Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24757 Location: Olympia Wash Rinse & Repeat
Posted: Thu May 10, 2018 8:37 am Post subject: Re: Java Green '64 with tree damage. |
You will need 3/4 drive socket and breaker bar to do the job. 1/2 drive will shear off.... _________________ In Stereo, Where Available! |
propguy Samba Member
Joined: September 10, 2004 Posts: 86 Location: Madison, WI
Posted: Thu May 10, 2018 9:11 am Post subject: Re: Java Green '64 with tree damage. |
Yes to the 3/4" breaker bar. I have broken several 1/2" drive ones. Luckily it was a craftsman and they replaced them both. |
KollynnBlackpaw Samba Member
Joined: October 19, 2016 Posts: 528 Location: Hubbard, Oregon
Posted: Thu May 10, 2018 7:12 pm Post subject: Re: Java Green '64 with tree damage. |
Will do! The car is up in the driveway now, so he's safe, but I'll still have to do brakes obviously. Going to pick up pistons/cylinders for the squareback this weekend, then get wear parts for the bug engine to do my first old-parts build. _________________ '71 Shantung Yellow AT/FI Squareback |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Fri May 11, 2018 6:33 am Post subject: Re: Java Green '64 with tree damage. |
KollynnBlackpaw wrote: |
mukluk wrote: |
The rear axle nut is 36mm on a Beetle; be aware they're normally torqued to a minimum of 217ftlb. |
Okie dokie, know I got one of those. And yeah, I'll be using a biiiig cheater pipe. |
Get a Torque Meister tool _________________ 1963 Ragtop Bug |
Posted: Wed Jul 04, 2018 12:34 am Post subject: Re: Java Green '64 with tree damage. |
Righto - been a bit. Eiche's been on the backburner for a hot minute as both the Squareback and the Bus shat out for a while. The Square is up next for getting worked on as the bus has just started running (well enough) again.
But! I've got a savings for the Bug going. Getting enough money together for a motor - I want to get him to fire before I focus on wheels, brakes, pans, body work, wiring, dropping... the list goes on. But I'll follow through on him! We'll see where the body work gets, as I'm looking at possibly leaving my shop behind, but I have a friend with a portopower who will hopefully still be around to let me use it, as he's just left the shop as well.
Y'all will see big updates coming in the coming month or so! I plan on having that motor done! _________________ '71 Shantung Yellow AT/FI Squareback |
Rome Samba Member
Joined: June 02, 2004 Posts: 9651 Location: Pearl River, NY
Posted: Wed Jul 04, 2018 7:59 am Post subject: Re: Java Green '64 with tree damage. |
Glad you still have an active interest in Eiche. Were you able to thoroughly clean your heads and the rest of the engine parts so that you assess your rebuild possibility on them? |
Posted: Wed Jul 04, 2018 12:21 pm Post subject: Re: Java Green '64 with tree damage. |
Rome wrote: |
I've actually got them all setting with a friend who's a well known engine builder around here. He'll be making sure everything looks alright that we can use, and when we've got all the parts together he'll show me how to build. I'm very excited to learn! _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Tue Aug 07, 2018 4:39 pm Post subject: Re: Java Green '64 with tree damage. |
Hi all! Unfortunately - I've agreed to sell Eiche to a friend for double my money, plus work on my other cars. But I'll still keep you guys updated! I'll likely be working with him on it, learning welding, he's going to teach me rebuilding on his motor, and as far as I know he'll be putting in a split (or oval, can't remember) rear window, a sliding rag, and just fixing some of the body damage and spotting in places he bondo's. I told him a prerequisite for him buying it is NO repainting the car! And he agrees, happily. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Tue Aug 07, 2018 4:45 pm Post subject: Re: Java Green '64 with tree damage. |
Well as long as the beetle is getting some help. Thanks for the update! _________________ In Stereo, Where Available! |
Posted: Tue Aug 07, 2018 4:52 pm Post subject: Re: Java Green '64 with tree damage. |
Of course! And I'll be keeping y'all heavily up to date. Gonna make sure he sends lots of pics and info. He only lives a bit away so won't be hard. _________________ '71 Shantung Yellow AT/FI Squareback |
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Tue Aug 07, 2018 6:55 pm Post subject: Re: Java Green '64 with tree damage. |
Awesome! Good to hear and thanks for the update! _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
