School me on Solar
syncro surf
syncro surf is offline
PostPosted: Fri Mar 30, 2018 2:48 pm    Post subject: School me on Solar Reply with quote
A buddy of mine just installed a solar system on his Sprinter. When I went to check the progress I was fairly blown away by the complexity of his set up.
Powered by 400 watts of panels. Can some of you experts tell me if this a crazy install or is this just what it takes? I have gathered that most vanagons run about 200 watts. Is 400 watts the issue here?
E1
E1 is offline
PostPosted: Fri Mar 30, 2018 3:15 pm    Post subject: Re: School me on Solar Reply with quote
Gadget Kings will love that.
I'm simple-minded so do not.
The more crap you have, the more issues you will have ó an eternal and unavoidable truth in almost everything.
We have a 120-watt portable (highly recommend a portable if you're parked much) charging two 100aH AGMs, wired to GoWesty's 1100-watt inverter for the times we run a blender. If never needing that level of power, I'd buy a smaller inverter of maybe 400 watts to save power.
Here in the sunny West, it's enough to keep a laptop charged all day while running a 27" monitor and have enough left over to crank tunes and/or watch a movie or two on said monitor when pitch black.
Not a tech guy but have run this setup full-time for nearly five years. I paid a good installer with more cerebral capacity than I (small feat, that), and paid extra for big cable and a great isolator. I also let the alternator charge all three batteries, which saves a ton of solar time though totals an alternator every couple years.
If doing this all over I'd do it exactly this way again, though I might add a charger on those two weeks a year we have shore power.
1984 Westy-Ferrari firing at 33% capacity
I drive by the seat of my pants but then get behind on my steering
Thank You Bob Lazier, Forever Golden
0to60in6min
0to60in6min is offline
PostPosted: Fri Mar 30, 2018 3:19 pm    Post subject: Re: School me on Solar Reply with quote
it's not an issue...it depends on his electrical consumption...
similar to a 90hp WBX compared to a Subaru 3.0 with 200+hp... is it an issue? Very Happy
E1
E1 is offline
PostPosted: Fri Mar 30, 2018 3:32 pm    Post subject: Re: School me on Solar Reply with quote
The 90 isn't unless you wanna climb a hill. Laughing
shagginwagon83
shagginwagon83 is offline
PostPosted: Fri Mar 30, 2018 3:40 pm    Post subject: Re: School me on Solar Reply with quote
I don't think the wattage is any relevance in this situation. More wattage, more need for bigger controller to handle that.
That being said, if it is a lithium battery setup. This setup probably also charges through the alternator. I don't think lithium batteries like being over charged. So I would imagine there is some sort relay there that shuts off current once that battery us fully charged.
That being said I'm sort of new to solar and would love to see the wiring diagram for that bad boy.
Brandon
"Jo Ann" - 1983.5 Ivory Westfalia 1.9L 2wd
Yellow Rabbit
Yellow Rabbit is offline
PostPosted: Fri Mar 30, 2018 3:50 pm    Post subject: Re: School me on Solar Reply with quote
Whatís the rush? I donít know why you would you need more than 83 hp anyway. Very Happy
E1, what portable setup do you have? I also need to get something soon.
1985 Westfalia GL
E1
E1 is offline
PostPosted: Fri Mar 30, 2018 3:56 pm    Post subject: Re: School me on Solar Reply with quote
83? WOW, mine's only 82!!! Laughing
(probably 70 nowÖ)
Edit: Not in a hurry at all, the only time I'd like more hp (torque, reallyÖ) is for heavy off road action.
Panel is from Zamp Solar in Bend. 25-year warranty, not cheap but worth the dough in my experience.
Probably has 1,000 days' use now, I'd buy another one in a minute.
RichBenn
RichBenn is offline
PostPosted: Fri Mar 30, 2018 5:05 pm    Post subject: Re: School me on Solar Reply with quote
The smart move on solar is:
1. Reduce consumption first. LEDs are WAY cheaper than solar. You also do not probably need 110 volt appliances. Plenty of DC and hand crank appliances. nverters cost the batteries, even when there is no load.
2. Figure your needs in a 24 hr. period, then in a weekend. Typical big draw items are DC fridges, propex heater fan, followed by big hifi subwoofered audio.
3. Use an MPPT controller to eek out extra so you don't need as much panel.
4. Plan on draining your batteries only 50% down if you want them to have a normal life.
The short rule of thumb- 60 watt panel/55 amp battery- if you have no power big draw items (see number 2). 100 plus watts panels/100 aH if you have one big draw item. 200 or so watts/2 6V 200ah batteries if you have 2 or more big draws. Naturaly this will vary some, but a good starting point for what works reasonably in the small vanagon.
Rich
jmillsj
jmillsj is offline
PostPosted: Fri Mar 30, 2018 5:21 pm    Post subject: Re: School me on Solar Reply with quote
Thatís a very nice set-up. Those are Victron Energy lithium iron phosphate batteries and they have an external battery management system, which is a lot of what you see. Itís nicely done.
1985 Vanagon Westfalia EJ25
Vanagon owner since 1995
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Mar 30, 2018 5:33 pm    Post subject: Re: School me on Solar Reply with quote
Your buddy's system is loaded for bear.
Some of the items I can not identify.
Without a system diagram it is hard to say what all is going on BUT,
it looks like a system with more and bigger bells and louder whistles than you can fit in a Vanagon!
A lot looks networked and who knows all the charge paths and discharge circuits and not forgetting the manual (red) switch combinations.
400 watts of panels may or may not be enough for this rig.
I am impressed (depressed?) seeing all that hardware in there.
it is not inexpensive and likely way overkill for a Vanagon.
RichBenn
RichBenn is offline
And.... pricy! I would love to have those, as they can be drained farther thus taking less space for the same "real" capacity, plus they supposedly last longer. But I just could not justify the cost. Too bleeding edge for my wallet.
Rich
syncro surf
PostPosted: Fri Mar 30, 2018 5:39 pm    Post subject: Re: School me on Solar Reply with quote
I just meant is 400 watts the reason for the complexity of the system. I am thinking about a 200 watt system for my syncro, but I wasn't imagining anything like this. Sounds like maybe the batteries have a bit to do with it.
r39o
Samba Polizei
r39o is offline
PostPosted: Fri Mar 30, 2018 5:41 pm    Post subject: Re: School me on Solar Reply with quote
#MeToo
I have been happy with 110ah provided by two golf cart batteries and 60 watts of panels for many years now.
That on the cheap system was like $600 added up.
That person spent kilo bucks on all that electro bling.
erste
erste is offline
PostPosted: Fri Mar 30, 2018 6:14 pm    Post subject: Re: School me on Solar Reply with quote
your buddy's setup is awesome and looks very well done, but don't let the complexity scare you away from adding solar to your syncro.
Here's a picture of my more modest setup for reference (in the middle of a stereo install so some stuff is unhooked / unfinished):
- Optima yellow top
- Solar Epic 10A MPPT charge controller
- Solar Epic MT-50 remote display (mounted in the side panel behind the driver's seat)
- Blue Sea Systems ACR
- Blue Sea Systems Fuse Holders
- Blue Sea Systems Fuse panel
- Kingsolar 120w flexible solar panel (not shown / mounted on roof rack) this panel gets returned a lot on amazon for minimal damage to the plastic where it cracks at the ferrules, so you can get a pretty good deal on it. Flexible panels won't have the same longevity of rigid panels though.
As you can see, everything pretty much fits under the driver's seat. If I were to add another panel I'd probably need a 20A charge controller, which is larger and wouldn't fit under the seat with the fuse panel there.
The yellow top probably isn't ideal, but I've been happy with it and it meets my needs so far.
I would point out that the MT-50 will shut everything down to preserve the battery at only like 11.5v, so you really only have 1.5-2 volts to play with, which was not the impression I got even after tons of research.
If you search this forum you'll find a lot of solar threads with wiring diagrams that will help point you in the right direction.
The one special tool that I didn't know about or have was this lug crimping tool:
https://www.amazon.com/gp/product/B003X51S00/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
good luck with your system!
E1
E1 is offline
PostPosted: Fri Mar 30, 2018 6:47 pm    Post subject: Re: School me on Solar Reply with quote
Very cool build!
Are you saying your Optima holds 13.0-13.5 volts, or shows that as a surface charge in daylight?
erste
erste is offline
PostPosted: Fri Mar 30, 2018 7:28 pm    Post subject: Re: School me on Solar Reply with quote
E1 wrote:
Very cool build!
Thanks E1.
Max voltage I've seen off the panel (topped up in full sun without anything except the fridge being used) is 13.5v or 13.7v. I believe the MT-50 indicates it's 100% full at that point.
The van sat once for about a week and a half without being driven and it was cloudy. The fridge and CO monitor took the battery down to 11.2 or 11.5 during that time and the MT-50 stopped letting them draw power at that point. I was confused and thought something went wrong, but it's just standard operation to save the battery. You tell the MT-50 what batteries (starting / aux) are in the system and it adjusts based on those inputs.
E1
E1 is offline
PostPosted: Fri Mar 30, 2018 8:54 pm    Post subject: Re: School me on Solar Reply with quote
Thanks, Erste. Our inverter has an alarm at 11, but it hasn't gone off for two years. We watch it closely and shut down at 11.5 as a bottom. But we use a Yeti and block ice so no draw there (and why we bought a Yeti to focus power on a monitor).
I see mid-13s in the sun, too, but it drops with the sun even with zero load. My understanding is a battery can't store much above 12.7 volts for long. Even if we do a full day of blinding charge and no load, the next morning the batteries are still only at 12.72. Ours are AGMs, seems lead acid holds either slightly more or slightly less, not sure. Our controller is a simple, on-panel unit to prevent overcharge.
If I need a long day's power and it's pouring, maybe once every 30 days, we resort to firing the "big generator," all 1.9 liters of 'er. We use very close to one gallon's gas for an hour's idle and that gets us roughly 0.7 volts of charge. Only used in moments of desperation.
RichBenn
RichBenn is offline
PostPosted: Fri Mar 30, 2018 10:31 pm    Post subject: Re: School me on Solar Reply with quote
erste wrote:
E1 wrote:
Very cool build!
Thanks E1.
The MT50 is just a monitor/control interface. You can also buy a wireless interface or usb to do the same from android phones or Windows computers. The controller is what shuts off tthe batery, does the multilevel MPPT algoriths, etc. EPSOLAR (now going by Epever) is the maker of the Solar Epic controller and MT50. BTW, those other interfaces allow graphing of solar performance throughout the day, a fun thing for geeks like me.
These controllers, while very nice in most respects are poor at gauging state of charge. They kind of work while the sun is up, but the 13+ voltage is not indicative of the state of charge.
Batteries take what's called a surface charge, which gets them above the 12.7 to 12.9(some AGMs) volts a fully charged battery should read. In order to gauge the state of charge, a common technique is to remove the charging source and let the battery sit for a day, or apply a small load for 5-10 minutes. Unfortunately, that's not possible when charging, so you typically see 13-14+ volts, depending upon what state thd charging algorithm is in.
Hope that's helpful.
Rich
E1
E1 is offline
PostPosted: Fri Mar 30, 2018 10:44 pm    Post subject: Re: School me on Solar Reply with quote
Great stuff Rich, Thanks.
One side benefit of a portable is immediate charge gratification. If I wanna know what the actual charge is, I just unplug the portable and check the inverter readout. It tends to read a few hundredths of a volt below testing the batteries (four feet of cable away), but gets me in the ballpark.
Stupid-simple can be bliss.
Abscate
Abscate is offline
PostPosted: Sat Mar 31, 2018 1:55 am    Post subject: Re: School me on Solar Reply with quote
That Sprinter install has at least four major workmanship flaws in the installation. This is an area best left to the pros if you donít want your Bus or Van burned up.
You cannot acquire expertise By reading the internet or looking at pictures
.ssS!
