1976 914 Alternator Light
Mikedrevguy
Mikedrevguy is offline
PostPosted: Thu Mar 29, 2018 10:27 am    Post subject: 1976 914 Alternator Light Reply with quote
Situation- alternator not charging and light not lighting at startup.
If I externally ground the light, it will light, but, s not grounded on its own.
Where would I check this for the bad ground?
Thanks
74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!!
Starbucket
Starbucket is offline
PostPosted: Fri Mar 30, 2018 1:07 pm    Post subject: Re: 1976 914 Alternator Light Reply with quote
I believe it doesn't use a ground as it just completes the circuit so if bulb is burned out = no charge. Check your alt. brushes.
Mikedrevguy
PostPosted: Fri Mar 30, 2018 1:28 pm    Post subject: Re: 1976 914 Alternator Light Reply with quote
Bulb is not burned out. Have checked with known good bulb and socket.
Key on- alt- light does not light.
76 914 with 2260
79 VW Iltis
69 Bwajaja
Starbucket
PostPosted: Fri Mar 30, 2018 3:14 pm    Post subject: Re: 1976 914 Alternator Light Reply with quote
Trace the wires looking for bad connection, if all good take alt. to flaps and get it tested.
Mikedrevguy
PostPosted: Fri Mar 30, 2018 3:46 pm    Post subject: Re: 1976 914 Alternator Light Reply with quote
Thanks.
76 914 with 2260
79 VW Iltis
69 Bwajaja
Starbucket
PostPosted: Sat Mar 31, 2018 2:12 pm    Post subject: Re: 1976 914 Alternator Light Reply with quote
Check autohauseaz.com if you need parts.
[email protected]
dr914@autoatlanta.com is offline
PostPosted: Mon Apr 02, 2018 11:00 am    Post subject: Re: 1976 914 Alternator Light Reply with quote
make sure that you have power to the red with white that connects to the bulb, go to the blue wire and first check to see, with the key in the on position if you have a ground. If not, go to the front of the relay board in the engine compartment, remove the two rear phillips screws and back the board back, pry off the top exposing the two rows of pins like eggs in a carton, hook your test light to the positive post of the battery, pull the bulb out of the alt light socket and see if the blue wire is grounded. If it is there is a break, if it is not then substitute the voltage regulator. If that does not make a difference then replace the alternator. Make sure that the alternator harness is firmly plugged into the replay board and properly connected to the back of the alternator.
Mikedrevguy
PostPosted: Mon Apr 09, 2018 10:04 am    Post subject: Re: 1976 914 Alternator Light Reply with quote
thanks for the direction. so far haven't gotten past discovering that the blue white is NOT grounded with the key is on (or at least it is a very intermittently poor ground.
discovered a bit of a rats nest behind the instrument cluster. surprise surprise.
biggest so far was the terminal ends of the red/white power wires taped to the lead of a blue/yellow. Blue/yellow dives back into the wiring harness taped together. has micro spade connector, but these were taped with electrical tape.
any suggestions/hints on what this might be connected to?
also, there's a stray black/yellow strip wire. it, too, has a micro spade connector/
thanks again.
Mike
76 914 with 2260
79 VW Iltis
69 Bwajaja
