Mar 28, 2018 5:27 pm Post subject: Re: "J" tubes and sled tins |
VW_Jimbo wrote: |
I have an Empi 1 5/8" hide away muffler installed on my 1600. |
1-5/8" is way too big for a 1600. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Mar 28, 2018 6:05 pm Post subject: Re: "J" tubes and sled tins |
Glenn wrote: |
VW_Jimbo wrote: |
1-5/8" is way too big for a 1600. |
He might be just referring to the muffler.
But for a header? Yeah, I agree that it's too big. _________________ I have learned over the years.
Buy Once, Cry Once!
