mreuter Samba Member
Posted: Sat Mar 31, 2018 9:14 pm Post subject: Help with hardwood floor install in Westfalia Syncro |
I have a question about installing hardwood floor in my Westy. I found allot in this forum but most of the install is with cabinetry installed. I removed all my cabinetry to install Lizardskin sound and heat control. I wonder if I can install the hardwood floor covering the whole area and install the cabinetry and rear seat on top of the floor or do I have to install everything and than only cover the small area with hardwood floor like it is done in all the installs I found on Samba? Any advise would be appreciated.
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9937 Location: Orbiting San Diego
Posted: Sun Apr 01, 2018 2:32 am Post subject: Re: Help with hardwood floor install in Westfalia Syncro |
I always do the whole floor with cabinets out. Much cleaner that way. Leave some small gap at the hidden edges.
Mark |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sun Apr 01, 2018 7:52 am Post subject: Re: Help with hardwood floor install in Westfalia Syncro |
@djkeev & crazyvwvanman
Thank you for your advise! Any pictures you could share or link to your post?
Did you have to cut anything on the cabinetry? |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sun Apr 01, 2018 9:10 am Post subject: Re: Help with hardwood floor install in Westfalia Syncro |
I was going for the "Hacienda" look- with tile floors and mexi water basin--looked good, but weighted in at about 100# just for the floor. But did set a Masonite floor for the entire interior and tiled round the the amenities.
In the end, It was just to much weight and mechanicals put the project on the back burner after getting into splits.
Sold it to explorers who took all the heavy stuff out and really did an excellent job on putting it back on the road.
[img]
[/img]
[img]
Guess my point is- you can get really carried away with what you dream and in the end it's just not sustainable. After seeing other Scoolie builds with tile n stuff litterly fall apart on corrugated roads.- I will next stick to the KISS principal.[/img] _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Sun Apr 01, 2018 9:14 am Post subject: Re: Help with hardwood floor install in Westfalia Syncro |
I have a finished photo of the last one I did. It is easy, cheap, and looks good.
Mark
E1 Samba Member
Joined: January 21, 2013 Posts: 6563 Location: Westfalia, Earth
Posted: Sun Apr 01, 2018 9:16 am Post subject: Re: Help with hardwood floor install in Westfalia Syncro |
William, I Love the Hacienda look!
And the ceiling, I've toyed with that very design (in my head) for our headliner...
Mark, sweet. Great upholstery, too. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Posted: Sun Apr 01, 2018 9:26 am Post subject: Re: Help with hardwood floor install in Westfalia Syncro |
Side note- once your floor is in - get a "floor stabilizer" clear coat and it will basically "glue" all the seams together and give it a tough shine. _________________ some days I get up and just sit and think. Some days I just sit.
Posted: Sun Apr 01, 2018 10:30 am Post subject: Re: Help with hardwood floor install in Westfalia Syncro |
Wow, all this amazing work. I was going for the grey Allure Ultravinyl. 100% waterproof floor. I still have the original floorboards with the grey plastic on top. The floor will be higher so i was wondering if anyone had to cut the rear bench seat box on the bottom or was it not required at all? Th |
Posted: Sun Apr 01, 2018 12:13 pm Post subject: Re: Help with hardwood floor install in Westfalia Syncro |
Looks like my Westi subfloor is smaller. It ends right where the cabinetry is installed.
Timwhy Samba Member
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Mon Apr 02, 2018 7:28 am Post subject: Re: Help with hardwood floor install in Westfalia Syncro |
williamM wrote: |
[img]
Wow!
Your reply got me excited, I too want tile in my van, and bummed because you confirmed my fear of weight and durability.
Your tile looks amazing though (or DID look amazing) want to come do my kitchen?
Owen _________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
Posted: Mon Apr 02, 2018 9:17 am Post subject: Re: Help with hardwood floor install in Westfalia Syncro |
Timwhy wrote: |
I planed down strips of cedar for the ribs in the floor as an anchor. Holes where the exiting floor bolt held in the seat were left in place.
Then I screwed the strips in place and topped them with a piece of thin plywood. Finally plotted out the laminate and secure it with a piece of angled aluminum.
Looks amazing. Did you screw down every cedar strip? Any worries about water getting in from underneath? Did you use a planner for the strips to size them? |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2796 Location: North Carolina
Posted: Mon Apr 02, 2018 9:26 am Post subject: Re: Help with hardwood floor install in Westfalia Syncro |
When I put my laminate flooring in, I just kind of winged it and it's worked out great for over a year of pretty hard use. I filled each of the channels with reflective heat tape, then I glued down reflectix sheets, then I glued very thin plywood on top of that. Then, installed floor, trim, done. A true weekend job- actually a true single weekend day job, my favorite kind.
I guess what I'm trying to say is there way more than one way to skin this cat. I did it my way because my investment was whatever the reflectix roll cost because I already had everything else, including the floors that I helped a buddy remove from the house he had just bought.
Don't overthink it and have fun! _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
